This thread is privately moderated by demondriver, who may elect to delete unwanted replies.
Old Jul 17, 2011, 11:52 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
is that 767 falling over in the background chris go prop it up before it falls and gets a bad case of hangar rash
Keenan smith is offline Find More Posts by Keenan smith
Old Jul 17, 2011, 01:04 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
It's O.k. K It's just on an angle because the stand is broken, I hope to fly it soon!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Jul 17, 2011, 05:46 PM
Marrone is offline
Find More Posts by Marrone
Gravity manager
Nederland, NH, Amsterdam
Joined May 2011
Hee demondriver!
She's looking better and better as you progress. In your first movie you said that you probably were going to cutout and hinge all controls. Did you? Is it really necessary on foam planes? what kind of hinges did you use?
Marrone is offline Find More Posts by Marrone
Old Jul 18, 2011, 01:23 AM
Up-Out-&-Gone
Joined Mar 2007
Originally Posted by Marrone View Post
Hee demondriver!
Hi Marrone that's a great question, I find plastic hinges seem to hold up better than tape or the foam itself, I've cut out all the control surafces & an now ultracoting them before re-attachtment.
Old Jul 18, 2011, 01:35 AM
Up-Out-&-Gone
Joined Mar 2007
I found that the Windrider decals have a non-glossy matte finish so I glossed them up with Testors-model master high gloss
Old Jul 18, 2011, 01:44 AM
Up-Out-&-Gone
Joined Mar 2007
A bit of decals & some Ultracote & we have some progress on the Windrider 737!
Old Jul 18, 2011, 04:56 AM
Marrone is offline
Gravity manager
Joined May 2011
Just to inform you in case you did not know. There have been some problems with the landing gear experienced and described by the guys in the other rc groups windrider topic.
The landing gear appears to bend when landing on hard surfaces. Therefore the wire in the landing gear needs to be replaced with a 4mm steel wire, the spring can be shortened a bit and the shaft should be replaced by a bigger one. (if i remember correctly) it is also advisable to use different edf fans since the standard one that come with the kit seem to have some balancing problems causing the motor to be ripped out.
Old Jul 18, 2011, 12:05 PM
Up-Out-&-Gone
Joined Mar 2007
Thanks Marrone! I have also heard about the retract strut wire not being strong enough, I'll replace it with a stronger steel piece or carbon fiber one, & as for the edf's allot of edfs need balancing I just hope that these don't.
Old Jul 18, 2011, 09:39 PM
phillipd is offline
Find More Posts by phillipd
Joined May 2011
looks awsome this is going to be one of the top ones out there
phillipd is offline Find More Posts by phillipd
Old Jul 19, 2011, 05:11 PM
Up-Out-&-Gone
Joined Mar 2007
I just do my best Boss, I just hope your happy when you get it.
Old Jul 19, 2011, 05:44 PM
Marrone is offline
Gravity manager
Joined May 2011
does the tail of the fuselage not fit perfectly on the main fuselage with you too guys? Concerning alignment that is.
Old Jul 19, 2011, 06:05 PM
Up-Out-&-Gone
Joined Mar 2007
Hi Marrone the windrider 737 has to be "eyeballed" when you epoxing it or hot-gluing it into position in order to inshure it's perfectly verticle.
Old Jul 20, 2011, 07:16 AM
Marrone is offline
Gravity manager
Joined May 2011
Thanks demondriver, but are we talking about the same?
When fitting the back fuselage in to the front fuselage part, you have these rectangular of foam on the inside that are there to align the two parts. When putting mine in without any forcing, the alignment of fuselage is not correct. I can get it aligned by forcing but when not forcing it is not aligned. Is this a small flaw inherently to these foam planes or do i have to send mine back. Do you guys also have some dents here and here? I have them. Strange, since it was packed outstanding and there was damage on outside of package.
Old Jul 20, 2011, 10:46 PM
Up-Out-&-Gone
Joined Mar 2007
I think I understand Marrone, the rear tail part of the fuselage can be tricky to get lined up but you've gotta try your best, as for dings & dents simply use light-wieght spackle to fill in any dents.
Old Jul 20, 2011, 10:48 PM
Up-Out-&-Gone
Joined Mar 2007
Here are both 737 halves with decals being added soon I'll epoxy the halves together.
Found Windrider 737/787 teha99 Aircraft - Electric - Jets (FS/W) 2 Jun 24, 2011 12:23 PM
Sold Windrider 737 ARF Flexserve Aircraft - Electric - Jets (FS/W) 17 May 10, 2011 07:58 PM
Discussion Windrider 737 donation to Japan earthquake Ming Foamy EDFs 27 Apr 22, 2011 07:38 AM
Video Windrider 737 Transavia.com livery Fotor Electric Plane Talk 2 Mar 24, 2011 04:54 PM
