Old Dec 20, 2011, 09:27 AM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
thanks. does anybody knows where to buy current sensor which is compatible with RVOSD?
sharonx is offline Find More Posts by sharonx
Old Dec 20, 2011, 09:57 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Do you want an aditional one or "broke" yours? In the latter case, look at the bottom of the PCB. There is a VERY small trace going to the connector connection labeled VCC which is suposed to serve as a fuse (to protect the RVOSD if you connect the sensor the wrong way to the board). It melts trough if you do this and if it's only for a second. Applying some solder there makes it work again, but be warned that a next time mixing up polarity then would most likely kill something in your RVOSD.
If you absolutely need a sensor, this guy here should work (but is a 50A sensor only)
http://www.flytron.com/osd-headtrack...simpleosd.html
Other than the 50A type "limit", the sensor should work the same. Note that it does not have that small trace which serves as a fuse though.
The "ultralight series" from Flytron eventually work too (but I haven't found the time yet to test it).
http://www.flytron.com/sensors/64-ul...nt-sensor.html
Eventually you would need a way to calibrate it. I don't know if the RVOSD firmware allows you to do this. I know, it's a shame but I have in general not enough time to do and check all the things I would like to....
The sensors chips used are from Alegro and available, so replacing yours (provided it's broken) is an option. Replacing the Flytron one with a 100A variant sensor chip is another option too.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Dec 20, 2011, 11:20 AM
sharonx is offline
sharonx's Avatar
HTH
Markus
Thanks for the info. I didn't break mine, I have a set without it form a friend.
According to Alex, it gives 41.25mV/A. This is not the case for flytron curr. sensors nor other I have seen.
Too bad we can't caliberate it in the menu.
Waiting for stock to arrive to RV. Will it ever ?
Old Dec 20, 2011, 11:48 AM
sharonx is offline
sharonx's Avatar
Originally Posted by Bear_Pants View Post
So how can I go about making a switch for RTH? I guess I can live without the menu switching. Kinda sucks though. I want to atleast toggle RTH if something is going wrong. Or have it RTH if I disconnect my transmitter. Being able to use FBW would have been cool. Stupid fly sky.
I did it with 2 +100 +100 or -100 -100 (can't remember) mixes. it works like a charm. one mix wasn't enough.
I even have pan tilt and rudder while in RTH (-:
http://rangevideo.com/forum/showthre...ghlight=switch
Old Dec 20, 2011, 05:07 PM
Registered FPVer :)
Joined Aug 2006
Too bad you can't calibrate. The statement given by Alex does not sound right IMHO. The chip used, according to the datasheet, gives 20mV/A. It's this guy here: ACS758LCB-100U-PFF-T, the datasheet can be found here,
http://www.allegromicro.com/Products...Cs/ACS758.aspx
and you most likely should be able to sample it too.
The cirquit needed is dead simple in that the sensor get's 5v from a tiny linear voltage regulator, the output of the sensor chip forms the "signal" going to the RVOSD. The cirquit is pretty much what's proposed in the datasheet too, so you could build one up by yourself on one of those prototyping PCB boards available, or as mentioned previousely, get the one from Flytron and simply replace the sensor chip. At least that's the route I'm going if I need another single sensor.
For how long are they out of stock, and did RV gave any estimated arrival or other reasons why it's out of stock there? The thing does not look like rocket sience...
HTH
Markus
Old Dec 21, 2011, 06:36 AM
MaximumBob is offline
Find More Posts by MaximumBob
I love the smell of elapor....
MaximumBob's Avatar
Setauket, New York
Joined Oct 2009
would this current sensor work??????
http://www.readymaderc.com/store/ind...roducts_id=314
MaximumBob is offline Find More Posts by MaximumBob
Old Dec 21, 2011, 11:08 AM
sharonx is offline
sharonx's Avatar
1. Can I define the radius of the RTH circles ?
2. What happened if bettery runs out while in RTH ? will the plane land nicely ?
Old Dec 21, 2011, 12:31 PM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
No, the plane will stall and land un-nicely.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Dec 21, 2011, 01:38 PM
MaximumBob's Avatar
Setauket, New York
Joined Oct 2009
any help here?
Old Dec 21, 2011, 02:57 PM
Registered FPVer :)
Joined Aug 2006
any help here?
Not sure if you want to hear my opinion. The problem is that the product informations you linked to do not reveal which sensor is used etc. I would have to buy one and reverse engineer it. Maybe someone who has this sensor could give us some information on it.
So IMHO for those who don't want to delve too deep into the topic and badly need a solutoin, a working option is to go for the sensor from Flytron, unsolder the allegro chip used there, and replace it with the one RV uses. I posted the type RV uses in one of my last posts here and you should be able to buy or sample it in small quantities. One obviousely should first check if he can source this chip before ordering at Flytron though. The sensor from Flytron and the one RV needs are pin compatible. The only difference between the two is the milivolts per ampere reported and how many amps the sensor takes as a maximum.
Obviousely this MUST match what the RVOSD firmware expects cause otherwise your readings would be wrong. I thus don't see another way to get to such a working sensor other than useing the same chip RV uses or of course to wait for them to be in stock again.
HTH
Markus
Old Dec 21, 2011, 04:21 PM
MaximumBob's Avatar
Setauket, New York
Joined Oct 2009
thanks Markus.....wish we could get an answer from the RangeVid crew as to what the dealio is...... i hate flying without any idea as to what my current usage has been !!!!!!! its sorta like going on a road trip with a broken fuel gauge.... stressful !
Old Dec 23, 2011, 03:13 AM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
I bought RVOSD5 long time ago but only just got around to installing it (got a bit sidetracked with multi-rotor fpv). Works extremely well and it has given me a lot more confidence to fly further out. Without gps and rth I was always concerned about losing a plane due to video signal drop outs.
My question is, can you supply 12 volts to the unit by tapping into the balance port of a 4,5 or 6 cell lipo? I want to fly a wing using just the one battery which is a 5 cell, dont want to carry a 3 cell as well. So this battery would be plugged into the current sensor, then tap into the balance plug and supply 12 volts to RVOSD for the aux batt. plus 5 volts for my rx. Is there any problem having the same battery as main & aux at the same time?
Stunt Double is offline Find More Posts by Stunt Double
Old Dec 23, 2011, 03:37 AM
Registered FPVer :)
Joined Aug 2006
While you could do this, I strongly recommend you not to do it. The reason is that if you do so, you discharge some cells more than others which will lead to an unbalanced battery and the battery failing earlier.
The save way to do this is to add another DC/DC converter (small, lightweight and efficient) that you hook up to the battery and which outputs the 12 volts you later on feed into your RVOSD. Just make sure you use a DC/DC converter and not a linear voltage regulator. Maybe something like this should do well:
http://www.dpcav.com/xcart/product.p...cat=256&page=2
I know it's out of stock, but it should give you an idea on what to search for. If you intend to also hook up your bec to this, make sure the current consumption of your rx and all servos plus the OSD is not too high for the converter.
Just searched the net a little more, and this guy may works well for you:
http://www.sureelectronics.net/goods.php?id=837
HTH
Markus
Old Dec 23, 2011, 03:50 AM
Joined Oct 2007
Thanks Markus thats a help. The reason I asked that is because I tap into a 4 cell on my fpv quad and supply 12 volts to the vTx / camera. Those flights are very short so it doesnt seem to unbalance the pack but I guess if I did this with RVOSD/rx/vTx/cam + a long flight it would definitely unbalance the pack.
Old Dec 23, 2011, 04:16 AM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
We can only order the rvosd from rangevideo?
freshmint is offline Find More Posts by freshmint
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
