Old Oct 19, 2011, 02:08 AM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Originally Posted by Firatp View Post
Hi again,
How can I learn my RVOSD's firmware version?
When you start the OSD, it will show the firmware # for the first couple of sec.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Oct 19, 2011, 02:17 AM
Bear_Pants is offline
Find More Posts by Bear_Pants
United States, NJ, Manchester
Joined May 2011
Video 5.03 Sensor 5.06
Am I up to date?
Bear_Pants is offline Find More Posts by Bear_Pants
Reply With Quote  (Disabled)
Old Oct 19, 2011, 02:52 AM
Village Idiot!
Joined Apr 2011
Am I up to date?
Yep. 5.06 was released this month.
Old Oct 19, 2011, 02:54 AM
Joined May 2011
Okay. So yeah with my prop on the vibrations are horrible. It's pretty chipped up prop though. I have the OSD wrapped in foam and velcrod not too tightly. Vibrations all the way up. I guess I'll just see how she does in the air.
Old Oct 19, 2011, 04:09 AM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Hello,
It is not shown in Rangevideo.com. Where is it published?
thanks
Firatp is offline Find More Posts by Firatp
Old Oct 19, 2011, 04:12 AM
Village Idiot!
Joined Apr 2011
Hello,
thanks
Its over at ........ Rangevideo.com. In the "Latest Firmare Version" thread,
http://rangevideo.com/forum/showthre...n-for-your-OSD
Old Oct 19, 2011, 11:12 AM
m60power is offline
Find More Posts by m60power
Joined Sep 2011
On mine, its from the Tx/camera battery. But hooked up to one battery would give you your pack voltage and you can set the mAh warning setting to compensate for only reading one pack.
Wait, I forgot about Amp Load. I dont know it each pack will "see" the whole amp load or not. Voltage yes, amp load, I dont know.
Are there any other options for current sensors that can handle the higher voltage and current? would the eagletree elogger v4 work with rvosd.
m60power is offline Find More Posts by m60power
Old Oct 19, 2011, 12:56 PM
m60power is offline
Joined Sep 2011
Or does range video offer a stronger current sensor?
Old Oct 19, 2011, 01:01 PM
Village Idiot!
Joined Apr 2011
Don't think so. 99% of users dont use that many amps. Have you signed up on their forum? They are in there more of the time to answer questions.
Old Oct 19, 2011, 01:09 PM
Joined May 2011
scooooooooooottteeeeeeeeeeeeeerrrrrrrrrrrrrrrrrrrr rrrr
Old Oct 19, 2011, 01:15 PM
Village Idiot!
Joined Apr 2011
Pants be of bear?
Old Oct 19, 2011, 01:17 PM
Joined May 2011
Pants be of bear?
WEEEEEEEEEEEEEEEEEEEEEE
just got my dragonlink.
It's raining like a b*tch though.
Old Oct 19, 2011, 02:37 PM
m60power is offline
Joined Sep 2011
I'm asking about it on their forum:
http://rangevideo.com/forum/showthre...ring-questions
I haven't got an answer yet regarding current sensor options. Are there any other OSDs out there that include an IMU autopilot that can do more than just RTH? (heading hold, position loiter, waypoints, etc...) I might just have to go with eagle tree because I know their elogger current sensor is rated for something like 100 amps and 80 volts. Although I don't think they have the awesome autopilot stuff that RVOSD V5 has...
Old Oct 19, 2011, 02:48 PM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
On the Range Video site, I found this: RVOSD5 main Main_5.05S Release date: 23/July/2011
Did I miss something?
I didn't find the 5.06 thingy.
lrrps is offline Find More Posts by lrrps
Old Oct 19, 2011, 02:56 PM
Joined May 2011
I have a question regarding this
"5- Make sure to remove the propeller from the motor at this stage. Connect GPS and all inputs to RVOSD:
RVOSD defaults to "regular" inputs. This means each channel of the receiver has to be connected to separate input channels on RVOSD. If you want to use a PPM ready receiver you can use the “PPM configuration” explanation, else configure inputs and outputs like this:"
Now. I'm not sure I understand. I do have a dragon link that is run off PPM. I'm just not sure I follow what this part means. I have everything hooked up like normal (lots of wires). Not sure what the PPM configuration is for.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 10:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 11:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 05:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 01:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 03:51 AM
