Old Jun 24, 2011, 11:01 AM
WBFlyer is offline
Find More Posts by WBFlyer
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
bought 60 size NTM motor need ESC recommendations
I have a 60 amp ESC but wonder if it will be enough. The plane will be about 7 lbs and the motor is 470k Ibeleive. I would be using a 5 cell lipo or maybe 6 cell. THe mototr recommends a 60 amp esc and cell range between 5-7.
WBFlyer is offline Find More Posts by WBFlyer
Old Jun 24, 2011, 12:42 PM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
post the motor details and what size prop you gonna swing ?
Blackrat is offline Find More Posts by Blackrat
Old Jun 24, 2011, 02:29 PM
WBFlyer is offline
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
Spec.
Battery: 5~7 Cell /18.5~25.9V
RPM: 400kv
Max current: 40A
No load current: 10V/2.7A
Current capacity: 60A/15sec
Internal resistance: 0.06 ohm
Weight: 359g (not including connectors)
Diameter of shaft: 6mm
Dimensions: 81x50mm
Old Jun 25, 2011, 03:53 AM
Blackrat is offline
Registered Loon
Blackrat's Avatar
Joined May 2006
yea that will be fine then, just make sure you run a prop that is suited for 5/6s ... is that esc you got rated to handle 6s ?
start with a small prop , and check amp draw , then go bigger
Old Jun 27, 2011, 10:57 AM
WBFlyer is offline
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
Would I gain a lot more going 6 cell or can I stick with 5? I need to order a battery fo rher.
Old Jun 28, 2011, 12:51 AM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
what type of plane? If it's your typical floater like a .60 sized trainer ya itll more than fly it.
yes, a 7 pound plane is a .60 class 2 stroke
where it gets confusing is:
1) engine performance is very WIDE (for example just in 2 strokes, an old Enya .60 will only putt putt an 12-6 at 10,000rpm. that's no faster than a .45 class engine. where most good .60 class engines are going to be turning a 12-6 in the 13-16500rpm range. (and likely running a little more prop)
2) virtually all common quick sizing formulas advocated (like the popular displacement in ci * 2000 = watts for a target) leaves you with a far under powered version of what would commonly be encountered with modern glow engine designs from the last 20 ish years.
You either wind up with the same thrust, completely lacking the pitch speed, or you can get the pitch speed & loose the thrust. VS a properly sized 2 or 4 stroke glow plant. (most common is to have the same thrust, and half the pitch speed.)
unless im missing something you bought a Turnigy Easymatch 60 as there is no 400kv NTM currently listed on HK.
http://www.hobbyking.com/hobbyking/s...dProduct=14405
So for just some generic plane, yes. That will more than fly it, however. It is not likely to have the thrust and pitch speed a typical .6X class 2 stroke, or .90 class 4-stroke. So if it's an aerobatic or fast model, def get more motor on it! (Honestly brushless outrunner installations generally have a lot more in common with the powerband diesels have)
Toysrme is offline Find More Posts by Toysrme
Old Jun 28, 2011, 02:28 PM
WBFlyer is offline
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
Ok, thanks for the detailed info! I bought a 6 cell lipo with my 60 amp ESC and the Easy match .60 motor. Not looking for crazy performance but would like strong take offs in short runway areas. I think this would do that, but I am not going to get vertical performance by any means.
Old Jun 28, 2011, 02:41 PM
Toysrme is offline
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
what kind of plane?
Old Jun 28, 2011, 04:30 PM
WBFlyer is offline
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
I got it from Nitro Planes. It's th e.60 size gas low wing trainer that I am converting to electric. 71 inch wingspan and about 7 lbs.
Discussion Need help with Hyperion Zlin 50L motor size AeroWolff Electric Plane Talk 3 Jul 27, 2011 08:49 PM
Discussion Many posts, need a few recommendations on upgraded motor, esc and servos! bigo66 Foamies (Kits) 2 Feb 22, 2011 07:52 PM
For Sale FT-FS EDO F-15, need 60 size motor. Magnumpi Aircraft - Fuel - Engines and Accessories (FS/W) 2 Apr 13, 2009 09:36 PM
Off Site Graupner Ultra 2000-7H Brushed 60 size motor + ESC tree_top_chop Aircraft - Electric - Helis (FS/W) 0 May 31, 2005 12:30 AM
