Old Jun 22, 2011, 07:28 PM
Danal Estes is offline
Find More Posts by Danal Estes
Flys with Thumbs
Danal Estes's Avatar
Frisco, TX, USA
Joined Sep 2001
Arduino support to drive an Eagle Tree Power Panel LCD
I recently wanted to drive an Eagle Tree Power Panel LCD display with an Arduino. I found lots of partial examples, but nothing approaching a complete sketch. Once I completed my other projects, I packaged up the code into a couple of "demonstrator" sketches. One uses the Arduino standard "Wire" library. The other has its own primitives for i2c support, and is therefore about 960 bytes smaller. They are otherwise nearly identical. It is a fairly full implementation, including cursor positioning, and the ability to define custom characters.
The Power Panel lists for US $40 at Eagle Tree. It may be available for less at other vendors. It is small, lightweight, and being transflective is much more readable in daylight than most back-lit LCDs.
The Arduino shown below is a Mini Pro from Sparkfun Electronics. The code has also been tested on an Arduino Uno.
I hope these examples will help anyone wishing to drive this display with an Arduino (or maybe even other micro controllers).
Danal Estes is offline Find More Posts by Danal Estes
Old Jun 25, 2011, 07:48 AM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Wow, it is very nice to see ready to use code. Thank you for sharing Danal!
It worked fine on Arduino Nano v3 I have.
Satoru
ssatoru is offline Find More Posts by ssatoru
Old Jun 26, 2011, 03:54 PM
Flys with Thumbs
Frisco, TX, USA
Joined Sep 2001
Satoru
Good to hear that it worked on someone else's hardware. That's always the ultimate test!
Old Sep 05, 2011, 02:59 AM
odam2k is offline
Find More Posts by odam2k
Team Basement-RC
odam2k's Avatar
Canada, ON, Toronto
Joined Jul 2008
I don't understand why this thread hasn't more responses, this is fantastic stuff! Now I have a simple, easy to use display for my projects, and its been lying in a drawer unused up till now.
Thanks so much for sharing... now if I can get the arduino and the MKQuad talking via bluetooth or xbee, I'll be laughing!
Thanks again!
odam2k is offline Find More Posts by odam2k
Old Sep 10, 2011, 07:59 AM
dleroi is offline
Find More Posts by dleroi
Don L.
Old Lyme, Connecticut
Joined Feb 2006
Thanks again!
Agree! I considered the Power Panel LCD for a telemetry display I built recently, but decided to go with a bulkier serial device when I found out the Eagle Tree LCD was I2C. Now, I'm going to give it a try.
Thanks, Danal!!!
- Don
Edit: Odam2K, here's the clunky version talking with MK via Bluetooth.
dleroi is offline Find More Posts by dleroi
Old Sep 10, 2011, 08:03 AM
nyc863 is offline
Find More Posts by nyc863
Joined Nov 2008
This is really great.
I wish I'd read it before buying the LCD117 kit which is a serial connected pic controlled back-lit LCD.
http://shop.moderndevice.com/products/20x4lcd-lcd117kit
It is cheap, but serial ports are a scarce commodity in Arduino. 1 on everything except the the mega where you get 4.
To have a cheap widely available outdoor readable LCD via I2C is a really cool.
nyc863 is offline Find More Posts by nyc863
Old Sep 10, 2011, 11:12 AM
Peter Seddon is offline
Find More Posts by Peter Seddon
Solihull, England
Joined Jun 2004
This is an alternative albeit using a serial port. http://cats-whisker.com/web/node/7
Peter
Peter Seddon is offline Find More Posts by Peter Seddon
Old Sep 12, 2011, 02:58 PM
Flys with Thumbs
Frisco, TX, USA
Joined Sep 2001
There's a ton of serial LCDs out there. They all tend to use similar modules.
The Eagle Tree's two big differences are:
  • I2C Interface
  • Daylight Readable
Old Sep 13, 2011, 04:26 PM
odam2k is offline
Team Basement-RC
odam2k's Avatar
Canada, ON, Toronto
Joined Jul 2008
Thanks, Danal!!!
- Don
Can you share your code?
Old Sep 13, 2011, 08:38 PM
dleroi is offline
Don L.
Joined Feb 2006
Yes. FYI, the ground station hardware is the DIY Drones Ardustation kit and the software was adaped from the "AltaStation", here:
http://en.altapix.com/technique/altastation.html
I modified the original AltaStation code to work on the ArduStation hardware. It was mostly related to talking to a different display and monitoring the buttons. My version (at least for now) uses only 2 of the buttons to move through the display screens.
If you're able to program an Arduino, you can customize the code to make it display whatever telemetry data you want.
PM your email address and I'll send you the Arduino code.
- Don
Old Sep 19, 2011, 06:21 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
You can use any digital pin to send data to LCD117 (or any other USART Serial LCD).
Just use the SoftwareSerial Library in Arduino.
Also, it's not too difficult to hack the pic driver chip on these displays.
Here is my hacked firmware for Sparkfun Serial LCD display (sry about reflections...).
If anyones interested, I can post in a new thread....
Mike Barton is offline Find More Posts by Mike Barton
Old May 04, 2014, 10:37 AM
Gerry B is offline
Find More Posts by Gerry B
Gerry B's Avatar
Surrey, BC, Canada
Joined Feb 2007
I know it's been a while but I am interested. Also, do you know if a standard HD44780 LCD display can be used in place of the power panel and what would be the pinout connection to the eagletree logger?
Gerry B is offline Find More Posts by Gerry B
Old May 06, 2014, 11:44 AM
United Kingdom
Joined Nov 2008
not directly, you would need an i2c -> HD44780 LCD 'bridge module' which would translate the i2c cmds/data for the LCD.
connection will be standard i2c, so: 0v, V+, SDA & SCL (exactly what sequence I cannot say but could easily be determined)
HTH
Old May 11, 2014, 02:02 AM
Gerry B is offline
Gerry B's Avatar
Surrey, BC, Canada
Joined Feb 2007
Hi Mike
Thanks for your response. I picked up a I2c shield kit today. I will build/wire it up and let you know how it goes.
Gerry
Old Jun 21, 2014, 01:30 AM
AlexTakt is offline
Find More Posts by AlexTakt
Starting with FPV
New Zealand
Joined Apr 2010
Exactly what I was looking for. Thank you Danal.
To add my 2 cents, I've put it in the library.
Enjoy.
AlexTakt is offline Find More Posts by AlexTakt
Help! Eagle Tree LCD Power Panel protocol? GeorgeP DIY Electronics 176 Dec 04, 2015 04:04 AM
Sold Eagle Tree MicroPower E-Logger With Power Panel LCD Display For Sale!! Super D Aircraft - Electric - Power Systems (FS/W) 1 May 03, 2011 04:00 PM
Sold Eagle Tree MicroPower E-Logger w/ LCD power panel $75 greykat Aircraft - General - Miscellaneous (FS/W) 3 May 23, 2007 11:27 PM
For Sale Eagle Tree MicroPower E-Logger w/ LCD power panel greykat Aircraft - Electric - Power Systems (FS/W) 0 May 21, 2007 03:45 PM
