Old Aug 28, 2003, 08:15 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
HELP me choose an airfoil design
Which is the better wing design? The top one which just cuts the rear 1 1/2" of the wing for an aileron but which leaves a sizable gap or the bottom one which just adds a flat 1 1/2" of foam to the rear edge for an aileron?
hoppy is offline Find More Posts by hoppy
Old Aug 28, 2003, 10:33 AM
DEPENDS is offline
Find More Posts by DEPENDS
Idaho
Joined May 2002
hoppy,
We might need a little more information to make a semi-educated guess. Is the wing straight or tapered? Strip or inset ailerons? Are you attempting a scale or semi-scale plane, or is it a one-off design? How much time do you want to spend building ailerons? I doubt that the answer is going to be black or white. As always, it's a collection of compromises.
JT
DEPENDS is offline Find More Posts by DEPENDS
Old Aug 28, 2003, 10:55 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Ok - It's a solid foam wing, straight, 8" chord, 30" length. It's for the HOOT, a KAOS takeoff. I don't want to spend a lot of building time on any one aspect. The plane is aerobatic, flies at medium speeds and weighs about 14oz. This one was made with the sheet foam ailerons.
hoppy
Old Aug 28, 2003, 11:57 AM
DEPENDS is offline
Idaho
Joined May 2002
Nice looking foamy. Because it isn't trying to look scale, I would go with the strip aileron. It's easier to build, easier to hinge, (packing tape) and is going to provide as much control as the tapered aileron. Every once in a while, we build for looks as well as flying, and that's when the tapered aileron is considered. Go with the flat strip. FWIW, I haven't had much success with foam ailerons. I prefer 1/8" balsa. Doesn't warp as badly as foam.
JT
Old Aug 28, 2003, 09:00 PM
Daveairway is offline
Find More Posts by Daveairway
Santa Rosa, Northern CA, USA
Joined Oct 1999
Re: HELP me choose an airfoil design
Hoppy,
How about this and use Tape on the top to hinge. You can also fold the aileron over and tape the bottom of the V.
Daveairway is offline Find More Posts by Daveairway
Old Aug 28, 2003, 09:27 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
thanks guys -
that'll work dave.
hoppy
Help me choose an X-mas present EddieNewYork Micro Helis 13 Dec 08, 2005 05:31 PM
Help me choose an ESC for my ZAP 400 Allign or Castle? Leif Mini Helis 3 Nov 18, 2005 10:20 AM
Question Please help me choose an outrunner for my BT Corona. brian.pedersen Electric Heli Talk 14 Oct 28, 2005 12:47 PM
Help me choose please! rpsmtihii Parkflyers 10 Oct 13, 2001 11:57 AM
How do you choose an airfoil? DeaninMilwaukee Power Systems 9 Jul 05, 2001 02:26 AM
