Old Nov 02, 2011, 08:56 AM
pouascail is offline
Find More Posts by pouascail
Viuz La Chiesaz
Joined Nov 2006
Try not to copy and paste the password (blanck spaces are sometines added...)
Type : RvosdSequencer and let the username empty...
regards,
pouascail is offline Find More Posts by pouascail
Old Nov 02, 2011, 05:45 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
I have a question about the altitude when it comes to waypoint navigation.
When using RTH I have set an upper and lower altitude, and I have set my plane to turn off the motor and glide, when flying from the upper altitude, down to the lower altitude.
In waypoint navigation, does the plane also glide down if waypoint 1 = 300 meter altitude and waypoint 2 = 100 meter altitude, or does it descent to 100 meter, with the motor running, and then let the plane build up more speed than it might be able to handle ?
SpookiePower is offline Find More Posts by SpookiePower
Old Nov 03, 2011, 12:17 AM
Viuz La Chiesaz
Joined Nov 2006
Hello
I think you d better ask to alex in range video forum for autopilot questions he has the knowledge.
Old Nov 03, 2011, 02:34 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
I'm wondering if imdone has eventually powered up his FPV gear correctly.
lrrps is offline Find More Posts by lrrps
Old Nov 03, 2011, 06:48 AM
Macattaka is offline
Find More Posts by Macattaka
Beyond the BlackStump
Macattaka's Avatar
Australia, SA, Adelaide
Joined Mar 2006
I've just installed and maidened the V5 in a Radian Pro, how cool is 'fly by wire'!
One small problem, I'm not getting any current draw info no matter what throttle setting, it just sits on 0.5A. I do see accurate batt voltage, but the mAh draw only trickles along obviously following the 0.5A draw.
Any ideas?
Macattaka is offline Find More Posts by Macattaka
Old Nov 03, 2011, 08:01 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
There have been a few dead current sensors. You are in luck. I have a spare you can have until your replacement arrives, if its dead.
Yes FBW is brilliant. Great for thermalling. You might want to tweak it up a bit as the default settings are quite conservative.
Cheers
Frank
ommadawn is offline Find More Posts by ommadawn
Old Nov 03, 2011, 10:24 AM
Bear_Pants is offline
Find More Posts by Bear_Pants
United States, NJ, Manchester
Joined May 2011
I tested autopilot yesterday again. It was cool. Flew in circles this time not a figure eight. :]
Bear_Pants is offline Find More Posts by Bear_Pants
Reply With Quote  (Disabled)
Old Nov 03, 2011, 10:42 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Did you have a chance to try the autopilot on a windy day?
Old Nov 03, 2011, 11:34 AM
Joined May 2011
Not yet! When I properly "prop out" my plane my take offs will be tons easier. But I will keep you updated.
Old Nov 03, 2011, 12:17 PM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
I have on moderately windy days.
FBW really helps keep things stable.
Since ground speed is used instead of air speed I had the heading indicator go in reverse once
RTH can fail in high winds.
Example: A strong tail wind will cause you to have a high ground speed, but low air speed. This might lead to a stall, but it would have to be pretty dramatic to cause a crash.
A strong head wind may cause the aircraft to just just point home but not actually get there any time soon. This depends on what your cruise throttle is etc.
A side wind will case the aircraft drift as it heads home, it will constantly correct, but it isn't smart enough to vector in for shortest path.
BushmanLA is offline Find More Posts by BushmanLA
Old Nov 03, 2011, 02:42 PM
Joined Jun 2009
Does it shows the speed negative, like -20km/t if there is enough headwind to push the plane backwards ?
Old Nov 03, 2011, 02:46 PM
rc-mike is offline
Find More Posts by rc-mike
Stay airborne my friends
rc-mike's Avatar
USA, TN, Dickson
Joined Nov 2004
No, it doesn't know which way the plane is pointed so it just thinks the plane is facing the opposite direction. A magnometer would be nice in a situation like this. I've had it happen many times. As a matter of fact, it happened to me yesterday. Calm on the ground but very windy up high.
rc-mike is offline Find More Posts by rc-mike
Old Nov 03, 2011, 04:11 PM
Macattaka's Avatar
Joined Mar 2006
Cheers
Frank
Thanks Frank, I'll be in touch when i get home.
I will tweak the FBW settings a bit as it was super stable but manouevred with all the agility of a houseboat.
Cheers,
Al
Old Nov 03, 2011, 05:11 PM
BushmanLA's Avatar
Joined Dec 2005
Cheers,
Al
FBW takes a while to get used to, you really got start moving those stick around to do anything
Here is a vid with the aircraft flying backwards
http://www.youtube.com/watch?feature...WU1K6u6I#t=60s
Old Nov 03, 2011, 07:54 PM
Macattaka's Avatar
Joined Mar 2006
'sticks to the corners' I can do , it's the subtle movement of gliders that's new to me...
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
