Originally Posted by borneobear
Where are the stabilized flight reports??
I am not reporting here because I still have some problems running RVOSD5 and autopilot correctly. It came out it does not work with GoPro HD camera live video output correctly. Probably desoldering resistor R11 would help, but not confirmed. RangeVideo can not confirm this because they have no access to GoPro HD.
And currently I have problem that AHI is not aligned with the horizon. BTW I have full RVOSD5, not addon card.
Here's the video from my last test flights. GoPro HD changed to simple PAL CCD camera for tests. Please open in YouTube to see index.
I think there are many users that are happily using the product without any problems. And then there are some like me that are having issues. Probably you should look for info on RangeVideo forum.
I will post a review after all my issues with RVOSD5 are solved.
Originally Posted by mark hitchman
If you launch in fly by wire mode will this stabilize a wing like the Zephyr or is there a better mode to launch in?
Yes, it will stabilize it during the launch. Though prior to doing this you have to make sure IMU works correctly and vibrations does not affect it, also check that AHI is aligned with horizon. The best would be launch without FBW (fly by wire) and watch video recording afterwards to determine if AHI was was aligned correctly all the time.
Originally Posted by Blackrat
that would be awesome eh , launch at let fly to the first way point .. getting onto drones here
Unfortunately waypoint sequencer works only for USA customers. It is disabled for the rest of the world.
