Espritmodel.com Heli Air
Old Nov 22, 2011, 11:36 PM
slim1357's Avatar
United States, OR, Portland
Joined Dec 2010
I've had the slow motor problem as well and dealt with it the same way most of you have. One issue that keeps popping up on my mini quad is that after a few minutes of flying, the quad develops a serious drift to port. I can immediately fix it by landing, bringing the motors to a stop and then taking off again. I do not disarm the board during this procedure. Does this sound like a hardware issue? anybody else get a similar thing happening?
As far as programmers go, I got the pocket avr from sparkfun, it came with the right kind of cable and has worked flawlessly.
slim1357 is offline Find More Posts by slim1357
Old Nov 22, 2011, 11:46 PM
BlackCat_'s Avatar
United States, WI, Wausau
Joined Sep 2011
Drift after flying for a few minutes seems to be normal. It seems to be worse if you don't let the board "aclimate" to the temperature outside before flying since the gyros are temp sensitive.
BlackCat_ is offline Find More Posts by BlackCat_
Old Nov 23, 2011, 12:42 AM
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Originally Posted by erazotropa View Post
Here M48 and M328
For scalestick Aileron 5 / Pitch 5 and Yaw 4
Can you also compile with scalestick 4 for all axes? That is what I added as "acro" to the flashtool.
Thanks Christian
LazyZero is online now Find More Posts by LazyZero
Old Nov 23, 2011, 01:42 PM
Sent from my kk board
Italy, Lombardia, Milan
Joined Sep 2011
1st try - 1st crash
Originally Posted by rernewe View Post
If you take off by accelerating quickly (still being careful of course) the effects of the slow motor seem to be minimal. It only seems to be an issue if you start very slowly, for me if i go to 1/4 stick fast (it's then light on the skids) all 4 motors seem to be ok, i can then proceed normally with no more slow motor effect. I don't know why it works but if i try a slow start i will then need to disconnect the battery, then re-connect and do the faster start to get rid of the symptoms. ......hope this helps.
I tried the quad today, trying to take off really slow to set the trims,
After i broke the number 4 prop and replaced it, i tried your way ( max trim on pitch fwd , aileron and rudder full left) .
At 1/3 throttle the quad was 3 meters in the air, but im new to quad ( used to nitro planes) i paniced and choped the throtle, and now i need a new frame
Its milan Vs barcelona tonight so the new frame will wait for tomorrow morning
urban pilot is offline Find More Posts by urban pilot
Old Nov 23, 2011, 02:57 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Originally Posted by Sympster View Post
I can confirm the lastest ones they are selling works fine on the HK V1 board, just flashed two of them. It is distinctive because it doesn't have the 10 to 6 cable adapter, it has a 6 to 6 adapter. I mean to say the programmer only has 6 pins. You can see in thier picture. Notice only 3 leads on each side of the board. There may be others that have that 6 pin header, I just haven't seen them. Works fine with www.fischl.de USBasp drivers. Can't guarantee which one they will send you, as when my friend recently ordered it they sent him the one pictured and the old one with the 10 to 6 wired adapter and the old one didn't work.
That's the one i have as well. It does the flash without any probs.
panos2408 is offline Find More Posts by panos2408
Old Nov 23, 2011, 03:31 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
I have had same behavior on 4th motor. My problem is that it takes a lot more than half throttle to get it to spin. I programmed an "idle" switch which by flipping it starts all the motors at 30/100. Motor still not spinning even after disconnecting and reconnecting the battery. I can't program it to go more... I am pretty sure it will teleport to the nearest cloud 1600W on a 1.2kg quad is serious power.
Can anyone link me to the 4.5 version for Xcopter? I ve looked everywhere for it but couldn't find it.
My esc's don't plan on working on Mike's Burton FW. I am seriously thinking of throwing the board in the bin and try another. 5 Days I have been reading everything about FW and kkmulticopter board. It's always the same deal. I find the solution that works for everybody but not me
Old Nov 24, 2011, 10:22 PM
Louisville, KY
Joined Jun 2006
I just heard from another friend that he received the "no worky" type yesterday from GoodLuckBuy.com so I recommend not ordering programmers from them as you can't be sure which they'll send you.
Sympster is offline Find More Posts by Sympster
Old Nov 25, 2011, 05:04 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Maybe they are not aware that they don't work. Maybe your friend can post them a link to this thread to enlighten them.
Old Nov 26, 2011, 10:41 AM
Joined Feb 2004
Does anyone have the direct link for the driver for the programmer in this ebay item?
http://www.ebay.com/itm/160679413985...84.m1497.l2649
I can't seem to find the driver for it. I thought I'd replace my home made one with one that was built exactly for this
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Nov 26, 2011, 11:35 AM
Master of Flash
LazyZero's Avatar
Joined Jun 2005
http://fischl.de/usbasp/
Best Christian
Old Nov 26, 2011, 11:40 AM
Joined Feb 2004
for some reason that like doesn't open
Old Nov 26, 2011, 11:41 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
http://www.fischl.de/usbasp/ try this one download the usbasp.2011-05-28.tar.gz
Old Nov 26, 2011, 11:44 AM
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Ups. Double post
Old Nov 26, 2011, 11:45 AM
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Strange that the link does nOt work. But take the zip not the tar.gz.
Old Nov 26, 2011, 02:35 PM
Joined Feb 2004
Well, since I allready have one programmer that works, I decided to send the new one to my son, the computer guru and let him have a go at it. He's got a KK board too but didn't have a programmer.
Can one of you more experienced types point me to a programmer that goes well with Lazy Zero's flashtool?
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Cool KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Hot Online Deals 0 May 26, 2011 12:28 AM
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 0 May 22, 2011 09:14 PM
Sold Quadcopter KK Multicopter RR or RTF w/Turnigy 9X -- Trades welcome KKUSA Aircraft - Electric - Helis (FS/W) 12 Mar 04, 2011 04:29 PM
For Sale SOLD, THANKS - COMPLETE KK QUAD RTF Kapteinkuk multicopter for sale bob.titus FPV/RPV - Equipment and Vehicles (FS/W) 0 Nov 12, 2010 07:23 AM
