Old Oct 20, 2011, 09:42 AM
Bear_Pants is offline
Find More Posts by Bear_Pants
United States, NJ, Manchester
Joined May 2011
Originally Posted by lrrps View Post
Does updating the firmware reset le AP setup to default?
Yes.
Bear_Pants is offline Find More Posts by Bear_Pants
Reply With Quote  (Disabled)
Old Oct 20, 2011, 11:47 AM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Look at you go! RVOSD expert :-)
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Oct 20, 2011, 02:24 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Tonight I gain some progress and made connection between RVOSD and Pickit 2. But this time I received "PICkit 2 VPP voltage level error"
Does any RVOSD expert know to pass this?
Cheers
Firatp is offline Find More Posts by Firatp
Old Oct 20, 2011, 02:28 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
Are you trying to program using a Laptop?
If so try using a PC, sometimes the laptops can't provide enough power on the USB ports.
Elcheapo is offline Find More Posts by Elcheapo
Old Oct 20, 2011, 02:41 PM
nft343 is offline
Find More Posts by nft343
Joined Mar 2011
You can also use a powered USB hub to achieve the same result.
nft343 is offline Find More Posts by nft343
Old Oct 20, 2011, 02:50 PM
Joined May 2011
d:
Old Oct 20, 2011, 03:32 PM
Firatp is offline
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Yes, I am using a laptop. Yeah maybe my laptop has not enough power!!
Thanks in a million.
Regards
Old Oct 20, 2011, 03:35 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Try all the usb ports, some are high power some are not.
man2000me is offline Find More Posts by man2000me
Old Oct 20, 2011, 04:15 PM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
On my laptop (Asus G73JH) the usb ports on closer to the battery pack are the high power ones.
bakchos is offline Find More Posts by bakchos
Old Oct 20, 2011, 04:34 PM
Joined May 2011
I don't know. This logic makes no sense to me though. Maybe on older laptops. But all ports should supply the same amount of power regardless if your a laptop or desktop plugged into the wall or running on battery.
Someone prove me wrong?
Old Oct 20, 2011, 04:39 PM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
They all provide the same amount of voltage, but they can't all supply the same amount of current. The USB standard specifies some value but most can supply more, and some devices require more.
Also, the PICkit has to be set up correctly to provide power to the RVOSD.
BushmanLA is offline Find More Posts by BushmanLA
Old Oct 20, 2011, 04:46 PM
Joined May 2011
Okay. Interesting I can see that. Thanks.
Old Oct 21, 2011, 02:49 PM
gitcho is offline
Find More Posts by gitcho
team n00b - captain
Canada, BC, Vancouver
Joined Aug 2011
also just bought an RVOSD5 for my easystar ... been reading these latest posts and glad to hear that I'm not the only one who can't connect all the wires from scratch blindfolded.
I've read through the instructions, but the wiring connections piece is a bit confusing ... the main instructions page has a broken link to wiring diagrams (database error). I have a few questions that diagrams would probably help clear up (eg. can i use the lead from the thunderbird 36a esc instead of the current sendor?) ... Anyone have any pictures/diagrams for a basic easystar wiring config?
gitcho is offline Find More Posts by gitcho
Old Oct 21, 2011, 10:50 PM
Joined May 2011
Got my servo wire in today and re did my wing and hid wires and the RVOSD
I'm trying to fix the videos so I can upload from today. I found a better capture program to use while I'm out on the field so I won't have to deal with that sh*t anymore.
Also quick question. When you land. How do you clear the summary screen?
Old Oct 22, 2011, 02:30 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
If you blip the throttle (>3a)the summary disappears
ommadawn is offline Find More Posts by ommadawn
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
