Old Oct 19, 2011, 02:17 PM
nft343 is offline
Find More Posts by nft343
Joined Mar 2011
I THINK that's for a RX which can pass the PPM stream directly out, not as separate channels.
Originally Posted by Bear_Pants View Post
I have a question regarding this
"5- Make sure to remove the propeller from the motor at this stage. Connect GPS and all inputs to RVOSD:
RVOSD defaults to "regular" inputs. This means each channel of the receiver has to be connected to separate input channels on RVOSD. If you want to use a PPM ready receiver you can use the “PPM configuration” explanation, else configure inputs and outputs like this:"
Now. I'm not sure I understand. I do have a dragon link that is run off PPM. I'm just not sure I follow what this part means. I have everything hooked up like normal (lots of wires). Not sure what the PPM configuration is for.
nft343 is offline Find More Posts by nft343
Old Oct 19, 2011, 02:26 PM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Originally Posted by lrrps View Post
On the Range Video site, I found this: RVOSD5 main Main_5.05S Release date: 23/July/2011
Did I miss something?
I didn't find the 5.06 thingy.
Right below the 5.05 is the 5.06 thingy....
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Oct 19, 2011, 02:28 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Originally Posted by ScooterInVegas View Post
Yep. 5.06 was released this month.
Thanks I found them.
Is there a sequence between main and video board when updating ?
Firatp is offline Find More Posts by Firatp
Old Oct 19, 2011, 02:29 PM
Bear_Pants is offline
Find More Posts by Bear_Pants
United States, NJ, Manchester
Joined May 2011
Hm. Not sure. Would be cool to lessen up the wires
Bear_Pants is offline Find More Posts by Bear_Pants
Reply With Quote  (Disabled)
Old Oct 19, 2011, 02:31 PM
Village Idiot!
Joined Apr 2011
Yes the DL has PPM on ch 9 I think. If you have the new Rx, its the top and bottom pins, not the middle.
Old Oct 19, 2011, 02:34 PM
Joined May 2011
Okay. I'm going to double check that picture posted in the thread.
So this means I don't need all those servo wires everywhere? Just one wire from channel 9 into my ppm1 on RVOSD?
I'd also need to hook up a wire for the RSSI as well to right?
Bah I'm confused now.
Channel 9 is not marked but It's stated that it's a PPM channel
There is a separate PPM channel for a servo wire to plug into. However I'm not positive on what is the correct way. This is a new receiver.
Old Oct 19, 2011, 02:39 PM
Village Idiot!
Joined Apr 2011
Yep
Old Oct 19, 2011, 02:50 PM
Joined May 2011
Yep
Cool it works! Going to carefully hook up the RSSI... can I do it with the servo wire that came with my rvosd?
Old Oct 19, 2011, 02:52 PM
Village Idiot!
Joined Apr 2011
I dont know.........can ya?
Yes
Old Oct 19, 2011, 02:54 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Yes, 1 (3 servo wire) for ppm, 1 (1 wire) for rssi, and 1 (3 servo wire) for current sensor. The you servos and thorttle connect to the rvosd.
man2000me is offline Find More Posts by man2000me
Old Oct 19, 2011, 03:01 PM
Firatp is offline
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
My question to whom succeeded flash RVOSD
I made the connection and selected device family but it says "No device detected. Ensure proper capacitance on VDDCORE/VCAP pin. "
Do I need to some setting additional?
Old Oct 19, 2011, 03:16 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
Read the RSSI configuration part of this instructions: http://rangevideo.com/forum/showthre...progress...%29
Elcheapo is offline Find More Posts by Elcheapo
Old Oct 19, 2011, 03:17 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
Make some side pressure by setting some inclination on the pickit so it makes better contact with the board.
Old Oct 19, 2011, 03:20 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
I did also have problems getting it to connect. But after many attempts, it finally worked out.
SpookiePower is offline Find More Posts by SpookiePower
Old Oct 19, 2011, 03:31 PM
Joined May 2011
Figured it out. Should be set to fly. When it doesn't rain :\
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
