Old Jun 29, 2011, 05:23 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
Gary,
Vimeo works fine here. Is there away to move the horizon bar up to the horizon or is it always in the center of the screen? RTL looks like it works great.
vertcnc is offline Find More Posts by vertcnc
Old Jun 29, 2011, 07:00 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
Not to hijack, and its sort of a embarrassing question, but
how hard is this RVOSD gen5 to install and setup?
How many hours are you all putting to get this to work?
(ie....menu screen setup, RTH....etc....)
I have a SkyWalker and Radian PRO for FPV.
I have Immersion EzOSD and its probably the easiest OSD I've ever setup
I do not have RTH on my EzOSD, it doesn't have that option.
So please be easy on me
LexusFPV is offline Find More Posts by LexusFPV
Old Jun 29, 2011, 09:26 PM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
I use the EzOSD as well. It is a great system. The only thing lacking is a inertial guidance system.
Using a FY-21AP on a Skywalker plane it works well with the EzOSD.
However the long wave fishtailing (over corrections) are aparent using the FY 21 during stabilization mode.
Only the gain by potentiometers are available for the control surfaces on the FY.
It will probably take me 2 hours to install the unit upon arrival.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Jul 01, 2011, 10:02 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
The upgrade board is an excellent option! However I was wondering...
I have done the mod to my OSD to enable it to use a go pro as the primary camera. Is the resistor I remove on the board I would keep or the new board?
Thanks.
Gree is offline Find More Posts by Gree
Old Jul 01, 2011, 12:17 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
On the new board you have to remove R11, it is located on top of the graphic board and label is different. So you don't need to disassemble the boards.
Elcheapo is offline Find More Posts by Elcheapo
Old Jul 02, 2011, 11:54 AM
Joined Feb 2011
OSD Comparison chart.
Here is a link to OSD comparisons.
It needs to be updated.
https://spreadsheets.google.com/pub?...jg&output=html
Old Jul 02, 2011, 12:28 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
You have to ask DOSD makers//followers to do so, they manage that chart.
Old Jul 02, 2011, 12:38 PM
Neo360 is offline
Find More Posts by Neo360
Joined Jul 2009
http://www.vimeo.com/25832128
Neo360 is offline Find More Posts by Neo360
Old Jul 02, 2011, 01:02 PM
imdone is offline
Find More Posts by imdone
imdone's Avatar
United States, WA, Seattle
Joined May 2011
Question...If you are in fly by wire mode, can you easily switch to return to home with out going through the menu if needed?
imdone is offline Find More Posts by imdone
Old Jul 02, 2011, 01:06 PM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Turning the Tx off will do it.
Gary Evans is offline Find More Posts by Gary Evans
Old Jul 02, 2011, 01:07 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
The autopilot has 6 modes:
RTH
Level flight
Heading hold
Position hold
Fly by wire
Waypoint sequencer
The mode can be preselected in-flight on the menu, and it is activated/deactivated with a toggle switch assigned to an auxiliary channel.
But if at any time the system detects that the R/C link is lost, it will switch to "return home" mode, until signal is back.
Old Jul 03, 2011, 12:28 PM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
what voltage does the current sensor work too ?
70A aint much
Blackrat is offline Find More Posts by Blackrat
Old Jul 03, 2011, 12:45 PM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
why data is always so centered? osd644 or dragonosd always put data glued to frame so it dont looks like intrusive, in rvosd a big margin is let over all edges, can this info be moved by user?
wallaguest1 is offline Find More Posts by wallaguest1
Old Jul 04, 2011, 11:20 AM
Blackrat is offline
Registered Loon
Blackrat's Avatar
Joined May 2006
RTH
Level flight
Heading hold
Position hold
Fly by wire
Waypoint sequencer <--- is this for north america only ??
want to buy this osd, but not sure if it can handle 6s ?
and does the waypoint function work for the rest of the world ?
Old Jul 04, 2011, 11:31 AM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
Yes it can handle 6S. But in that case you have to provide a 3S battery to power the video signal through the auxiliary battery input.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 10:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 11:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 05:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 01:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 03:51 AM
