Old Jun 20, 2011, 07:17 AM
JonDv is offline
Find More Posts by JonDv
Australia, QLD, Burpengary
Joined Jun 2011
Instruction Manual Error in J-Power T-45 50mm CG postion
I have just recieved an e-mail from J-Power regarding the CG shown in their T-45 50mm Instruction Manual. Further to my inquiries, they have now confirmed that the CG shown in their Instructions is indeed totally in-correct, and they have released a new diagram showing the correct intended position for the CG for the T-45 50mm. This is the e-mail :-
Dear Jon,
Good day!
Thank you very much for your assistant on our quality control.
Yes. I got reply from our R&D department, the CG for T-45 is wrong in our manual, we revised the version already, enclosed I also put the right version as per ref. Refer attached new drawing for T-45 CG.
We are sorry to bring you this problems. and sincerely appreciate your help on the quality control on our products.
Thanks!
Shirley
J-Power
Hopefully this info will be of use to new T-45 owners. I got concerned that the picture shown in the manual may have been incorrect, when I realised that every other J-Power EDF plane manual used the front of the wing (or where it meets the fusalage) as the reference point to measure where the actual CG should be.
For those that don't know the T-45, the instruction manual incorrectly shows the CG mark as being on the left hand vertical marker line in the picture, i.e the front of the wing where it meets the fusalage, instead of the right hand marker line . The correct "stock" CG position is now shown below.
JonDv is offline Find More Posts by JonDv
Old Jun 20, 2011, 10:40 AM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
Great to know, thanks for the update. Haven t maidened mine yet.
JGuilty13 is offline Find More Posts by JGuilty13
Old Jun 20, 2011, 04:13 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
If you put the battery where they have it, you will be so nose heavy, you won't be able to pull out of a steep dive. (Don't ask me how I know)
I put the battery right in front of the servos, and it's fine. Using an 800.
kelberts is offline Find More Posts by kelberts
Alert Banana Hobby/J-Power 50mm A-10 EDF Failures Ducati0749 Foamy EDFs 5 Oct 27, 2011 06:25 PM
Contest J power 50mm speed compitition!!!! corsair nut Foamy EDFs 90 May 18, 2011 12:07 PM
Rant J Perkins Distrib - Why no 50mm J Power/Skyangel in UK????? Jacques.Eloff Foamy EDFs 10 May 16, 2011 05:29 AM
Build Log HSW J-Power 50mm T-45 SkylineFlyer Foamy EDFs 31 Dec 21, 2010 11:49 PM
