Old Dec 07, 2011, 10:51 PM
screwup is offline
Find More Posts by screwup
no gap is too 'small'
screwup's Avatar
Melbourne, Australia
Joined Feb 2009
another Question about the AHI.
when you set it in the air, do you have to save ?
and does it reset the horizon when you start it up?
screwup is offline Find More Posts by screwup
Old Dec 07, 2011, 11:41 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
From the factory it is set level if the rvosd5 is level. It should be put in the plane level. If that is not possible then once your mounted ready to fly the go in the menu and set level ahi. Do this while the plane is on the ground. Let it sit for about 30 seconds. Then save configuration. You should be good to go.
man2000me is offline Find More Posts by man2000me
Old Dec 08, 2011, 12:42 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Its important to make sure the plane is siting at its normal flight attitude when setting the AHI neutral, so if the plane is usually a bit nose up in flight then sit it that way if setting the AHI on the ground.
ommadawn is offline Find More Posts by ommadawn
Old Dec 08, 2011, 11:47 AM
MaximumBob is offline
Find More Posts by MaximumBob
I love the smell of elapor....
MaximumBob's Avatar
Setauket, New York
Joined Oct 2009
el cheapo: when are you getting new stock of gen 5 and the current sensor and gps receiver?
MaximumBob is offline Find More Posts by MaximumBob
Old Dec 08, 2011, 11:51 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Originally Posted by BushmanLA View Post
If you are using two batteries, make sure you plug in the RVOSD battery before you plug in the battery to the current sensor.
I'm pretty sure there is a weird issue with plugging in batts in the wrong order that will hose the AHI and make it really sluggish.
Thanks BushmanLA for the suggestion. I tried to plug before the RVOSD and then battery to the current sensor and the problem seems to vanish... I tried only on the ground because today I could not fly.. I hope it will be fine even when I fly.
Then I try to "Set Neutral AHI".. Is correct run this setting on the ground and not in flight ?
IMEIV is offline Find More Posts by IMEIV
Old Dec 08, 2011, 12:32 PM
Gustavovon is offline
Find More Posts by Gustavovon
Brasil, RJ, Rio de Janeiro
Joined Aug 2011
2... I send an email to there but no one answer.
Gustavovon is offline Find More Posts by Gustavovon
Old Dec 08, 2011, 02:54 PM
MaximumBob's Avatar
Setauket, New York
Joined Oct 2009
bad time of year to be out of stock on stuff like this!!!!!! was going to ask my wife for a gen5 as a xmas present!
Old Dec 08, 2011, 03:52 PM
mark the shark is offline
Find More Posts by mark the shark
mark the shark's Avatar
United Kingdom, England, Darwen
Joined Aug 2007
I'm sure there will be a new batch soon I doubt he wants to miss out on the Xmas spending frenzy.
mark the shark is offline Find More Posts by mark the shark
Old Dec 08, 2011, 07:22 PM
MaximumBob's Avatar
Setauket, New York
Joined Oct 2009
yeah im in desperate need of the gen 5 and a new current sensor for my old gen 4!
Old Dec 11, 2011, 12:26 PM
henrymoro is offline
Find More Posts by henrymoro
henrymoro's Avatar
Espaņa, Cantabria, Miengo
Joined Jul 2007
Hi Guys,
Something weird happened to me in one of my first flights with rvosd, is that screens automatically switch between themselves without me touching anything in my futaba 12fg. Any of you experienced this before?
henrymoro is offline Find More Posts by henrymoro
Old Dec 11, 2011, 01:06 PM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Originally Posted by henrymoro View Post
Hi Guys,
The radio switch range adjustments that activates screen changes may be set too close to the trigger point. I would try first determining the exact point that activates the change and then set the range a little beyond that point.
Gary Evans is offline Find More Posts by Gary Evans
Old Dec 12, 2011, 12:10 AM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Video from my second flight with my RVOSD5.
Blunt Swift 2 w/ RVOSD - Flown w/ Dragon Link (3 min 41 sec)
airbagit13 is offline Find More Posts by airbagit13
Old Dec 12, 2011, 02:30 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
http://vimeo.com/33514357
Hi Airbag,
Is that the RSSI info displayed below the temperature (100%), I read 0% even when the DL TX is near the plane while in the menu 2/3 I can read min RSSI: 2350 max RSSI: 2350.
Dunno what I did wrong.
What VTX & VRX do you use, video is Xtal clear.
Also do you use a seperate lipo pack for the VTX, OSD, radio receiver & GPS?
Thanks.
lrrps is offline Find More Posts by lrrps
Old Dec 12, 2011, 04:21 AM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
Originally Posted by lrrps View Post
Hi Airbag,
Thanks.
Rerun the wizard, did turn off the transmitter when ask to ?
bakchos is offline Find More Posts by bakchos
Old Dec 12, 2011, 04:29 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
The wizard is a pain in the ass to follow by the letter, I had a hard time to setup the RTH feature.
Got to rememorize what I did before and redo it once again.
Thanks anyway for your input.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
