Old Nov 07, 2011, 11:26 PM
WickedFunRC is offline
Find More Posts by WickedFunRC
WickedFunRC's Avatar
Utah USA
Joined Jun 2002
georgerm, I'm glad you were able to get the wings fit up right. The Yak is a whole lot different than a small flat profile plane for sure. I think they're both fun in their own way. It's nice to have some of both styles to keep things interesting.
WickedFunRC is offline Find More Posts by WickedFunRC
Site Sponsor
Latest blog entry: Latest Video's
Old Nov 08, 2011, 09:24 PM
georgerm is offline
Find More Posts by georgerm
USA, OH, Columbus
Joined Oct 2010
ya completely different thats for sure. havnt had anymore time to fly it tho with school during the week.
georgerm is offline Find More Posts by georgerm
Old Nov 15, 2011, 01:00 PM
Schrottflyer is offline
Find More Posts by Schrottflyer
Deutschland, BY, Augsburg
Joined Nov 2010
IŽll got mine yesterday It looks like MUCH FUN
Schrottflyer is offline Find More Posts by Schrottflyer
Old Nov 16, 2011, 08:19 PM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
Finally got mine put together and flown today. I went with all cheapie mg servos and a BPHobbies 2207? 950kv with a 10x4.7sf at the moment. I really need to try an 11 incher because it not very snappy at all right now. It'll hover it but with little to no pullout. Will probably wind up with my Park 480 on it eventually. I'm using Gens Ace 1500s and never even checked the balance but it feels pretty close. Was much too windy to really be able to dial it in properly but I like the way it flies. No sign of any bad habits which gives me confidence to fly it much too low for my skill level. LOL By far the easiest kit I've put together. I love the servo arm extensions but don't like the non swiveling push rod connectors. Went with Dubro stuff there. I used Stick and Seal glue for the first time on this plane and I really like it.
krexken is offline Find More Posts by krexken
Old Nov 17, 2011, 01:24 AM
Utah USA
Joined Jun 2002
Assembly doesn't get much easier for sure. I've used Stik 'n Seal on quite a few EPP planes and it's held up great. I use Welder more now days, but mostly because it's easier for me to apply with the thinner density and long applicator tip. Definitely try an 11x5.5E or a rigid 11x4.7SF prop on the 2217 950kv motor. That should be a nice improvement.
Site Sponsor
Old Nov 17, 2011, 01:32 PM
pullup! is online now
Find More Posts by pullup!
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Went with HK 13g digital servos, and at first a 100 gram out runner pushing 230 watts spinning a 12x6 with a 30 amp esc and 1800 Nanotech 25-50c Turnigy batteries. The Yak flew fine, but being at altitude it would hover. When I would try and punch out It would climb another foot and that was it.
So swapped out the out runner and ESC. Now running a Gforce G10 3715-1100 kv out runner and a 50 amp ESC. 460 watts pulling 37 amps spinning a 12x3.8
RTF weight is 31.5 ounces, and I'm getting 4.5 minute flights with 11.40 volts left in the Nanotechs upon landing.
Fun plane!
pullup! is online now Find More Posts by pullup!
Old Nov 18, 2011, 05:40 PM
mixerfix is offline
Find More Posts by mixerfix
Joined Mar 2010
Chilink :-) (Chinese Teink)
Hi,
I bought mine built (i.e. secondhand) and built not so very well. After two or three flights, did the following:
1. Removed the drek ESC and replaced with Castle Thunderbird 54
2. Removed the HXT900 servos from the ailerons and replaced with Savox 0257
3. Removed the RCtimer 3536 motor and replaced with Turnigy SK 3542-1000
4. Removed the battery from behind the motor to above the port wing
5. Closed the battery bay with a block of fitted EPO
6. Gorilla-glued the bits in place
7. Strengthened the landing gear
The plane flies like that mouse (from Hoodwinked) on coffee, using an APC 12x6 or E-Flite 12x6SF props
mixerfix is offline Find More Posts by mixerfix
Old Nov 19, 2011, 11:32 AM
Joined Nov 2010
Today i build it, the dusty Weather is so bad i cant maiden so i must hoover in Livingroom
Old Nov 19, 2011, 02:58 PM
helicow is online now
Find More Posts by helicow
Gravity gets me down.
helicow's Avatar
USA, FL, Brooksville
Kevin, any thoughts of carrying the 2217 950kv motor? I think the lower kv is better for 3D, at least that has been my experience, plus, I do not think it has an issue with the 11 inch prop.
Bob
helicow is online now Find More Posts by helicow
Old Nov 19, 2011, 09:26 PM
danstah is offline
Find More Posts by danstah
United States, AZ, Yuma
Joined Jun 2007
Here's a picture of my Yak. Got an Exceed RC Optima 480 3010-1020KV on it. It flies heavy but handles just fine with some speed. It flies great @ night
danstah is offline Find More Posts by danstah
Old Nov 19, 2011, 11:48 PM
Utah USA
Joined Jun 2002
Bob
I have thought about picking up the 2217 950kv. I will bring them in soon. I'm going to build my next plane of this size (SU-31) with the 2217 1100kv. It should come in at closer to 22-23oz and be a real floater, so something in the 950kv - 1100kv would give me nice thrust with decent flight times on a 1050mAh - 1350mAh battery.
Site Sponsor
Old Nov 19, 2011, 11:51 PM
Utah USA
Joined Jun 2002
Nice, I need to hook up some lights.. Though I won't be in a tee shirt when I fly it (coldddd). I need to move to AZ.
Site Sponsor
Old Nov 19, 2011, 11:55 PM
RickC2009 is offline
Find More Posts by RickC2009
RickC2009's Avatar
USA, NY, Brookhaven
Joined Mar 2003
Cool lights!
Where did you get them from?
rickc
RickC2009 is offline Find More Posts by RickC2009
Old Nov 20, 2011, 12:13 AM
danstah is offline
Joined Jun 2007
Cool lights!
rickc
DWFoamies
Old Nov 21, 2011, 01:39 AM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Got mine in the air for the first time today.
Powered with KDA 22-20L from HK, http://www.hobbyking.com/hobbyking/s...r%5FMotor.html
Plus MG14's all around and 3s1300mA Lipos on 30A Plush ESC.
What can I say about this plane, I put 6 packs through today and every flight just feels more comfortable and easy to fly.
I did notice that the 130mm CG they recomend is damn hard to achieve so I just left it.
I have a hell of a belly pitch on knife edge which is usually from CG being too aft, but I'm going to drop down to a slightly lighter and more powerfull motor and see how things balance out after that.
One thing I wanted to check, did any of you guys add some right and down thrust by putting washers behind the motor mount for this plane?
bigroger is offline Find More Posts by bigroger
Discussion Fancy foam EPP Edge 540 or Yak 55. Please help me decide ! DaN_Th3_MaN 3D Foamies 13 Aug 07, 2012 10:12 AM
Discussion - PYRC Yak 55 - 34" - 9mm EPP - FREE Plans - PinkYakRC Foamies (Scratchbuilt) 18 Aug 02, 2011 02:56 PM
Alert For sale - EPP Yak-55 - $25 rpstar Atlanta Area RC 7 May 26, 2011 01:28 PM
