Old Nov 29, 2011, 10:10 PM
epphobby is offline
Find More Posts by epphobby
epphobby's Avatar
United States, PA
Joined Aug 2011
Originally Posted by khen View Post
Yup, the thinner air at higher altitudes requires a bit more prop to get the same power. I ordered some Techone SUs for the site and set one aside for myself . It's critical that I demo all the planes I sell Or so I tell the wife.. but she doesn't buy it, hehe.. I've thought about bringing in a Telink for comparison, though the SUs look/spec different.
, my wife just doesn't buy it either
epphobby is offline Find More Posts by epphobby
Site Sponsor
Old Dec 14, 2011, 10:37 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Originally Posted by bigroger View Post
Yes, I'm at sea level inland Aus.
Does that make a difference?
I've ordered some 11x5.5 e props to try out plus I have an Omega 72g motor on order to test.
Khen, is the SU you refer to the Telink one or the Techone one?
Did you ever test that omega motor in this plane?
3drcparts is offline Find More Posts by 3drcparts
Old Dec 15, 2011, 01:22 AM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Yes I did test it out.
Using a ACP 11x4.7 it pulled like a beast.
Measured 430W and 39 amps wot on the watt meter.
Flying was strange, felt balanced in hand but flew really nose heavy.
Almost like the SF prop was too small for the motor.
I have some 11x5.5e props to try out at some stage, I've gone back to my smaller motor for this plane that is a 2834-1100kv baby. Swing the same 11x4.7 sf prop no problems.
The Omega has heaps of power but I noticed my 1300Ma Lipo that was giving me 6.5 min previously struggled to give me 5 minutes on the Omega motor and 11x4.7 prop. So I deduced its pulling more amps, definitely making more power but shortening my flying time and did seem to make it nose heavy.
bigroger is offline Find More Posts by bigroger
Old Dec 15, 2011, 09:30 AM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
interesting, what brand is the 2834-1100, I have the omega 72g in the parts bin, but also have this coming, http://epbuddy.com/index.php?main_pa...roducts_id=271
Motors are so confusing to me
Old Dec 15, 2011, 08:58 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
The smaller motor is from BestvalueRC, http://www.bestvaluerc.com/shop/shopexd.asp?id=332 it whips a 11x4.7sf without too much issue and really hurls the Yak pretty good without being crazy and its light to boot. I get about 6 minutes of 3D flying out of 1300Ma lipos and thats lots of hovering and harriers and some KE and spins etc to mix things up.
The Omega just didn't feel right to me with the SF prop and it sounded funny and chewed up the amps pretty quick as well.
Old Dec 16, 2011, 10:30 AM
Schrottflyer is online now
Find More Posts by Schrottflyer
Deutschland, BY, Augsburg
Joined Nov 2010
Today il get my new Motor, and new Servos the Plasteservos broken and il buy the Coronas hope it flys better with it. After the Windy Day i will fly it.
http://www.hobbyking.com/hobbyking/s...dProduct=14736
http://www.hobbyking.com/hobbyking/s...dProduct=10346
With this Setup the Yak must go 3d
Schrottflyer is online now Find More Posts by Schrottflyer
Old Dec 17, 2011, 11:21 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
The only two things I'd say is that that motor Schottflyer is very heavy for this plane. If you are trying to get to neutral cg you most likely will need tail weight.
Forget the Corona servos, go straight to MG14's. I use them on all my large foamies and they are great.
For the motor you could try this one:
http://www.hobbyking.com/hobbyking/s...dProduct=17600
And the MG14:
http://www.hobbyking.com/hobbyking/s...idProduct=8303
Old Dec 18, 2011, 12:00 AM
Joined Nov 2010
Hi Bigroger,
can u say me where the neutral cg is, il not found one in the Build.
I think must fly with it and look where it realy is.
Your Motor looks really better It has more Watt and its 18gr lighter.
Hope the Coronas looks better as the HK Servos there broken at second flyt.
Must learn handle it and hope it flys till next Year, so its my Nick hehe
Old Dec 18, 2011, 12:54 AM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
The cg is about 140mm back from the leading edge of wing. I have tried the Coronas and really found them terrible at finding centre and they would oscillate around neutral.
This plane is quite heavy as is, max out the throws on all surfaces and it 3D's pretty well, harrier, hover and aerobatics etc.
If you get the 1250kg 2834 motor your max prop will be 11x3.8sf, anything bigger will overheat a motor that size in that kV rating.
I'm running a 2834-1100kV on mine with 11x4.7sf and it still gets hot after a few hard packs of flying. I'm only using 1300mA Lipos in mine to keep the weight down and I get around 6-6.5 minutes.
Old Dec 18, 2011, 02:37 AM
Joined Nov 2010
Thanks Bigroger,
il must look the cg, and its not so windy today, il can get fly the Yak.
When i came back with the hole Flyer and anbroken, i can post my Experience from this Flyt. Thanks for your Effort. Thumps to push.
Old Dec 18, 2011, 10:22 AM
Joined Nov 2010
Its going 2 Batts with the Yak, after here is havy Snowfall and i cant see it.
But she flys very well the Motor is going good and she hoover and than goes vertical never Ending
The Servos is not the best ( Bigroger u sayd it thanks ) but theres better than the last HK Plaste.
Il get my Yak back in total off, and my Smile in Face was really great. Ill drink a Cup off Tea and hope the Weather goes better. I WILL FLY YAK55
Old Dec 18, 2011, 07:11 PM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
I recently triked my 920kv Park 480 on mine with a 11x3.8sf and was'nt real impressed with the power. It was better than my 950kv 2217 but not by a lot. Plane didn't mind the extra weight to me and still felt neutral to tail heavy. Not a lot of pullout from a hover but some. Wound up bending the 480's motor shaft on an unscheduled landing and managed to bust the motor mount. Time for surgery and hunt for another motor. Probably use my tried and true 3536 1100kv just to overpower this thing for a change. I haven't weighed my plane yet but for some reason it sure seems heavy.
I've got a couple Corona mg servos on this plane and I don't particularly like them due to excessive gear slop. MG14s are much better.
krexken is offline Find More Posts by krexken
Old Dec 18, 2011, 11:54 PM
Joined Nov 2010
Il cut out the Wooden Motor Mount , and bild it by myself from 4mm Aluminium.
You can get it from DIY Store for Cent, and its strong enough for Headlanding.
Il must make this its my Nickname Schrottflyer
Old Dec 19, 2011, 03:41 AM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Watch out for too much nose weight in this plane.
It does like to be balanced if not a little tail heavy.
Maybe try some 3-5 layer plywood if you can get it, its easier to fabricate and will be lighter than Al.
Perhaps a light coat in thin CA before install will help.
Old Dec 19, 2011, 11:28 AM
Joined Nov 2010
Im just weighed my Al Motormount and that bring 6,4 gr at the Scale, dont now how many the Wooden Mont weighs.Il think its not to havy for my Flytstile.
Discussion Fancy foam EPP Edge 540 or Yak 55. Please help me decide ! DaN_Th3_MaN 3D Foamies 13 Aug 07, 2012 09:12 AM
Discussion - PYRC Yak 55 - 34" - 9mm EPP - FREE Plans - PinkYakRC Foamies (Scratchbuilt) 18 Aug 02, 2011 01:56 PM
Alert For sale - EPP Yak-55 - $25 rpstar Atlanta Area RC 7 May 26, 2011 12:28 PM
