Old Jun 24, 2011, 10:02 AM
Moonlight is offline
Find More Posts by Moonlight
Moonlight's Avatar
Rees, Germany
Joined May 2005
Tried to flash to the new version from 4.5 without success. My Quad went completely crazy. Wanted to revers yaw but it didn't work in the way it did before. Is there a new setup routine which I missed ?
Cheers,
Ralf
Moonlight is offline Find More Posts by Moonlight
Old Jun 24, 2011, 10:36 AM
bajas is offline
Find More Posts by bajas
making big holes in the sky..
Scandinavia
Joined Aug 2009
Cheers,
Ralf
Witch board do you have and what RC RX/TX do you have???
bajas is offline Find More Posts by bajas
Old Jun 24, 2011, 11:35 AM
Moonlight's Avatar
Rees, Germany
Joined May 2005
I have the KR red board with esc Turnigy plush 18A and 2.4GHz JR DSX-12 with AR-6200 receiver.
Just went back to version 4.5 a few minutes ago to check. Everything works fine. With 4.6 everything is going wrong, gyros for nick and yaw have to be reversed. Also the trim needs to be far out of the center.
Cheers,
Ralf
Old Jun 24, 2011, 11:51 AM
Moonlight's Avatar
Rees, Germany
Joined May 2005
just noted another strange behavior. Motor 1 on the + configuration doesn't start correctly. Only after applying nearly full power for a short period it's running fine. This also doesn't happen on 4.5
Old Jun 24, 2011, 12:16 PM
bajas is offline
Scandinavia
Joined Aug 2009
Cheers,
Ralf
really strange...
I tried the 4.6 on my KR red board with 18a Hobbywing (the same as Plush) and with bit time beaten up 2217 turnegy motors.
And it flys like a dream..
I use a futaba 9c with a 149 RX.
The thing a had to do was:
-Connected the motors like this: http://www.kkmulticopter.com/index.p...-faq&Itemid=41
-reverse the throttle channel in the RX (ordenery for futaba)
-Taking in consideration that all the potts are reversed
-Calibrated the ESC from the card.
-reverse the yaw gyro.
-sat the gyros at ca 40-50%
good luck
Old Jun 24, 2011, 01:48 PM
Moonlight's Avatar
Rees, Germany
Joined May 2005
did exactly the same - but no success. The biggest issue seems to be the startup of motor 1. Already swapped esc connectors to check. It's for sure not the motor or esc.
Old Jun 24, 2011, 05:40 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Ohoy Kaptain....sadly I dont own a single + frame quad, so I will patiently wait for you to introduce a new Tricopter or Xquad software...
Here is something I have been tinkering with - hope you like it...it flies with tricopter 1.5 software, but has the usual sluggish stick response and very high gain scaling known from the WMP mod. I did not get around to changing the gyro or stick scaling yet...
I would also like to hear your opinion about the HW LP filter and possibly tuning the software to the 500 degrees/s output from the Invensense 500 gyros..so a few of these is coming your way of course....
Thanks!
Jussi
JussiH is offline Find More Posts by JussiH
Old Jun 25, 2011, 07:42 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Originally Posted by bajas View Post
....The pots are reversed (full is CCW)....
As stated before, it is possible to change the direction of the potmeters. Just enter gyro reversing and move the throttle up.
Det er nesten så man kan kalle det en ståkuk.... (sorry, had to write that in Norwegian)
kapteinkuk is offline Find More Posts by kapteinkuk
Old Jun 25, 2011, 07:49 PM
Quad Whisperer
Joined Jul 2008
Thanks!
Jussi
Hello, I like the size of that one. What about the LP filter? I can tune the firmware for it, no problem.
Old Jun 26, 2011, 03:34 AM
Moonlight's Avatar
Rees, Germany
Joined May 2005
kapteinkuk,
do you have any ideas ? I really would like to run 4.6
Old Jun 26, 2011, 07:09 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
Thanks, I knew I could count on you..
Can you send me you adress in a PM. I will get them out to you tomorrow.
I have used the resistor/cap values suggested by the datasheet for the external LP filter (750R/0.1uF) But I am unsure if this give a lowpass that is suitable! According to my calculations Cutoff freq is 2122Hz with this....
Jussi
Old Jun 26, 2011, 09:14 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
KK WMP & yaw PID Heading Hold (HH) control
Hi,
I think you want to see this one !
Can't imagine the result if i will implement it on the pitch and roll axes...
manu
PS: sorry for spamming this around the different groups, i think it could interest some people...
KK WMP & Yaw-PID control (2 min 48 sec)
alll is offline Find More Posts by alll
Old Jun 27, 2011, 09:02 AM
Quad Whisperer
Joined Jul 2008
Here is the new QuadControl V4.7 (plus and X mode) firmware.
The poor atmega48's memory is now full
Changes:
Higher ESC refresh: 300Hz
Added I-term on yaw axis
Added I-term anti wind-up, all axis
Changed potmeter usage:
Roll pot now controls P-term gain on roll/pitch axis.
Pitch pot now controls I-term gain on roll/pitch axis.
Yaw pot controls P-term on yaw axis as before. Yaw axis I-term is fixed at 0.2
X-mode setup:
Motor 1: front left, CW
Motor 2: back left, CCW
Motor 3: Front right, CCW
Motor 4: Back right, CW
Suggested initial setup:
P pot at 50%
I pot at 0% (it can be left at 0% since it does not have a secondary function.
Yaw P pot at 50%
Trim it level.
Adjust P (roll/pitch) to your liking.
Add I until it flies straight forward without pitching up.
Old Jun 27, 2011, 09:08 AM
Quad Whisperer
Joined Jul 2008
kapteinkuk,
Probably I wind-up caused by out of trim.
Use the new V4.7 and follow the setup guide.
Old Jun 27, 2011, 09:23 AM
Quad Whisperer
Joined Jul 2008
Jussi
The gyro you use has a internal 140Hz LP filter, so you can use those values.
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Cool KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Hot Online Deals 0 May 26, 2011 12:28 AM
Sold Quadcopter KK Multicopter RR or RTF w/Turnigy 9X -- Trades welcome KKUSA Aircraft - Electric - Helis (FS/W) 12 Mar 04, 2011 04:29 PM
For Sale SOLD, THANKS - COMPLETE KK QUAD RTF Kapteinkuk multicopter for sale bob.titus FPV Equipment (FS/W) 0 Nov 12, 2010 07:23 AM
