Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Does you ESC works normal, if you keep the current sensor between your lipo and ESC, but unplug the current sensor from the OSD ? |
Can you please help me with the following questions :
1. I have Gen4 with latest firmware. If I only connect 5V battery pack to the current sensor port - the RVOSD won't start. My gen5 (I have 2 RVOSDs) does start at this conditions. The gen4 will only start if I connect the 5V pack to Auxiliary Batt. Why is that ? 2.If I want to power up the RVOSD from my main lipo, does it take the power from the + - of the current sensor port or does it uses my ubec 5V that comes from the receiver ? Can I power the receiver without ubec, so the RVOSD will provide the 5V for the receiver and servos ? 3. Can I power up the entire system from 4S lipo ? The manual says to use max of 3S lipo. Does this mean I have to use different video lipo? p.s My lowest jumper is set to enable main battery Hope I didn't confuse you. Sharon |
2-The OSD takes power from +- of the current sensor or from auxiliary battery if connected. It lso power the Vtx and camera from those sources. It does not provide neither it takes power to the servo Vcc rails. you have to use an external BEC for that. 3-You can use any battery combination from 2S to 6S if the OSD is set to provide 5V to both camera and Vtx, else you have to use either a single 3S battery to power the entire system or a different cell count main battery with a 3S battery on the auxiliary battery input, main battery jumper has to be set to disable on this case. For a more detailed explanation of this you can read here: http://rangevideo.com/forum/showthre...progress...%29 |
got a few questions...why cant I upload the newest firmware to my osd? everytime I try to upload to my picket 2 I get a "device error hex file not loaded" message why do I get video a picture without plugging in my 3s aux batt? I thought the aux batt powers the vt and cam not the 4s main battery![]() also how do I display the aux batt voltage? |
5.06 is the one you want. My suggestion is that you fly a full flight with FBW activated and watch the AHI etc. If you have no problems here, then RTH should be rock solid. |
| Thread Tools | |
| Discussion Maiden Reports | 12345 | Arizona Model Aviators | 466 | Apr 23, 2013 06:29 PM |
| Help! RVOSD thermal sensors | rcmonster99 | Video Piloting (FPV/RPV) | 16 | Jun 20, 2011 10:21 AM |
| Discussion Weekend weather reports | neck | Arizona Model Aviators | 13 | Jun 10, 2011 04:59 PM |
| Discussion where are the Joe Nall horror "reports? | guy hanson | Radios | 49 | May 18, 2011 12:06 PM |
| Discussion Finally Fixed the Country Reports | daboz | Dynamic Soaring | 5 | May 16, 2011 02:51 AM |
