Old Nov 26, 2011, 03:46 PM
kauaicuda is offline
Find More Posts by kauaicuda
kauaicuda's Avatar
United States, MD, Frederick
Joined Aug 2010
This afternoon I installed and used the pocket AVR from Sparkfun. Installing the drivers was a real pain, but it works and I would recommend it. $20 shipped from Colorado.
I just flashed a black board and a red KK+ with it.
Thanks LazyZero!
kauaicuda is offline Find More Posts by kauaicuda
Old Nov 26, 2011, 03:47 PM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
Ok thanks. I'll look that one up.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Nov 26, 2011, 04:25 PM
panos2408 is online now
Find More Posts by panos2408
DXL Team Pilot FuriusP
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
The one you linked s the one i use myslef. It's been great so far.
panos2408 is online now Find More Posts by panos2408
Old Nov 26, 2011, 05:17 PM
Joined Feb 2004
I'm not sure what was the issue with mine pano. I could not get either my laptop or my desktop to recognise it. I sent it to my son. I'm sure he'll be able to get it to work.
In the meantime I ordered a cable for the one I have that works.
Old Nov 26, 2011, 07:02 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Well you are not the first one nor the last to have problems with these i guess. Either you are unlucky or i am lucky
Old Nov 27, 2011, 10:34 PM
tkoguy is offline
Find More Posts by tkoguy
R/C CRASHER
tkoguy's Avatar
United States, CA, Corona
Joined Dec 2004
newbie here, is this board (KKMulticontroller V5.5 Controller Board V2.2 from goodluckbuy) the same as (HobbyKing Quadcopter Control Board V2) if not which is better?
tkoguy is offline Find More Posts by tkoguy
Old Nov 27, 2011, 10:52 PM
Joined Feb 2004
My own research (I have both boards, both set up pretty much the same) tells me that the 5.5 board may actually be a bit smoother. But it could also just be that since I'm running 1000kv motors on one and 850s on the other that it could be a motor issue.
I do have another 5.5 that I just recently got and reflashed to X mode so I plan to switch it out and see for myself. The HK KK board is set to less than 50% on roll and pitch pots to get it to quit wobbling.
I will swap it out for the 5.5 which has the pots in their stock setting. If I get this done in the next day or so I will let you know.
Old Nov 27, 2011, 11:09 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
I believe they are the same. They use same gyros and same firmwares. They are both using an Atmega168. Goodluckbuy seems a bit nicer and comes cheaper since there is free shipping and you can buy it along with the usbasp for 33 USD. I have the one from goodluckbuy as a starting point. Flies good. Nice FC for the casual multicopter that you don't respect
Old Nov 27, 2011, 11:12 PM
Joined Feb 2004
The one I have that works was a pain at first. It took a couple of days to get it sorted out. But at least it works.
Old Nov 27, 2011, 11:15 PM
tkoguy is offline
R/C CRASHER
tkoguy's Avatar
Joined Dec 2004
Thanks guys the one from goodlucky seems like a better deal with the usb cable and free shipping.
Old Nov 27, 2011, 11:19 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
By the way i had some problems with the 4.7 firmware on this board. Motor no.4 wasn't spinning properly. I am currently flying with 4.5 since the rest of the FW weren't compatible with my ESC's. I tried everything so if you ever get problems with FW's try the 4.5 most propably you won't go wrong with it.
You might consider buying the distribution board as well for currents less than 20A. It is a nice deal for 2 bucks.
Old Nov 28, 2011, 07:24 AM
Windman is offline
Find More Posts by Windman
Sverige, Uppsala Län, Uppsala
Joined Mar 2011
Have you read my post?
http://www.rcgroups.com/forums/showp...&postcount=617
Windman is offline Find More Posts by Windman
Old Nov 28, 2011, 10:15 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Yeah i read that somewhere before and tried it.... Was it your idea? You owe me a prop if it was hahahahaha.
Old Nov 28, 2011, 02:52 PM
Windman is offline
Joined Mar 2011
Yes, that was my idea!
Did you take of fast or very slowly?
If I take of veeeery slowly, 4th motor side will not lift, and probably make the quad flip over (never tried).
When completely airborne, it behaves normal.
So give it a controlled quick lift without hesitation...
If you ever come to Sweden, there is a free prop waiting for you!
Btw. When you have about 30% throttle and you feel that motor 4 is not rising RPM as the other motors.
Will moving the quad (making the gyros compensate) change the motor 4 RPM? (That works for me)
You may have to disconnect the other 3 motors to hear the RPM from the motor sound
Old Nov 28, 2011, 04:10 PM
Kaptenklister is offline
Find More Posts by Kaptenklister
Sverige, Örebro Län, Hallsberg
Joined Oct 2011
I need some help, I installed this FW on my HK V2 board, now when I plug it in the esc:s play their usuall short series of beeps (turnigy plush 25) after that they all continue to beep constantly around 2-3 beeps per second.
The led light up when I move throttle to bottom right and it goes out when I move throttle to bottom left.
Any help is appreciated
Kaptenklister is offline Find More Posts by Kaptenklister
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 06, 2011 12:34 AM
Cool KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Hot Online Deals 0 May 26, 2011 01:28 AM
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 0 May 22, 2011 10:14 PM
Sold Quadcopter KK Multicopter RR or RTF w/Turnigy 9X -- Trades welcome KKUSA Aircraft - Electric - Helis (FS/W) 12 Mar 04, 2011 05:29 PM
For Sale SOLD, THANKS - COMPLETE KK QUAD RTF Kapteinkuk multicopter for sale bob.titus FPV Equipment (FS/W) 0 Nov 12, 2010 08:23 AM
