Old Oct 15, 2011, 08:56 PM
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Originally Posted by jeff2215 View Post
How often is the FBW, Level Flight, or RTH used? Every time you fly?
Ya, FBW and RTH most flights. RTH helps because I fly at night a lot.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Oct 15, 2011, 09:13 PM
jeff2215's Avatar
United States, MI
Joined Dec 2002
Thanks guys, you just cost me $300 ;-) Order placed.
jeff2215 is offline Find More Posts by jeff2215
Old Oct 15, 2011, 09:16 PM
United States, NJ, Manchester
Joined May 2011
So how can I go about making a switch for RTH? I guess I can live without the menu switching. Kinda sucks though. I want to atleast toggle RTH if something is going wrong. Or have it RTH if I disconnect my transmitter. Being able to use FBW would have been cool. Stupid fly sky.
Bear_Pants is offline Find More Posts by Bear_Pants
Reply With Quote  (Disabled)
Old Oct 15, 2011, 09:19 PM
Village Idiot!
Joined Apr 2011
My RTH is on my throttle. Its this type of stuff I will tell you about later.
Old Oct 15, 2011, 09:21 PM
Joined May 2011
Okay sweet! Your using a futaba right? Monday all my stuff should be in. (Including my DL hopefully)
Old Oct 15, 2011, 09:40 PM
Village Idiot!
Joined Apr 2011
Originally Posted by Bear_Pants View Post
Stupid fly sky.
If you have to, use one of the turn nobs on the top. CCW for RTH and CW for flight menu.
Old Oct 15, 2011, 10:11 PM
Joined May 2011
I could try that actually. Will it know center? Great idea! All the knobs are assigned to channels so that will def work.
Old Oct 15, 2011, 10:56 PM
Village Idiot!
Joined Apr 2011
Or CCW for FBW and RTH on the throttle.
Old Oct 16, 2011, 12:28 AM
Joined May 2011
RTH on throttle would me hitting say the trim so it goes past what it is normally set at? Either way the RVOSD only has one aux input. I was hoping to be able to flip through screens and choose FBW and RTH some how.
I have a throttle hold switch in which I can adjust. And also failsafes in the TH9X. Although I never set them up before.
Old Oct 16, 2011, 12:41 AM
Village Idiot!
Joined Apr 2011
You can do all that with the aux channel (nob)
RTH on the throttle would be WOT.
Old Oct 16, 2011, 01:19 AM
Joined May 2011
Ah got you! Thanks. Basically just get in the habit of not giving her full throttle on launch and your good to go I'd imagine.
(as soon as you let off throttle from WOT it will turn RTH off)
cool
Old Oct 16, 2011, 03:51 AM
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
It would be a really good idea, if you are able to switch through the menus.
Each time you trim your plane, you should also enter the menu and "set neutrals" for level flight, if you want to use RTH - That's what I have been told.
SpookiePower is offline Find More Posts by SpookiePower
Old Oct 16, 2011, 05:13 AM
Joined Jun 2009
I have installed the lastest firmware 5.06 and tried to reduce vibrations, but I'm not sure if the vibrations are low enough to try RTH for the firste time.
I have recorded my last flight, and if you skip to 05:51, you will see the Debug screen.
FPV RVOSD Gen.5 (6 min 31 sec)
Old Oct 16, 2011, 10:34 AM
Village Idiot!
Joined Apr 2011
Debug screen looks good. Try the RTH. The bar was only maxed at 1.91 throttle, your "cruse" throttle should be set a lot lower down where the bar looked good. You should be OK.
Old Oct 16, 2011, 11:51 AM
Joined May 2011
I'll see what I can do. Would be much easier to trim my plane out if I can set neutrals in the air.
Discussion Maiden Reports 12345 Arizona Model Aviators 466 Apr 23, 2013 06:29 PM
Help! RVOSD thermal sensors rcmonster99 Video Piloting (FPV/RPV) 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
