Old Nov 21, 2011, 06:11 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
You use a kk plus 5.5d? Check the bootloader switch. On other boards check the soldering of the hinheader. If that is okay you should get your magnification glass and check the controller pins.
Christian
LazyZero is offline Find More Posts by LazyZero
Old Nov 21, 2011, 07:12 AM
elmesito is offline
Find More Posts by elmesito
Chopping board captain
elmesito's Avatar
United Kingdom, England, Lincs
Joined Aug 2011
I have no idea what I am using anymore, I am confused!
It should be a KK blackboard V5.5 (the one with murata gyros).
I am thinking to write a quick test program with Bascom (I can't do ASM), that replicates the inputs from the receiver to the motor outputs. In that way I can truly verify that the ports actually work.
Am I the only person to have this many problems?
elmesito is offline Find More Posts by elmesito
Old Nov 21, 2011, 01:26 PM
Sympster is offline
Find More Posts by Sympster
Louisville, KY
Joined Jun 2006
Just flashed a HK V1.0 board to the V4.7 m48 KaptienKuk using Lazy Zero's Flash Tool. BTW awesome work LZ! Calibated the esc and all seems good. What is the difference between the V1.0 and V4.7? I thought I read somewhere the Yaw pot did something else..., can't seem to find it now. Are there any difference in setting things up or is it just improved code?
Sympster is offline Find More Posts by Sympster
Old Nov 21, 2011, 02:34 PM
Douwe74 is offline
Find More Posts by Douwe74
Netherlands
Joined Apr 2010
Originally Posted by Sympster View Post
This is it. It came as an "extra" freebie when my friend ordered this one:
http://www.goodluckbuy.com/usb-asp-a...-adapter-.html
I also had some problems with the goodluckbuy.com programmer and I gave up trying to get it to work as soon as I saw the picture on the incompatible programmers list of lazyzero. A new programmer is already on its way.
Are there any known issues that I should be aware of when using the KK flash tool / avrdude software on a Windows 7 64-bit computer?
Douwe74 is offline Find More Posts by Douwe74
Old Nov 21, 2011, 04:07 PM
ariekraakjr is offline
Find More Posts by ariekraakjr
The Netherlands, FR, Wymbritseradiel
Joined Oct 2005
Is this also usable on the HobbyKing Quadcopter Control Board V2 (Atmega168PA)?
ariekraakjr is offline Find More Posts by ariekraakjr
Old Nov 21, 2011, 04:09 PM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Yes. Follow the directions on Christians web site for his Flash Tool to erase the chip first and then you can flash it with what ever Firmware you want.
Rob...
mxspode is offline Find More Posts by mxspode
Old Nov 21, 2011, 04:10 PM
ffranck is offline
Find More Posts by ffranck
ffranck's Avatar
Oslo, Norway
Joined Jan 2011
Yep, I am using V4.7 with HK V2 Board on my quad.
ffranck is offline Find More Posts by ffranck
Old Nov 21, 2011, 04:14 PM
mxspode is offline
mxspode's Avatar
Interesting, those instructions are no longer there. He now links a tutorial on Daddes site. Looks like a good one.
Christian, I notice that Dadde does not mention erasing the chip in his Tutorial. Does your flash tool now take care of that for us?
Rob...
Old Nov 21, 2011, 04:25 PM
erazotropa is offline
Find More Posts by erazotropa
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
Works perfect!
Thanks for Stevis
I have made some mega168p X Quad firmwares that are working very good:
Standard the Yaw rate is very low, Increased a little bit.
Scalestick for Aileron and Pitch = 5 and Yaw = 4
If you are going to reflash, set fuse bit "Preserve EEPROM data", this will keep calibration information intact
erazotropa is offline Find More Posts by erazotropa
Old Nov 21, 2011, 04:30 PM
kauaicuda is offline
Find More Posts by kauaicuda
kauaicuda's Avatar
United States, MD, Frederick
Joined Aug 2010
There seems to be only really one USBasp on goodluckbuy, is this a good unit for $10? Or is there a better one that some of you KK freaks recommend?
kauaicuda is offline Find More Posts by kauaicuda
Old Nov 21, 2011, 04:50 PM
Douwe74 is offline
Netherlands
Joined Apr 2010
Don't buy that one, it's not compatible with the kk flash tool.
Old Nov 21, 2011, 05:08 PM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
i too bought that GLB kk/usb combo..couldn't get the usb to work..i bought this ebay one,,works flawless..
http://www.ebay.ca/itm/USBASP-USBISP...ht_4796wt_1037
but i use the cable that came with the GLB, was easier to move the pins (it wasn't a ribbon cable as pictured it their site)..
barok is offline Find More Posts by barok
Old Nov 21, 2011, 05:21 PM
Sympster is offline
Louisville, KY
Joined Jun 2006
I can confirm the lastest ones they are selling works fine on the HK V1 board, just flashed two of them. It is distinctive because it doesn't have the 10 to 6 cable adapter, it has a 6 to 6 adapter. I mean to say the programmer only has 6 pins. You can see in thier picture. Notice only 3 leads on each side of the board. There may be others that have that 6 pin header, I just haven't seen them. Works fine with www.fischl.de USBasp drivers. Can't guarantee which one they will send you, as when my friend recently ordered it they sent him the one pictured and the old one with the 10 to 6 wired adapter and the old one didn't work.
Old Nov 21, 2011, 06:17 PM
antennahead is offline
Find More Posts by antennahead
antennahead's Avatar
Joined May 2007
Thanks for posting this for those of us that can't understand how to do these things even if we tried!! Are there Any other changes to the 4.7 firmware except the yaw rate? how much do you feel the yaw rate has increased?
Originally Posted by erazotropa View Post
Works perfect!
Thanks for Stevis
I have made some X Quad firmwares that are working very good:
antennahead is offline Find More Posts by antennahead
Old Nov 21, 2011, 06:21 PM
Joined May 2007
What would happen if you made one that has scale stick 4 and yaw 4 on the same firmware?
Works perfect!
Thanks for Stevis
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Cool KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Hot Online Deals 0 May 26, 2011 12:28 AM
Sold Quadcopter KK Multicopter RR or RTF w/Turnigy 9X -- Trades welcome KKUSA Aircraft - Electric - Helis (FS/W) 12 Mar 04, 2011 04:29 PM
For Sale SOLD, THANKS - COMPLETE KK QUAD RTF Kapteinkuk multicopter for sale bob.titus FPV Equipment (FS/W) 0 Nov 12, 2010 07:23 AM
