Old Jun 20, 2011, 05:51 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Improved firmware for the KK multicopter, also the HK KK.
After trying Duck!'s MultiWii tricopter I found out that I needed to improve my firmware for the KK multicopter. The MultiWii flew like it was on rails
First out is the quad:
- higher ESC update frequency, from 180 to 290Hz
- PI control loop instead of just P.
- Easier to arm, no throttle trim required.
- Improved LED feedback when setting up. Entering the ESC throttle range adjustment will flash the LED 2 times. Entering the gyro/potmeter reversing flashes the LED 3 times, and will flash rapidly when correct input is given.
- Improved the multiply part of my math library by using the AVR hardware multiplier. The old one where written to suit AVR's without hardware multiplier.
It now flies like it is on rails, no ballooning (pitching up) when stick released in high speed. It also can descend rapidly straight down without wobbling.
The firmware fits in the small atmega48, so users of the HK KK card can upgrade without swapping chips.
Have fun!
EDIT:
New quadrocopter firmware V4.7, see post #73
kapteinkuk is offline Find More Posts by kapteinkuk
Old Jun 20, 2011, 05:59 PM
patrick21x is offline
Find More Posts by patrick21x
Joined Apr 2010
Will this work on my KK black Board?
Which is better, the black or blue board. I bought mine used rtf, and now im trying to learn how to set it up and all. When I let go of the sticks, should my quad pretty much hover by itself. Mine deffiently does not lol. What setting would I adjust to get it to be super stable?
patrick21x is offline Find More Posts by patrick21x
Old Jun 20, 2011, 09:34 PM
Efliernz is offline
Find More Posts by Efliernz
I'll fly anything...
Efliernz's Avatar
Hamilton, New Zealand
Joined Jan 2007
Awesome stuff... although I'm running the KK board as a hex and a tri (while I sort my Paris board out). Are you looking at playing with the tri and hex coding too??? please...
Efliernz is offline Find More Posts by Efliernz
Old Jun 21, 2011, 12:24 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Hi kapteinkuk,
great to see that there is a new firmware by you. I will try the new firmware, if the weather gets better this evening, on my quad. The 4.5 was already very stable in my opinion, so I am curious to see how the new firmware performs.
I also added the firmware to the repository of the KKmulticopter flash tool. Therefore I had to mirror the zip file on my server. I don't know why but I am not able to download from rcgroups with java. I hope you are okay with that?
Best Christian
LazyZero is offline Find More Posts by LazyZero
Old Jun 21, 2011, 12:43 AM
SSM is offline
SSM
Find More Posts by SSM
SSM
Voluntary Assumption of Risk
SSM's Avatar
Australia, VIC, Canterbury
Joined Nov 2003
Thank you, thank you, thank you KapteinKuK!!!
Simon
SSM is offline Find More Posts by SSM
jjk77 is offline
Find More Posts by jjk77
No, it's the same plane ...
jjk77's Avatar
Deutschland, Nordrhein-Westfalen, Bochum
Joined Jul 2010
Great news, are you working on a improved tricopter firmware as well? That would be so great
jjk77 is offline Find More Posts by jjk77
Old Jun 21, 2011, 02:41 AM
bajas is offline
Find More Posts by bajas
making big holes in the sky..
Scandinavia
Joined Aug 2009
This is great....
Is this for x config as well or just + ???
bajas is offline Find More Posts by bajas
Old Jun 21, 2011, 02:59 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Hi KK,
Out of curiosity, wanted to quick test this HK-on demand special one , especially the PI
I uploaded the 88hex on my +quad with WiiMP. After reversing the yaw, everything seems to work. I feel the I working when giving stick input : motors speed up slooowly...
Though, I can't find how to do a stick centering ? ...
Can you remind me the pot functions:
Roll = 0: gyro reversing (ok !)
Pitch = 0: ????
Yaw = 0: throttle calibration (ok !)
all = 0: ???? clear eprom ???
Will need to recompile to have more stick authority...
manu
alll is offline Find More Posts by alll
Old Jun 21, 2011, 10:33 AM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Thanks Rolf, I have always preferred your original firmware on my Tri. I test all of the others but always end up with the chip with 1.5 back in there. I don't have a quad but I am putting a KK board on a friends 330x so I will try it on there.
As always, thanks for your contribution.
Rob...
mxspode is offline Find More Posts by mxspode
Old Jun 21, 2011, 10:56 AM
Felias is offline
Find More Posts by Felias
Joined Jan 2011
Groovy!
If you could also release a x-firmware as well this would be absolutely spledid :-)
Felias is offline Find More Posts by Felias
Old Jun 21, 2011, 11:11 AM
V_Okto is offline
Find More Posts by V_Okto
Joined Feb 2011
i would _love_ the x firmware too
V_Okto is offline Find More Posts by V_Okto
Old Jun 21, 2011, 11:19 AM
micktol is offline
Find More Posts by micktol
Joined Mar 2009
I have flashed the firmware to my quad but when I start the motors to test it, they just get faster and faster with the same throttle input.
The same board works fine with Mike Barton's firmware and older versions so I at a lose as to why it happens.
any idea's?
micktol is offline Find More Posts by micktol
Old Jun 21, 2011, 11:34 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Same here... its the I-term..., I suspect the Rx readings to be off...
manuLRK
any idea's?
Old Jun 21, 2011, 12:09 PM
OlliW is online now
Find More Posts by OlliW
OlliW
Joined Sep 2009
looking at the code I think this is quite normal and the expected behavior. The Midd of the sticks is assumed to be at 1500us, often (usually) however it is in fact 1520us. So, you might get it a bit better by trimming your sticks.
Otherwise, I would suggest just start and fly... in flight the controller has a chance to do its job, but not while in rest.
Ideally, the code would be changed a bit
- the I term could be reset whenever the throttle is below a threshold
- one could introduce a dead band, such that a stick position very near to the center is assumed to be center (I had good experience with 5-10us)
- if the I term increase in magnitude beyond a certain point it should not be allowed to increase any further
I think these changes would add just few bytes of code.
"Interesting" that there is no I term on yaw, no heading hold...
Olli
OlliW is online now Find More Posts by OlliW
Old Jun 21, 2011, 02:44 PM
jorgen is offline
Find More Posts by jorgen
Joined Jun 2010
I've just tried this on my new quad and it flew much more stable compared to 4.5. Although I managed to drop the quad from a height, but that was due to the gnats that was biting me, so only user side bugs.
How would I reverse some of the gyro channels in the code? As it is now, I have to reverse the yaw gyro channel whenever I load a new firmware.
jorgen is offline Find More Posts by jorgen
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Cool KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Hot Online Deals 0 May 26, 2011 12:28 AM
Sold Quadcopter KK Multicopter RR or RTF w/Turnigy 9X -- Trades welcome KKUSA Aircraft - Electric - Helis (FS/W) 12 Mar 04, 2011 04:29 PM
For Sale SOLD, THANKS - COMPLETE KK QUAD RTF Kapteinkuk multicopter for sale bob.titus FPV Equipment (FS/W) 0 Nov 12, 2010 07:23 AM
