Old Jun 26, 2011, 12:25 PM
drew905 is offline
Find More Posts by drew905
ca
Joined Sep 2004
how to set throttle range on a tower pro H18A ESC
AFTER MY ESC IS SET UP. THE ESC WONT ENGAGE UNTIL ABOVE HALF THROTTLE . BUT it does RECOGNICE stick at low POSITION DURNING STARTUP. THE INSTRUCTIONS SAID THROTTLE RANGE SETTING ON PAGE 4. BUT THERE'S NO PAGE 4 ON THE INSTRUCTIONS . DOES ANYBODY HAVE THIS INSTRUCTIONS FOR THE THROTTLE RANGE LEARN ? I'm using a Futuba 9Chp transmitter with a spectrum AR6000 receive.
drew905 is offline Find More Posts by drew905
Old Jun 27, 2011, 12:00 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Drew;
Welcome to RCG.
Throttle must start at full up.
http://www.towerpro.cn/english/Manual/manual.html
TOWERPRO CO.LTD
BRUSHLESS MOTOR CONTROLLER
SETUP MENU (for new 18A /20A)
First, connect the motor and receiver to the speed controller
Remove battery power from the speed controller.
Turn on the transmitter.
Move throttle stick on full power position (UP Position)
Reconnect battery power to the speed controller
After 3 sec you can hear (all sound is 3 times)
∮— CELL Type AND Number
∮— — BRAKE
∮— — — TIMING MODE
∮— — — — Voltage Protection
ON you need programming menu, move the throttle stick to the middle position
5. Cell type and number SET
•— — 2LIPO (7.4V)
•— — — 3LIPO(11.1V)
6. BRAKE SET
••— NO
•••— — SOFT
•••— — — MID
•••— — — — HARD
7. TIMING MODE SET
•••— 2
••••— — 7
•••••— — — 15
•••••— — — — 30
8. Voltage Protection
••••— 2.8V/CELL
•••••— — 2.9V/CELL
•••••••— — — 3.0V/CELL
Attention: 10C or higher battery suggest select the 3.0V as the protection voltage. IF the option is you need, then move the throttle stick to UP position.
The long BEEP is save the option. And the system will go to the programming menu. You can setup other options.
When all you need option is setup ok, push the throttle stick to down position, after 1 sec the system will save all option, and then you can start the motor now.
rick.benjamin is offline Find More Posts by rick.benjamin
Old Jun 27, 2011, 02:37 AM
keyman923 is offline
Find More Posts by keyman923
Former Futaba employee
Joined Aug 2006
Towerpro left page 4 out of instructions, follow these
http://www.hobbywing.com/upload/manual/ESC_e.pdf
keyman923 is offline Find More Posts by keyman923
Help! Tower Pro BP-21 cutting out at full throttle joeyimscared Electric Plane Talk 3 May 17, 2011 02:05 PM
Help! HK SS 15-18 amp ESC stuck on reverse throttle range mman1506 Power Systems 5 May 09, 2011 04:17 PM
Question How do I set the brake on an Electrify ESC when throttle is on the switch? robh Power Systems 8 May 23, 2009 08:38 PM
Question How to set throttle range with Jeti Spin box ? badbill Power Systems 0 Dec 25, 2007 02:55 PM
Discussion How do I program a Throttle Curve to smooth out Tower Pro 15A ESC? mrebman Power Systems 11 Mar 19, 2007 09:49 PM
