Old Jun 22, 2011, 08:25 AM
alouette is offline
Find More Posts by alouette
alouette's Avatar
South Africa
Joined Jun 2009
HK Yak 55 EPP 1096mm
Anyone got one of these yet? I ordered one last night, so will put up some pics and info when I get it.
alouette is offline Find More Posts by alouette
Old Jun 22, 2011, 04:57 PM
WickedFunRC is offline
Find More Posts by WickedFunRC
WickedFunRC's Avatar
Utah USA
Joined Jun 2002
I have one on the way.
I'm thinking of carrying these on my site (the TechOne brand) but wanted to give one a try first.. I ordered it last week EMS but they are just barely getting it shipped.
WickedFunRC is offline Find More Posts by WickedFunRC
Site Sponsor
Latest blog entry: Latest Video's
Old Jun 22, 2011, 07:01 PM
2006rfarmer is offline
Find More Posts by 2006rfarmer
United States, CA, Temecula
Joined May 2006
I had the the smallar version (techone ) it came out extremely tail heavy, by the time I got the CG in the ballpark the plane was overwieght and flew like a brick! But on the good side some had no problems with there kit. seem's there might be an inconstancy in the foams wieght and density. Let us know how it comes out for you.
2006rfarmer is offline Find More Posts by 2006rfarmer
Old Jun 22, 2011, 07:14 PM
Utah USA
Joined Jun 2002
I've read others that have had the same problem with the smaller version. Did you mount the servos at the tail as per the design or move them closer to the COG and use push rods?
Site Sponsor
Old Jun 22, 2011, 08:30 PM
maxbee is offline
Find More Posts by maxbee
United States, TX, Houston
Joined Feb 2011
I have the same tail heavy issue. I think I am going to mount the servos as far forward without getting in the way of the alierons. Maybe also use some standoffs to keep things from flexing.(Graphite)
maxbee is offline Find More Posts by maxbee
Old Jun 22, 2011, 10:35 PM
Joined May 2006
I ended up moving the servo's forward up close to the CG ,it was still tail heavy! I even hollwed out the fuse. from the main wing to the tail feathers trying to releave the tail heavy condition and get the plane UAW down. It's still 70-80g over max,still fly's like a brick and this is not my first barbecue. I've had other techone planes that were all good but no luck with that one.
Old Jun 22, 2011, 11:51 PM
Utah USA
Joined Jun 2002
Wow, sounds like you tried it all, sorry you couldn't get it dialed in. After reading similiar feedback I decided to pass on the smaller Yak. I hope they have this worked out on the larger one and some of the other designs they have in the works.
Site Sponsor
Old Jun 28, 2011, 01:44 AM
Utah USA
Joined Jun 2002
I got my 1096mm Yak in today and slammed it together. Pretty quick building plane. I put in a Turnigy 2217 motor and it was under power. I got in a few flights before elevator servo gear striped when I did an abrupt snap roll. I'm using the recommended 10g digital plastic gear servo's and I'm afraid they are to weak for this size/weight of plane. I'm going to put in some heftier metal gear servo's and a more powerful Suppo motor and give it a go within the next couple of days.
Overall I like how it flies, nice harriers, harrier rolls and spins I didn't get to do to much knife edge. The CG balanced out fine with my 1300mah 3S Blue Lipo as well as my lighter weight 1300mah 3S Electric Power packs.
Site Sponsor
Old Jun 28, 2011, 04:57 AM
alouette is offline
alouette's Avatar
South Africa
Joined Jun 2009
Mine has been shipped. Planning on trying it out first with a C3530 1400Kv, got 2 mini MG servos and a handful of those digitals. Think I might put MG's on the tail and those digitals on the wings.
Also an 1800mah 3S, might later modify for 2200mah.
Old Jun 28, 2011, 05:44 AM
Eagleburger is offline
Find More Posts by Eagleburger
Electric Hippy
Brisbane
Joined Nov 2005
Use the hxt900's. Their gears are as good as hs65hb gears. I have had them on 49" wood planes that got thrashed about on 400Watts for years without problems. A MG servo on rudder is a good idea though.
Eagleburger is offline Find More Posts by Eagleburger
Old Jun 29, 2011, 07:54 PM
Slammm is offline
Find More Posts by Slammm
WoooHooo!!!
Slammm's Avatar
USA, CA, Santa Paula
Joined Mar 2007
Got one on the way, ordered 6/14, "held by customs at destination" 6/29
Also ordered the Donkey ST3007-1100kv Brushless Motor but I have an EFlight 480 that I think I'll try instead. Also ordered the "recommended" orange servos (but it sounds like they won't last) and three Turnigy nano-tech 1800mah 3S 25~50C Lipo Packs
Thanks for the tips about it being tail heavy and servos.
Can't wait, I must hit the site 20 times a day for the status.
Departed from Destination Transit Center
Slammm is offline Find More Posts by Slammm
Old Jun 29, 2011, 10:35 PM
Utah USA
Joined Jun 2002
I put some 939 metal gear servos in the tail. I had a chance to get one pack in this morning in 30-40 mph winds . It actually handles wind relatively well. Wish it would calm down though, I want to get some video footage.
Site Sponsor
Old Jul 01, 2011, 08:17 PM
Slammm is offline
WoooHooo!!!
Slammm's Avatar
Joined Mar 2007
Got it!
Received my Yak today and so far it looks great. About all there is to do is glue the tail feathers on and install the electronics.
One issue is the fuse is cupped. This is my second EPP foamy and the first (MS Composit Pitts) had the same problem. Wondering if this is an inherent problem with EPP foamies or is it just a fluke. Anyone know a good method to straighten it out? In the picture I have a straight edge touching nose and tail, there is at least 1/8" gap in the center. Don't want it fly like a dog chasing it's tail.
Old Jul 01, 2011, 08:48 PM
Utah USA
Joined Jun 2002
Normally with EPP you can just sit it on it's side on a flat surface and put a little weight on it and let it sit for a night. With the carbon fiber already glued in though I'm not sure if that would work.
Site Sponsor
Old Jul 01, 2011, 08:59 PM
Slammm is offline
WoooHooo!!!
Slammm's Avatar
Joined Mar 2007
The wing box won't let it lay flat so I'll do the best I can with straight edges and clamps. Don't want to run it down because so far I'm really happy with it, just want it to fly straight.
Discussion Fancy foam EPP Edge 540 or Yak 55. Please help me decide ! DaN_Th3_MaN 3D Foamies 13 Aug 07, 2012 10:12 AM
Discussion - PYRC Yak 55 - 34" - 9mm EPP - FREE Plans - PinkYakRC Foamies (Scratchbuilt) 18 Aug 02, 2011 02:56 PM
Alert For sale - EPP Yak-55 - $25 rpstar Atlanta Area RC 7 May 26, 2011 01:28 PM
