Old Oct 31, 2011, 08:56 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
No you select the controller corresponding to the target board.
LazyZero is offline Find More Posts by LazyZero
Old Oct 31, 2011, 02:40 PM
Jonit is offline
Find More Posts by Jonit
Joined Jul 2007
Originally Posted by erazotropa View Post
You select a Atmega48 as uC when creating the project..
Even if it will be flashed into a 168/168P ???
for 168P, select Atmega168
Jonit is offline Find More Posts by Jonit
Old Oct 31, 2011, 03:36 PM
erazotropa is offline
Find More Posts by erazotropa
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
ok thanks just to make it clear
erazotropa is offline Find More Posts by erazotropa
Old Oct 31, 2011, 03:49 PM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
Just wondering, as I wait for parts, if anyone has combined an ardupilot(legacy) with a HK KK board to get GPS and waypoint navigation of the ardupilot? I'm not thinking it would be simple, but hardware would be inexpensive. Figuring out what parts of either firmware to change seems the challenge.
HELModels is offline Find More Posts by HELModels
Old Oct 31, 2011, 09:23 PM
Windman is offline
Find More Posts by Windman
Sverige, Uppsala Lšn, Uppsala
Joined Mar 2011
Here I go again...
Regarding the "motor 4 issue".
(in + and x-copter with FW4.7)
I just can't get this problem solved!
Problem description:
Motor 4 spins up at about 0-10% throttle. Motor RPM is constant from 10-50% throttle. Motor RPM increases from 50-100% throttle. When throttle is at 50-100%, the motor RPM is a lot less then the other 3 motors.
(Quad is unflyable. Would not lift from ground if I tried.)
Tested so far without success:
* Two different receivers (Orange R610 and Spektrum AR8000).
* Two different ECU's (Plush 12A and Plush 60A)
* Two different motors (HobbyKing 2614 and Turnigy 3548)
* Reprogrammed to + and X-copter with FW4.7, several times.
* Reprogrammed to FW1.1 - EVERYTHING WORKS FINE!, several times.
* Recallibrating ESC's following guides like this one from rcexplorer, several times.
(Yes, I know FW4.7 have different motor and pot setup as in KK's post in this thread.)
* Callibrating both through KK-board and through the RX one ECS at a time, several times.
* Connecting ESC/motor 1-3 to motor 4 on KK. Then they are behaving the same. (This should confirm it is not an ESC/callibration/motor problem)
* Disconnected motor 1-3, only motor 4 connected.
* Fresh batteries
* Reprogrammed ECU's with Low/Middle/High timing (using a programming card)
* Tested two different HK V1 KK-boards.
* Tested all this on two identical X-copter setups, they both have exactly the same problem.
Some people say they just reflash and recallibrate, problem fixed.
This is not my case, believe me! I have spent many many hours on this
Some other people also seem to have this problem, solving it by going back to FW1.1, which is what I'm flying with right now...
I will try with another brand of ECU in a few days, that is all I can come up with.
Does anyone have a working quad with Turnigy Plush ECU's and FW4.7 on a HK V1 board?
PLEASE HELP!
This is how my beauty looks like. Maby this picture can create some sympathies
Windman is offline Find More Posts by Windman
Old Nov 01, 2011, 12:38 AM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
hi windman
i too FACED the same problem as u with the motor #4
the speed of the motor is quite worrying compared to the other 3 motors
so ....
i calibrated the ESCs ... make sure the gyros are working in the correct direction
took my X out to a grass field just in case it flips over it would have minimal damage coz i really wanted to try this 4.7
told myself not to worry about the 4th motor
throttled up ... quad lifted off (i was expecting a flip before it would get into a stable hover)
hovered perfectly !!! just have to trim it out a bit
settled my nerves about the 4th motor ... got into some FF
and now i am in love with the 4.7 ... just could not get enough of it ... LOL
it is seriously flying on rails
i know it all sounds strange and illogical ... but it worked for me
hope it works for u as well
QiW is offline Find More Posts by QiW
Old Nov 01, 2011, 02:15 AM
nikivan is offline
Find More Posts by nikivan
Joined Dec 2005
Regarding the motor #4 issue, I've observed this as well. However, the quad (HK V1 with TGY Plush 30A ESC running simonk's firmware) lifts just fine and flies very well. I like it much better than OpenPilot CC in rate mode. It is very stable in wind and I observe very little wooble in rapid descents. I am amazed how much it is possible to acheive with this tiny processor.
Cheers,
Nick
nikivan is offline Find More Posts by nikivan
Old Nov 01, 2011, 03:51 AM
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
Cheers,
Nick
So, you are selling you opencontrol then?
Old Nov 01, 2011, 06:31 AM
Windman is offline
Joined Mar 2011
Cheers,
Nick
Hi Nick,
So you had the same issue with KK's v4.7 and are now running simonk's?
Or, you have the same issue with simonk's, and it flies well?
Old Nov 01, 2011, 06:36 AM
Windman is offline
Joined Mar 2011
Cheers,
Nick
Hi Nick,
You got me convinced!
I will give lifting a try...
Actually, during my 10-50% throttle when RPM does not change on motor 4... if I tilt the quad the RPM increases (compensates). That's a good sign.
Old Nov 01, 2011, 07:50 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
No for 168P select 168P/PA, or the board you use.
Old Nov 01, 2011, 11:29 AM
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
That was not for your tool , it was mentioned for compiling the assembly code
Old Nov 01, 2011, 11:33 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Ha okay for compiling of cause the 168 for all atmega168/P/PA.
Christian
Old Nov 01, 2011, 11:38 AM
kalle123 is offline
Find More Posts by kalle123
kalle123's Avatar
Germany - Rhineland
Joined Oct 2008
Me.
This one. Rctimer bl, plush 12 a, HK v1 board, 4.7 firmware.
BR KH
kalle123 is offline Find More Posts by kalle123
Old Nov 01, 2011, 11:40 AM
Centurion1 is offline
Find More Posts by Centurion1
Joined Sep 2011
I am running 4.7, v1, dt750 and plush/basic 18s. no problems.
Centurion1 is offline Find More Posts by Centurion1
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 06, 2011 12:34 AM
Cool KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Hot Online Deals 0 May 26, 2011 01:28 AM
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 0 May 22, 2011 10:14 PM
Sold Quadcopter KK Multicopter RR or RTF w/Turnigy 9X -- Trades welcome KKUSA Aircraft - Electric - Helis (FS/W) 12 Mar 04, 2011 05:29 PM
For Sale SOLD, THANKS - COMPLETE KK QUAD RTF Kapteinkuk multicopter for sale bob.titus FPV Equipment (FS/W) 0 Nov 12, 2010 08:23 AM
