Old Dec 18, 2011, 07:26 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Originally Posted by lrrps View Post
The Dragon Link TX can operate without the antenna for some time, that's what Mike said.
You might want to ask him about that again.
man2000me is offline Find More Posts by man2000me
Old Dec 18, 2011, 07:36 PM
bakchos is online now
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
You can do like you want, but i would never operate a transmitting device without antenna, this will make it overheat and can cause damage.
In electronic, heat is the enemy
bakchos is online now Find More Posts by bakchos
Old Dec 19, 2011, 01:01 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Look here:
http://www.rcgroups.com/forums/showt...18533&page=122
lrrps is offline Find More Posts by lrrps
Old Dec 19, 2011, 02:04 AM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Originally Posted by gundamnitpete View Post
any idea on upcoming stock for the RV OSD?
its never coming back in stock
octane81 is offline Find More Posts by octane81
Old Dec 19, 2011, 02:11 AM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
His response...
http://www.rcgroups.com/forums/showp...postcount=1829
Old Dec 19, 2011, 06:13 AM
Gustavovon is offline
Find More Posts by Gustavovon
Brasil, RJ, Rio de Janeiro
Joined Aug 2011
Nooooooooo
Gustavovon is offline Find More Posts by Gustavovon
Old Dec 19, 2011, 06:17 AM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
Originally Posted by Gustavovon View Post
Nooooooooo
This must be a joke
sharonx is offline Find More Posts by sharonx
sharonx is offline
sharonx's Avatar
Originally Posted by ScooterInVegas View Post
What are HDOP and Angle ?
Old Dec 19, 2011, 06:21 AM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
HDOP is the GPS accuracy. The RVOSD is set by default to set home at 1.36.
The angle is the angle the plane is in relation to you and the ground.
Old Dec 19, 2011, 06:52 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
I have a question about Altitude Limit setting in Autopilot mený in RVOSD5
When AHI is set to IMU this limits acts only under Cruise altitude ? Correct ..?
And what happens when you turn on automatic pilot under this limit ?
IMEIV is offline Find More Posts by IMEIV
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
So -90 means that the plane is at right angle below your feet.
Old Dec 19, 2011, 07:08 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
I guess it will make the plane climb to the preset limit.
Old Dec 19, 2011, 07:17 AM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Imeiv - I think you have quite a few things mixed up. When the AHI (Artificail Horizon Indicator) is set to IMU that means that the osd is using the IMU for all AP(Auto Pilot) functions. The other option is IR Sensors. They were used with the g4 and were affected by clouds, water, anything that had a temperature different from its surroundings. Cruise Altitude + Altitude Control Limit will determind what altitude the rvosd will attemt to keep the plane at. When the plane is above the combined hieght of the Cruise Altitude + Altitude Control Limit, the rvosd will use the glide throttle setting and try to descend to the determind altitude. When the Plane is below the determind the altitude, the rvosd with use cruise throttle to attempt to stay or try to get to determind altitude.
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
You say that if I active autopilot at 50meters it brings the plane to 100meters (default value for Limit Altitude) ? I would think it brings the plane to Cruise Altitude (200m default value)..
Old Dec 19, 2011, 07:25 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Thanks..
Yes, I specifically called the IMU because the instructions talk about it in Altitude Limit. And say "When the AHI source is set to None, this limits PID action over and under Cruise altitude". This suggests that when AHI source is set to IMU the limits acts ONLY over OR under Cruise Altitude.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
