| Thread Tools |
| This thread is privately moderated by demondriver, who may elect to delete unwanted replies. |
Latest blog entry: Mini 50MM EDF F-105D Thunderchief
Now I'm painting the 737's engine nacell's testors gloss grey, then I'll apply another coat of 20 surface cote to make then scratch resistant.
Starting on the 737's nose gear, something Rookie2008 mentioned have come to pass . . . .the heavy China models rubber wheels that come with this kit are WAY to heavy for the retract motor of the servoless retract, i'll have to use lighter foam substitutes, plus I'll have to modify the nose gear well to accomidate the wheels.
Now I'm adding the nose gear to the 737, but there is one small problem thta everyone who's built the Windrider 737 has come across . . . . .there's not enough room in the wheel well for the retract to retract all the way into the well, here is the foam I cut away in order to solve this problem.
Now I'm adding the light-glass cockpit & also am adding the retact extensions & Nose wheel light wire to the nose section before joining the two fuselage halves.
Now I'm adding the lock nuts to the 737 plywood wing brackets before installation.
Joined at last! I finally have joined the two 737 fuselage halves together!
| Thread Tools | |
| Found Windrider 737/787 | teha99 | Aircraft - Electric - Jets (FS/W) | 2 | Jun 24, 2011 12:23 PM |
| Sold Windrider 737 ARF | Flexserve | Aircraft - Electric - Jets (FS/W) | 17 | May 10, 2011 07:58 PM |
| Discussion Windrider 737 donation to Japan earthquake | Ming | Foamy EDFs | 27 | Apr 22, 2011 07:38 AM |
| Video Windrider 737 Transavia.com livery | Fotor | Electric Plane Talk | 2 | Mar 24, 2011 04:54 PM |
