Old Jun 24, 2011, 08:03 AM
sean11 is offline
Find More Posts by sean11
Joined Jun 2011
Propeller recommendations Bixler/ sky surfer
Hi
Having successfully flown inverted - I was temporally was distracted - only to now require a replacement propeller - think it's a 5x5. And is there any real difference with the push prop or is just a conventional mounted - conventionally -if you see what I mean?
Any advice great fully appreciated - and yes I now know ... Down is up.
Bixler survived :-) happydays
sean11 is offline Find More Posts by sean11
Old Jun 24, 2011, 08:53 AM
DrEvil is offline
Find More Posts by DrEvil
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
TGY Sport 5x5 is the same prop i think, and yes you can use a
"convential" prop for a pusher setup.
As long as you mount the prop with the lettering facing forward in
flight direction.
I'm glad your Bixler made it ;-)
Kai
DrEvil is offline Find More Posts by DrEvil
Old Jun 24, 2011, 10:42 PM
himeros is offline
Find More Posts by himeros
O. C. CA
Joined Jan 2005
You could try the 6/4 prop, seems to work good.
H.
himeros is offline Find More Posts by himeros
Old Jun 25, 2011, 06:08 AM
sean11 is offline
Joined Jun 2011
Prop
Thanks guys - I'll try both
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Wanted Hawk Sky, Wild Hawk, Sky Surfer, etc dpw21562 Aircraft - Electric - Airplanes (FS/W) 5 Mar 06, 2011 07:12 AM
Discussion Blitz Sky Surfer as a Tractor clayfeld Foamies (Kits) 1 Mar 05, 2011 06:21 PM
Wanted Wild Hawk, Hawk Sky, Sky Surfer, dpw21562 Aircraft - Sailplanes (FS/W) 0 Mar 03, 2011 07:03 PM
