Old Oct 05, 2011, 02:43 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
You have to have a rangevideo account to see those jumper pictures. Here they are (see picture names):
boopidoo is offline Find More Posts by boopidoo
Old Oct 05, 2011, 02:45 AM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Originally Posted by man2000me View Post
Looks good on the AHI. It that was bouncing around then I would say you have a problem.
Try it, Turn it on and if it act strange then turn it off.
Also make sure your plane is trimed to fly at 8amps level with no stick input. Then set your "set neutrals" to that. According to you video you should set your cruise throttle to 1.47ms. And maybe set the glide throttle to 1.25-1.35 (that is a guess.
So each time I trim my plane, I have to enter the menu and "Set neutrals" ?
What is the difference between cruise throttle and glide throttle ?
SpookiePower is offline Find More Posts by SpookiePower
Old Oct 05, 2011, 02:46 AM
Joined Jun 2009
Originally Posted by ommadawn View Post
That looks great to me. Try it with FBW first just to prove to yourself. It will make you comfortable about giving up control to the OSD.
Looking Good!
Cheers
Frank
I'll try FBW first, and then RTH if it seems to work perfect.
But when I fly FBW, the OSD only helps me to keep the plane level, it does not use throttle - is this correct ?
Old Oct 05, 2011, 04:25 AM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
can the OSD itself be used as a quad stabilization too?
wallaguest1 is offline Find More Posts by wallaguest1
Old Oct 05, 2011, 05:39 AM
ommadawn is online now
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Hi Spookie,
Each time you change the trim of your plane, the autopilot needs to know what it is, so it can set the control surfaces to hold the new trimmed position. Once the plane is trimmed for straight and level you should set neutrals in the OSD A/P menu. This is needed every time you make changes to the trim the plane for whatever reason, but when its flying straight you shouldn't need to retrim. Don't forget to use the "Save Settings" after landing.
Cruise throttle is what you want the A/P to run the motor at when it needs to climb to your cruise altitude. Glide throttle is what you want the motor to run at when the plane is above the cruise altitude and descending. Usually you just set it to stop the motor and glide.
FBW doesn't change the throttle. All the stabilization modes allow you to use the motor. RTH is the only one that manages the throttle.
ommadawn is online now Find More Posts by ommadawn
Old Oct 05, 2011, 05:45 AM
Joined Jun 2009
Thanks Ommadawn
I have another question - there is a number just above LOS on the F16 screen, that shows almost the same as LOS. But what does these numbers mean ?
Old Oct 05, 2011, 05:49 AM
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
LOS is line of sight distance. The distance between you and the plane. The other distance is across the ground, to a spot on the earth directly beneath the plane. When you are directly overhead your ground distance will be zero and your LOS will be the same as your altitude.
Old Oct 05, 2011, 05:50 AM
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
Im going to start charging $$ for this soon
Old Oct 05, 2011, 06:05 AM
ptuxbury is online now
Find More Posts by ptuxbury
ptuxbury's Avatar
Joined Jan 2006
Yes, thank you ScooterInVegas and Boopidoo.
Just to be clear, I did read the instructions over several times. What confused me was the terminology - "enabled" vs "disabled". So I did a search on this thread and saw Elcheapo say to remove the jumper in post 253. That is why I asked whether or not it should be removed entirely.
So, back to the terminology, does "enable" mean that we are enabling the main battery to power everything (not just ESC, motor, servos, but also the RVOSD, camera, and vtx), and "disable" mean that the main battery will only be used to power ESC, motor, servos (i.e. we are disabling the main battery from powering the RVOSD, camera, and vtx), in which case we will need a secondary battery to power OSD, camera, and vtx?
If I had the answer to that, then everything would be clear to me.
Tux
ptuxbury is online now Find More Posts by ptuxbury
Old Oct 05, 2011, 12:31 PM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Tux
You just gave the correct answer to your own question.
lrrps is offline Find More Posts by lrrps
Old Oct 05, 2011, 01:44 PM
Joined Jun 2009
Im trying to upgrade the mainboard firmware right now - but the PICkit 2 software will not detect the PICkit 2 programmer.
When I open up PICkit 2 program - it says PICkit 2 found and connected.
But when I select the right device it says - No device detected. Ensure proper capacitance on VDDCORE/VCAP pin. But the Target and Busy LED turns on for just a second.
What is going wrong here ?
Old Oct 05, 2011, 01:50 PM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Do you have the lastest Pickit software v2.61?
Gary Evans is offline Find More Posts by Gary Evans
Old Oct 05, 2011, 03:18 PM
Joined Jun 2009
I did use the latest software - but after many attempts it worked finally.
Old Oct 11, 2011, 01:26 AM
Bear_Pants is offline
Find More Posts by Bear_Pants
United States, NJ, Manchester
Joined May 2011
I'm thinking of getting this. Mostly because of the horizontal attitude indicator. Can this be set up to work with my flying wing? (elevons)
Bear_Pants is offline Find More Posts by Bear_Pants
Reply With Quote  (Disabled)
Old Oct 11, 2011, 02:27 AM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Yep. The "horizontal attitude indicator" as you call it is called AHI.
AHI my butt, wait till you flip a switch and the plane turns around and comes home!! And Fly By Wire (FBW) in the wind, the plane flys like there is no wind. Cool...
ScooterInVegas is offline Find More Posts by ScooterInVegas
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
