Old May 01, 2012, 10:08 PM
EightOhMike is offline
Find More Posts by EightOhMike
EightOhMike's Avatar
United States, NC, Greensboro
Joined May 2011
Wing flutter, indeed, and I built as true to the plans as I could muster, to include the covering. I used standard Ultracoat, not the light stuff. Invariably, then, I don't have it tight enough, which occurred to me today as the wing fluttered again, on a descending pass, but really not a high-speed pass, maybe thirty-five to forty miles per hour tops, nowhere near the sixty-something that someone mentioned (maybe it was Tim (Laquerhead) when he downloaded the data).
Anyway, it turns out my wife caught the flutter on video... Two notable things on this video: the strange sound from my motor at about the six second mark, and the flutter at about the thirty-second mark. After the flight it occurred to me that I probably needed to tighten the covering (and probably adjust the washout as well).
And if the video didn't load properly, here's the link.
<iframe width="640" height="360" src="http://www.youtube.com/embed/oJlRC7wDjlk?rel=0" frameborder="0" allowfullscreen></iframe>
EightOhMike is offline Find More Posts by EightOhMike
Old May 03, 2012, 01:34 PM
Lacquerhead is offline
Find More Posts by Lacquerhead
Wood Chucker
Lacquerhead's Avatar
USA, TX, Allen
Joined Nov 2009
Ewwww, that was a moment of excitement I hope you don't experience again. I'd also suggest you check your motor mount. If its loose you can get all sorts of weird noises like that. I had a screw back out a bit (because I was stupid and used a screw that was WAY too small) and let the mount vibrate. Took a bit of looking but was obvious what the problem was once I found it.
Lacquerhead is offline Find More Posts by Lacquerhead
Yippee! New kit from House of Balsa, Electric Commander Dennis Sumner Parkflyers 147 Sep 13, 2014 06:04 PM
Discussion Found Electric GEE BEE Balsa Kit! avengedkevinfold Electric Plane Talk 0 Apr 02, 2011 06:51 PM
Discussion Recommendations: Scale Electric Float Flyer WAFlyer15 Scale Kit/Scratch Built 12 Mar 19, 2011 10:53 PM
Sold New In Box - House of Balsa P-51D Mustang Electric Balsa kit Henna_Ojisan Aircraft - Electric - Airplanes (FS/W) 3 Oct 23, 2008 09:57 AM
Wanted Original Gryphon sail plane (balsa wood kit): Model Dynamics/Bob Martin Elsalen Aircraft - Sailplanes (FS/W) 1 Dec 31, 2007 03:04 PM
