Espritmodel.com Heli Air
Old Jan 19, 2012, 12:07 AM
Joined Jul 2011
Originally Posted by M4d_D View Post
do the JR receivers have a ppm output ? i need it for a mikrokopter or for my multiwii ... can i use the 4channel receiver rg411b with ppm to get all 8 channels ( like its possible on a frsky system ) ?
HI,
no and no. At least not now.
You can use a single line converter from ikarus modellbau.
Cheers, Ralf
rapega is offline Find More Posts by rapega
Old Feb 03, 2012, 03:47 PM
Ελλάδα, Δυτική Ελλάδα, Πάτρα
Joined Jun 2009
Has anyone experience with the xg8 and rg831 in 50cc plane or bigger ?
johncoulouris is offline Find More Posts by johncoulouris
Old Feb 04, 2012, 01:16 AM
Russia,Moscow
Joined Jan 2007
I run it on the 30cc sized electric plane. What is you concern? The range or how it will go along with 50cc engine?
vic_bull is offline Find More Posts by vic_bull
Old Feb 04, 2012, 04:35 AM
Joined Jun 2009
Both of them
Old Feb 04, 2012, 08:43 AM
Russia,Moscow
Joined Jan 2007
I couldn't comment much, I rarely hit more then 150 meters mark from TX.
Old Feb 26, 2012, 01:23 PM
Russia,Moscow
Joined Jan 2007
Does anyone has any experience with TLS-PWR power sensor? I just got mine and a bit dissapointed. First, the software on XG8 doesn't show you amps, only volts and mah consumed. Second, according to four other measuring devices I have, it shows the voltage of the pack 0,3-0,4v higher and there is no way to calibrate anything of course.
Old Feb 27, 2012, 12:40 AM
Joined Jul 2011
HI,
you did update your XG8?
Cheers, Ralf
Old Feb 27, 2012, 02:31 AM
Russia,Moscow
Joined Jan 2007
Sure I did. The latest firmware is something-007.
Old Feb 27, 2012, 02:35 AM
Joined Jul 2011
F***
The Power Sensor ist not yet to buy in germany, but that sounds bad.
Measuring the consumed power is my basic need to have maximum flight time.
I hope JR is going to fix that. (And add logging for the telemetric data.)
Greetings from germany,
Ralf
Old Feb 27, 2012, 02:53 AM
Russia,Moscow
Joined Jan 2007
Ralf, I have bought mine in Japan, seems to be the only place for now. I don't worry a lot for not showing amps on the TX screen, I think it would be implemented in future, at least it sound logical. But what I really don't like that the device itself pricey and the voltage measurement is off. I say it's off because when I connect fully charged 4S lipo it shows me 17.2 Volts which couldn't be of course. And knowing that the voltage measurement is off I couldn't trust the total MaH consumed of course.
As for the logging, I don't think they will implement it in XG8, marketing you know.
Old Feb 27, 2012, 03:08 AM
Joined Jul 2011
Well, I have an 11X Zero and an XG8, I hope the new firmware for the 11X will come soon.
But I presume I will go back to HoTT as soon as they have a good affordable transmitter.
In the 11X I have the choice of DSM2, FASST, FrSky, KDS, HoTT and more. ;-)
So I am quite relaxed.
But for now, DSM2 is the best choice for the 11X, because it is not using PPM to feed the Module.
You can see that in the Monitor/Servo Test mode, with DSM2 they run smooth, with all other the Servos are a bit jumpy.
Greetings,
Ralf
Viele Gruesse,
Ralf
Old Feb 27, 2012, 03:27 AM
Russia,Moscow
Joined Jan 2007
Speaking of HoTT and other German manufactures I think we have to keep an eye open for the sensors made for use with the JR. Like WS-tech or SM-modellbau. I hope they will provide soon wide array of the sensors which are gonna be more precise then the current JR sencsors.
Old Feb 27, 2012, 04:13 AM
Joined Jul 2011
SM-Modellbau will not, I asked them.
Old Feb 27, 2012, 04:34 AM
Russia,Moscow
Joined Jan 2007
I just asked JR on the Facebook about calibration of the power sensor. They told they are going to implement it in the TX firmware soon. So not everything lost. Just needs some time, again.
Old Feb 27, 2012, 04:41 AM
Joined Jul 2011
That sounds good! Thank you!
Rave JR XG7 DMSS thread NEW!! Mikarro Radios 77 Dec 04, 2012 06:00 PM
Discussion Spektrum DX8 vs. JR XG8 Pippin Radios 112 Apr 04, 2012 06:36 PM
Discussion JR XG7 DMSS & DSM2 rx sidneyw Radios 2 Apr 03, 2011 11:08 AM
Discussion Jr xg7 dmss khymlawrence Radios 1 Mar 29, 2011 12:15 AM
Off Site Jr xg7 dmss khymlawrence Aircraft - General - Radio Equipment (FS/W) 0 Mar 28, 2011 08:02 PM
