Old Jun 21, 2011, 09:51 PM
JKEP44 is offline
Find More Posts by JKEP44
United States, KS, Junction City
Joined Aug 2008
Need a .25 size high wing tail dragger, ideas?
Hi everybody, I am looking for a .25 size high wing tail dragger arf. The problem is I can only find tricycle set ups. Does anybody know where I can buy one from or have any suggestions? It has to be an arf, I currently don't have time to build a kit.
JKEP44 is offline Find More Posts by JKEP44
Old Jun 21, 2011, 10:08 PM
Majortomski is offline
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
Sig Kadet LT 25
Majortomski is offline Find More Posts by Majortomski
Old Jun 22, 2011, 12:39 PM
gluemaster is offline
Find More Posts by gluemaster
Cub-O-Holic
gluemaster's Avatar
Deltona, FL
Joined Dec 2006
Hobbico Superstar EP converted to glow? Like this one:
gluemaster is offline Find More Posts by gluemaster
Old Jun 22, 2011, 01:47 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You can leave the nose gear off and move the rear landing gear forward. You determine where you want the gear to be at and cut out the balsa and glue in a plywood mount for the landing gear. Then glue in some triangle stock on the inside of the fuse to help reinforce it. The drill the holes and mount the landing gear.
A good location is about in line with the leading edge of the wing or slightly back.
earlwb is offline Find More Posts by earlwb
Old Jun 22, 2011, 04:39 PM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
That's what I'd do. Not a very difficult mod. you could really just cut out the existing block, notch the fuse further up to accomodate the gear, epoxy it in with some reinforcement and patch the hole that it leaves where it was originally located. With the proper tools and a couple small pieces of covering it could be done in under an hour, minus time for the glue to dry.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Jun 24, 2011, 03:00 AM
JKEP44 is offline
Joined Aug 2008
Thanks guys, that should be easy enough. Doing that opens up a lot of options.
Old Jun 25, 2011, 09:58 AM
jbrracer is offline
Find More Posts by jbrracer
foam gone wild!
United States, IN, Roanoke
Joined Apr 2011
earl and chill have the right idea one thing thats nice about that is you can re thing the landing gear ie lower, higher, wheels, wheel pants, CF, you name it.
-JB
jbrracer is offline Find More Posts by jbrracer
Found High wing tail dragger arf Ice Aircraft - Fuel - Airplanes (FS/W) 1 Apr 13, 2010 02:55 PM
Help! Recommendation on 40 size tail dragger kit or ARF hutchis Beginner Training Area (Fuel) 4 Aug 02, 2009 06:30 PM
Discussion Looking for a 20-25 size high wing ARF with wide cowl DaveInLA Fuel Plane Talk 2 Sep 21, 2007 04:59 PM
