Old Jun 22, 2011, 09:21 AM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Build Log
2 Meter Horten XII
I don't know what I was thinking when I started the build log over in the scale sailplanes section. Anyway, here's the link to that build log. I'm planning to finish the build here.
Brian
cpdude is offline Find More Posts by cpdude
Old Jun 22, 2011, 09:38 AM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
Nice to see a wooden wing in these parts
Robbie d is offline Find More Posts by Robbie d
Old Jun 23, 2011, 03:30 PM
SUNSQUINT is offline
Find More Posts by SUNSQUINT
the lift is always in the sun!
SUNSQUINT's Avatar
USA, AZ, Tucson
Joined Feb 2008
can you please cut and paste the few posts to this thread? Very interested in the build... keep it up!!
SUNSQUINT is offline Find More Posts by SUNSQUINT
Old Jun 23, 2011, 04:15 PM
cpdude is offline
Joined Jan 2004
The first picture [down below] shows the .4mm (1/64") birch ply being formed around a tube. This piece of plywood will be use to form the rear of the cabin right in front of the propeller/spinner. That would be the area to the left in this picture:
It may not show up very well but the second picture below show the spars being glued in place. The spars are made from a "bargin bag" of spruce I got from Aircraft-Spruce down in southern California. I cut them to size on a table saw. This is much cheaper than buying them cut to size.
Next up...more time on the table saw cutting spars.
Brian
p.s. I'll link to the pictures in the other thread below.
Old Jun 23, 2011, 04:19 PM
cpdude is offline
Joined Jan 2004
Pictures from the other thread
Here are the pictures from the other thread...
Old Jun 23, 2011, 05:40 PM
airtimeasto is offline
Find More Posts by airtimeasto
There is only DS
airtimeasto's Avatar
Australia, WA, Baldivis
Joined Aug 2008
looks very cool. Does it need vertical stablizers or is the pod it.
Asto
airtimeasto is offline Find More Posts by airtimeasto
Old Jun 23, 2011, 06:37 PM
cpdude is offline
Joined Jan 2004
@Asto-No verticals. None necessary!
Brian
Old Jun 23, 2011, 11:35 PM
SUNSQUINT's Avatar
USA, AZ, Tucson
Joined Feb 2008
The Hortons were way ahead of their time....
Old Jun 24, 2011, 01:51 AM
Robbie d is offline
Crazy Cessna Owner
Robbie d's Avatar
Joined May 2001
If they weren't powered, I doubt they would have more than just a faired bubble canopy. The pod was just to cover the engine.
Old Jun 25, 2011, 07:12 PM
Tail Saw is offline
Find More Posts by Tail Saw
a wing is enough
Tail Saw's Avatar
Germany
Joined Aug 2010
Hi Brian,
thank you for your great job at drawing the "missing parts" and now I see a great job at building the 2 m Ho XII (as usual from you )
In order to motivate you a bit, look once more at my videos of flying my Ho XII, its the #8 of the first series. I hope you like my jobs on this plane too
Horten XII at Vohenstrauss (5 min 9 sec)
...and with onboard cam:
Gastflug der Horten XII bei den Büchelsbergfliegern (5 min 13 sec)
I´m looking forward to the progress (and waiting for the building log of Robbie´s Horti Micro-Elli)
Regards from Uwe,
("the father" of this versitale flying wing model)
Tail Saw is offline Find More Posts by Tail Saw
Old Jun 25, 2011, 09:15 PM
cpdude is offline
Joined Jan 2004
I love it! The videos are definitely motivational. My XII is coming together very nicely! This is going to be a great plane.
About the missing parts. You're very welcome! I definitely hope that they work out well for you.
Brian
Old Jun 27, 2011, 12:54 AM
cpdude is offline
Joined Jan 2004
Okay I managed to spend some time in the shop today.
I got some work done on the back of the cabin. I like like how it came out but I did manage to tear up some of the skin. The .4mm plywood is really thin!
I also got most of the spars cut and glued in place. The top spars on the left wing are now sanded to shape. I honestly had forgotten how much fun it is to sand the aft spars. Not!
Anyway, here are the pictures...
Old Jul 03, 2011, 02:10 AM
cpdude is offline
Joined Jan 2004
A little bit more progress
Well I've made a bit more progress on the XII. I've got a good portion of the top of the left wing panel skinned. I've also got the main and front shear webs glued in place. I'm very happy with how the laser cut shear webs fit!
What have I learned so far. One thing is that I made the face of the sub-leading edge a bit too short. I've corrected the drawings so that the face now extends about ~42mm past the last rib and blends into the tip.
I'm also concerned that I may have removed too much material from the control surfaces. It's obviously very important that they are as ridged as possible to avoid flutter. My plan at this point is to add some carbon fiber to the trailing edge.
Brian
Old Jul 05, 2011, 01:01 AM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
are you only cutting these for yourself or will you be selling the laser cut parts+plans?
This 2M one interests me the most, as it would be easier for me to store and haul something that size.
jonquinn is offline Find More Posts by jonquinn
Old Jul 05, 2011, 01:16 AM
cpdude is offline
Joined Jan 2004
@jonquinn-I'm sure that we could work something out. I'll send you a PM with my contact information.
If you're looking for something small the Micro-Elli may also be an option? Rob has a build log going here. There is also a thread on rc-network.de.
Brian
Build Log 2M Horten XII cpdude Scale Sailplanes 4 Jun 22, 2011 09:22 AM
For Sale 2 Sig Riser 2 Meter Kits NIB Mark Miller Aircraft - Sailplanes (FS/W) 2 Jun 10, 2011 05:46 AM
Sold Tower Hobbies Vista 2-Meter Sailplane ARF Cincy E-Flyer Aircraft - Electric - Airplanes (FS/W) 7 Mar 14, 2011 07:30 AM
Sold Tower Hobbies Vista 2-Meter Sailplane ARF Cincy E-Flyer Aircraft - Sailplanes (FS/W) 0 Mar 10, 2011 08:21 PM
Sold Discus CS 2.7 Meter critical-mach Aircraft - Sailplanes (FS/W) 7 Mar 09, 2011 10:12 AM
