Old Jun 20, 2011, 05:04 PM
sa-woody is offline
Find More Posts by sa-woody
X - USAF X - FAA
Santa Ana, CA
Joined Dec 2004
How do you set up for "crow/spoilers/reflex"
I have a simple sailplane; Throtle, Ele, Rud and Ailerons. I am using a DX7 and a 6 channel RX. I want to know how to raise both ailerons using them as a spoiler/crow/reflex on approach controlling the yaw with the rudder. I don't want to set up flaps or build spoilers in the wing.
Any help would be appreciated very much.
Bob
sa-woody is offline Find More Posts by sa-woody
Old Jun 20, 2011, 06:23 PM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Use the mixes, easy to do and use the trims up on the top center to control them...
Evan D is offline Find More Posts by Evan D
Old Jun 20, 2011, 07:34 PM
MikeC47 is offline
Find More Posts by MikeC47
Growing up is overrated
MikeC47's Avatar
Bellevue, WA, USA
Joined Nov 2009
Hi Bob
I have a DX6i, not a DX7, but I imagine the setup will be similar. I assume that you have two servos for the ailerons, and that they are each plugged into the receiver, one to the aileron channel and one to the aux channel. This can’t be done if the servos are fed through a Y plug. You then activate the flap control so you can use the flap switch to move both ailerons in the same direction. Use whatever setting you need to get them both up when you put the flap switch down. You should still have aileron control for roll even with the ailerons up, it just gives you a new neutral position. You will also want to experiment with mixing in some elevator with the spoilerons. I hope this helps.
MikeC47 is offline Find More Posts by MikeC47
Old Jun 21, 2011, 06:03 PM
sa-woody is offline
X - USAF X - FAA
Santa Ana, CA
Joined Dec 2004
Thanks Mike
All is well in lala land.
Bob
Discussion Just got a used Spek 7 and rx - how do I set it up? RCWarbirds Radios 8 Apr 01, 2011 11:48 AM
Do you set up your hotliners with camber and reflex? BING! High Performance 12 Jul 01, 2005 03:14 PM
How do you set "crow"for your XL3200? Zhaokun Deng Electric Sailplanes 15 Feb 13, 2004 10:30 AM
how in blue blazes do you set up a mutiplex 3030 for 120'ccpm with logo 10 aaronredbaron Electric Heli Talk 0 Oct 18, 2003 04:06 PM
Spirit Spoilers......How do YOU hook them up??? Chris Rust Electric Sailplanes 16 Sep 22, 2003 07:12 PM
