United States, CA, Cameron Park
Joined Jan 2004
I've got some PMs from people interested in getting laser cut short kits. So here's the deal. I can cut short kits for the 2m & 2.6m Horten XII, the 3.4m Horten XVI, the 4m Horten XIV and and the 1.5m Horten Micro-Elli.
I will also be able to make short kits for my own 4.1m Horten IIIe pretty soon. Here's the link to the IIIe: http://www.rcgroups.com/forums/showthread.php?t=1455941. Just send me a PM if you're interested. Brian p.s. I'll post some links on my rcgroups blog soon. |
Joined Jan 2004
Hey Ken,
I frankly hate the "new" monokote! Anyway, I will not be using an iron on film covering. I will probably be using polyspan. The aft spars and control surface spars will all have .4mm birch plywood shear webs. The front of the control surfaces and the wing openings will be faced with the same. Brian p.s. I'm almost done cutting yours.
Brian,
I am giving thought to using silk and dope like the old days. A translucent wing would be so cool! But I worry how well it would hold up. Maybe something like Sig Koverall. Films don't like to stick to plywood anyway. This is a worry on the SuperHawk I am building (larger, modern version of the HobieHawk) as the wing skins are all ply, but need Monokote to provide torsional rigidity. Ken |
Joined Jan 2004
I've got some Koverall so that's definitely an option. I haven't been completly happy with silkspan. I use some on my Horten XVI and it has proven to be a bit fragil. I've started covering my Horten XIV with polyspan and it seems much more durable at this point.
Brian |
Joined Jan 2004
Update
Well, I finally managed to get a bit of work done. I've tried to note the work in the descriptions.
Brian
Joined Jan 2004
@Ken - Just an FYI...the plane isn't designed to use landing gear. It have been designed to use a bungee launch. However, as with most things it can probably be modified.
I attached a few pictures of the XII showing the gear. Several of the pictures are of a mockup. Enjoy! Brian |
Yardley, PA
Joined Sep 2006
The pics I was able to find show 2 smaller front wheels in the wings and one large rear wheel that carried about 60% of the weight. Front wheels retracted back, the back wheel retracted forward.
I do have a glider retract that should work for the main, a couple of light retracts should work for the front. Steering is going to be.. interesting. |
Those pictures are just what I need! If I can't fit something I will build custom retracts. By the way, what all up weight are you looking at? I tend to do kit bashing. I always have to be a bit different
As my DLG is curing, I am looking at my Windrider BD-J and should I put retracts in it. For the first time in 30 years I have a paved runway available. This has caused me to want a few planes with retracts. The field is actually the old Stone Mountain Airport. (General Lee statue carved into the face http://www.rvforsaleguide.com/images...-picture-2.jpg) They did fly sailplanes out of there. It is 10 miles east of Atlanta. Thanks, Ken |
Joined Jan 2004
@Ken - I don't have a weight on mine yet since I'm not done. We might be able to get Uwe to get us the weight from some of the XII's that have been completed in Germany. I'm thinking that the weight will vary depending on the motor and batter selection.
Brian |
Joined Jan 2004
The motor would generally be something in the E-Flite 15 range with a matching folding prop. I'm planing to use a 950KV Exceed RC Rocket motor from Hobbypartz and ~11 x 6 prop. If you're going to go with retracts then this obviously won't work. You'll have to go with a higher KV motor and a smaller prop.
![]() Brian |
| Thread Tools | |
| Build Log 2M Horten XII | cpdude | Scale Sailplanes | 4 | Jun 22, 2011 08:22 AM |
| For Sale 2 Sig Riser 2 Meter Kits NIB | Mark Miller | Aircraft - Sailplanes (FS/W) | 2 | Jun 10, 2011 04:46 AM |
| Sold Tower Hobbies Vista 2-Meter Sailplane ARF | Cincy E-Flyer | Aircraft - Electric - Airplanes (FS/W) | 7 | Mar 14, 2011 06:30 AM |
| Sold Tower Hobbies Vista 2-Meter Sailplane ARF | Cincy E-Flyer | Aircraft - Sailplanes (FS/W) | 0 | Mar 10, 2011 07:21 PM |
| Sold Discus CS 2.7 Meter | critical-mach | Aircraft - Sailplanes (FS/W) | 7 | Mar 09, 2011 09:12 AM |
