Old Jun 23, 2011, 04:54 AM
Blackrat is online now
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
torque roll - not torque roll , but a rookie mistake post 12
after ditching my plane yesterday on launch i was thinking whats the best way to help reduce torque roll on launch ?
after driving around for an hour to find somewhere to fly and getting all setup and ready to go and then seeing the esc would only power up to 15A i thought what the hell lets go for it, not gonna waste another week with the weather and finding the time to fly
FPV Farm cruise , just having fun (3 min 16 sec)
you can see by the time i get my hand to the stick its already rolled over and too late ... throwing with my right hand and being mode 2 doesnt help
i built a similar plane but with bigger wings and it doesnt have this problem at all , but i dont like the big wings as its too bulky
i was thinking bigger prop and lower kv motor ? but this would make things worse ? or not ?
anyone else having a handful with torque rolls ?
Blackrat is online now Find More Posts by Blackrat
Old Jun 23, 2011, 04:58 AM
areis81 is offline
Find More Posts by areis81
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
no, you need smaller prop and higher kv to reduce torque roll
areis81 is offline Find More Posts by areis81
Old Jun 23, 2011, 05:36 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
The only prop planes I hand launch is a Funjet and Ritewing but don't FPV with them. I put landing gear on my Skywalker to avoid hand launching for FPV. If you don't want to do that, consider a dolly. I recently made and used one for the first time on my Flyfly Mirage and it worked great. I know some guys launch los and transition to the goggles once at altitude. I have done that once and didn't like it.
techspy is offline Find More Posts by techspy
Old Jun 23, 2011, 07:00 AM
swami is offline
Find More Posts by swami
swami's Avatar
Ursel, Belgium, Europe
Joined Jul 2001
Maybe you can setup your transmitter to use the rudder stick to give some aileron input to the right.
Dirk.
swami is offline Find More Posts by swami
Old Jun 23, 2011, 02:24 PM
Registered Loon
Blackrat's Avatar
Joined May 2006
Dirk.
sheesh ... now why didnt i think of that !!!!!!!!!!
thanks a million
*grabs Tx and starts programming*
Old Jun 23, 2011, 02:32 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
To reduce torque roll you need less torque.
Less throttle and/or less prop.
Toysrme is offline Find More Posts by Toysrme
Old Jun 23, 2011, 03:39 PM
hazchem88 is offline
Find More Posts by hazchem88
Joined Dec 2009
and/or do what I did, add a little right roll.
I did this via a switch. when switch is on a little up elevator (about 2mm) and a little right roll.
Never torques on me
hazchem88 is offline Find More Posts by hazchem88
Old Jun 23, 2011, 06:06 PM
henkvdw is offline
Find More Posts by henkvdw
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
Blackrat
What kind of wing do have there?
Flying over the dairy farms is a good idea getting fimiliar with the plane.
I have been eyeing the Hanekam Mountains for a while.
Stormsrivier and the Garden Route will have some beautiful scenery too.
Don't get down there to often though.
Henk
henkvdw is offline Find More Posts by henkvdw
Old Jun 23, 2011, 07:05 PM
Toysrme is offline
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
the real answer here is "throw it with less throttle and be smoother in your input" heh.
as said you can go old school and just move the trim over a tad. or make it heavier & more complex by tossing a gyro on the roll axis.
Old Jun 24, 2011, 09:43 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
don't throw dirrectly into the wind but rather slightly to the right of the wind
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Jun 24, 2011, 12:39 PM
Registered Loon
Blackrat's Avatar
Joined May 2006
also a good tip, thanks
my dad said the wind was blowing from behind ( slight breez ) i wasnt paying attention , i was more concerned about the esc spooling up oh well ... after watching the osd video it confirmed what he said lol couldnt argue with that
stormsriver coming up just need to iron out a few minor things now , but getting there
Old Jun 29, 2011, 03:14 AM
Registered Loon
Blackrat's Avatar
Joined May 2006
problem solved, its not torque roll
so after an awesome launch today (right trim to lift right elevon about 3-4mm) i thought a bit about the launch , it launched perfectly and immediately started to pull to the right. Click click on the left trim and got her flying nice and straight and proceeded on with my mission
when i got home i checked out the levels of the elevons and this is when the penny dropped , hear me out
because i have the video Tx on the far right hand wing (no counter weight on left wing) when i fly i need to trim in left hand trim to get her to fly level (the weight of the vtx pulls the right wing down) thats all good untill the next flight ....
because i now have left hand trim ( from the previous flight) and i launch the aircraft it does exactly that , it goes hard left , and bam
not torque roll but rather stupid rookie mistake , and this explains why sometimes it launches straight out perfectly level and doesnt always have the same left hand pull
yippeee , im still making a launch rail
Old Jun 29, 2011, 07:17 AM
Gamblerman is offline
Find More Posts by Gamblerman
Gamble with Gravity
Gamblerman's Avatar
Joined Jun 2011
I had the same problem with my Falcon Flying wing. I couldn't see how to throw it correctly. I tried IBCrazy's "sky hook" toss and that was ok, but still didn't fix it. My solution was to use a different plane for FPV.
Try the sky hook. Instead of tossing the plane forward, throw it in an arc over your shoulder kind of like a lay-up shot in basketball. You can tilt the plane in the thorw so the torque roll results in a leveled out plane.
Gamblerman is offline Find More Posts by Gamblerman
Old Jul 01, 2011, 09:12 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
I think when most people talk about torque roll on a hand launch, it is just a bad hand launch....
Maybe examine your launch technique first? Are you really launching it with wings level? Also I think not having your thumb on the stick is a very bad idea....
Try to learn to launch with your left hand, then you can correct instantly. It feels weird at first but it is easy once you do it.
Gree is offline Find More Posts by Gree
Old Jul 01, 2011, 09:28 AM
CaliDave is offline
Find More Posts by CaliDave
CaliDave's Avatar
Bay Area
Joined Dec 2010
Why no counter balancing when designing that? Seems it will be more stress throughout the entire flight as the plane compensates for the weight with trim on one side. I'm guessing you'd lose some performance due to that.
CaliDave is offline Find More Posts by CaliDave
Question Torque Roll solutions runester351 Pusher Prop Jet Models 8 Jul 07, 2011 10:48 PM
Discussion Funjet massive torque roll- need help kingkyle Flying Wings 10 Apr 30, 2011 09:23 PM
Discussion Too much torque roll 3DHS KillerCut 3D Flying 5 Mar 31, 2011 03:08 PM
Discussion Habu torque roll! Ara Tidwell Foamy EDFs 0 Mar 30, 2011 08:19 PM
"Torque roll" with Twin-Jet Jurgen Heilig Foamies (Kits) 23 May 17, 2001 05:06 PM
