Joined Feb 2006
I'm using the most deflection I can get without the control surface binding with the pushrod. Same thing with flaps, i'm running as much as I can get.
I went to fly it friday and had a hard time getting it off glassy water. It just wants to be suctioned to it. While plowing threw the water for such a long time they took on some water so before flying this one you might want to seal the floats up better. |
Humm...
I have tried to take off from water with some water inside floats...too bad...
I used so much elevator that I made a vertical climb from water when take off. Ir was so fast that I could not avoid crash. Now, I decided for a cam on the hook so I can see how things are going on far from my spot. Do you think it is a good idea? |
Joined Feb 2006
Well, I wrecked it today! Went out for the first time in a good year to do FPV stuff on land before taking it out to the lake tomorrow. Made about 5 flights then suddenly I lost all flight controls, pretty sure motor stopped also. I still had video.
I looked up, saw it spiraling in, then went back to the TV screen to try to watch exactly where it was going to hit. We are in a hilly area with tall grass. Anyway, I can't say I'm not disappointed but the carnage almost always makes up for it. Great airplane. I'm ordering another tonight! I just need to figure out if it was the receiver (HK orange), the FPV gear and maybe interference?, the ESC, etc? What caused the failure!?!?! |
Joined Jan 2006
Just got my cessna rtf tonightI went out to test the thing for the first time with the floats on it and crashed it into the lake twice! Anyway it got off the water ok but immediatley was all over the place and nose dove into the lake. I am an experienced pilot but have never flown with floats on. It seemed to be way off balance, maybe underpowered? It flip flopped all over the place. I don't know it just did not want to fly well. One thing I noticed when building it was the motor was angled to the right so i put in some spacers to straighten it. Maybe It was supposed to be that way? The CG was near the leading edge of the wing and the flaps, ailerons and elevators were all even. Overall I like the plane but am scared to repair it and get it back in the air. It doesn't make much sense as to why it was behaving this way.
Joined Apr 2008
If I read your post correctly your CG was close or at the leading edge. This is too far forward and would definitely cause a problem. Your CG should be closer to the wing spar area. You need to re balance your plane once you put floats on. Also, put the right thrust back the way it was.
| Thread Tools | |
| Mini-Review Hobby King Cessna 182 RTF Deluxe / Skyartec Updated | hipher | Foamies (Kits) | 11 | Sep 13, 2011 03:02 AM |
| Build Log Hobby King 1.5 meter Cessna 182 w/ Floats | WAFlyer15 | Foamies (Kits) | 5 | Jul 01, 2011 08:07 PM |
| Discussion Hobby King 36" Cessna 182? | CyberJay | Waterplanes | 0 | Apr 23, 2011 09:01 PM |
| Sold HobbyKing Durafly Cessna 182 1.4m | esa3 | Aircraft - Electric - Airplanes (FS/W) | 5 | Mar 15, 2011 04:56 PM |
