Old Jun 20, 2011, 09:48 AM
electricrcflyer is offline
Find More Posts by electricrcflyer
Corvallis, OR
Joined Mar 2000
Outrunner Motor for 2m sailplane
Hello all. I have a Tower Hobbies Vista EP 2m sailplane with a canned 550 motor. Can you suggest an outrunner motor that is inexpensive and a direct/drop in replacement for the stock motor. I plan on using 8 Nicads/NimH
or 3s lipo. Saw lots of BL motor at Hobby King but am not sure w/c one. Can you suggest a specific motor? Thank you.
Ron
electricrcflyer is offline Find More Posts by electricrcflyer
Old Jun 20, 2011, 11:48 AM
TopSpin is offline
Find More Posts by TopSpin
Leesburg, VA
Joined Jul 2005
Try Low Price RC instead. Here is a good one for that plane.
http://www.lowpricerc.com/product_in...oducts_id=1064
Never ever order anything from Hobby King that is on backorder, you will never see it or your money again. I don't recommend them.
TopSpin is offline Find More Posts by TopSpin
Reply With Quote  (Disabled)
Old Jun 20, 2011, 12:15 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Hey Ron, welcome to the world of RC electric gliders! The difference between a brushed can motor and a brushless roadrunner is significant. To keep the weight the same, you will get a LOT more power from the brushless, if you want to keep the power the same... you will need a lot of weight to balance. Note, my use of "lot" is subjective.
The 550 can motor is producing around 200 watts on an 8*4 or 8*6 prop. A decent little motor for the Gentle Lady class gliders is the KDA 2220-L from HOBBYKING. It will turn a 9*6 or 10*6 prop on 12 volts at 20-25 amps approx. On the lower voltage of the nihm packs, you may go up to 11*8 or so (just a guess!) The gliders really perform better with a larger diameter prop for thrust, and less emphasis on pitch speed. On my 2m gliders I run from 10 to 11 inch props.
You will also need a speed controller for brushless... get one with 10 amps.or so more capability than your projected need - under loading the components in the power set will ensure long life and happy parts.
JimNM is offline Find More Posts by JimNM
Old Jun 20, 2011, 01:12 PM
Corvallis, OR
Joined Mar 2000
Hi TopSpin and JimNM. Will either of the motors you suggested fit into a speed 500/600 type motor mount w/o modification? I really prefer not to do any modification.
Ron
Old Jun 20, 2011, 01:19 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
Strange.... recently I made two different purchases from Hobby King of stuff that was on back order.
Both orders have arrived and the wait was only a couple of weeks on each order.
One order was for 2.4 Ghz receivers and the other was for a load of clockwise and counter clockwise props.
I have never had any problem dealing with them and have spent a lot of money over several years worth of orders.
sparklet is offline Find More Posts by sparklet
Old Jun 20, 2011, 01:29 PM
sparklet is offline
Cumbria in the U.K
Hi Ron,
I won't recommend a specific motor but I will strongly suggest you use 3S lipos. The power to weight advantage is significant and the lipos will be far better for a glider. You will need a proper balancing charger for the lipos but once you use them I doubt you will want to go back to nimh packs.
I was flying a lightweight glider this afternoon with 3S 1600 mAh lipo packs. and an Emax 2215-25 brushless outrunner. The glider weighs around 2 lbs and wingspan is approx 64 inches. It's built up balsa construction.
To climb, very quickly, to the limit of my eyesight takes only around 20 to 30 seconds. I time the pack so I run it for 3 minutes total motor runtime. That gives me several climbs to very high and leaves the lipos in a safe discharge state.
I had 1 hours flying with 3 lipo packs. The lipos are LoongMax and are 3 years or so old.
Old Jun 20, 2011, 01:54 PM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
Hey Ron, the mounting holes for this motor are on a 16mm by 19mm hole pattern. I believe that is the smart as your motor mount. note that some older 500/600 motors used a band around the body of the motor to the motor in place. The outrunner motors will not work with that style. Sorry if you already kniw that, but I don't want to lead you wrong by assuming that you already know this stuff.
http://www.hobbyking.com/hobbyking/s...idProduct=2106
Old Jun 20, 2011, 06:20 PM
Corvallis, OR
Joined Mar 2000
Thank you for all the replies. I'll post update when project is done.
Discussion can anyone identify this outrunner EDF motor? for 90mm fan. Warhead 1850kv motor? cleansho93 Electric Ducted Fan Jet Talk 2 Mar 18, 2011 01:56 AM
Sold 2m ARTF "Competition" Sailplane - SEE PICS agarchitect Aircraft - Sailplanes (FS/W) 6 Mar 16, 2011 09:21 PM
For Sale METRICK 2M Sailplane Kit olyman Aircraft - Sailplanes (FS/W) 1 Mar 04, 2011 08:39 PM
Motor/gearbox recommendations for 2m sailplane Woody Electric Sailplanes 11 Jul 08, 2001 07:27 PM
