Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
Lars. |
Joined Apr 2006
Don't get me wrong
the danger is not for your OSD i don't think it will hurt the OSD but if you by accident connect an empty and a fully charged battery with a Y connection then the current in the wires will be wherry big and the wires will be wherry hot and the batteries can cats fire when the full battery trying to charge the empty in 2 seconds, so if you newer forget to check voltage before connecting and voltage is only 0,1-0,2 V difference you will be safe, just don't forget to check. ![]() Manny people do it daily. Lars. |
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
I have been working on my vibrations and would like to hear if the vibrations are low enough to use RTH ?
If you take a look at my video, and skip to 04:38 you will see the debug screen while I'm airborne.
Looks good on the AHI. It that was bouncing around then I would say you have a problem.
Try it, Turn it on and if it act strange then turn it off. Also make sure your plane is trimed to fly at 8amps level with no stick input. Then set your "set neutrals" to that. According to you video you should set your cruise throttle to 1.47ms. And maybe set the glide throttle to 1.25-1.35 (that is a guess. |
Go to the link for the G5 instructions and scroll down till you see "RVOSD, camera and video Tx power management:"
There are pictures showing you how to set your jumpers. You should read the whole two times before even setting up your G5. http://rangevideo.com/forum/showthre...progress...%29 This is from the instructions, which you should have read.. The OSD will supply power to the camera and video transmitter. If the voltage selection jumpers are set to 12V RVOSD will route the battery with the highest voltage to power the device (camera or video Tx associated with the selected jumper). So if the main battery voltage is more than 3S(12V), user will have to change the disable jumper to isolate the main battery and provide a 3S battery on the auxiliary battery input port. When the voltage selection jumpers are set to 5V RVOSD will supply power from an internal 5V regulator. However if any of the jumpers are set to 12V you have to follow the above recommendations. Only when both jumpers (camera and video Tx) are set to 5V the OSD can work with any battery combinations in the 2S-6S range. This are few examples of jumper positions: Main battery enabled, 12V VTx, 12V Cam: http://rangevideo.com/forum/attachme...8&d=1315418224 Main battery disabled, 12V VTx, 12V Cam: http://rangevideo.com/forum/attachme...9&d=1315418238 Main battery enabled, 12V VTx, 5V Cam: http://rangevideo.com/forum/attachme...0&d=1315418254 Main battery enabled, 5V VTx, 12V Cam: http://rangevideo.com/forum/attachme...1&d=1315418267 Main battery enabled, 5V VTx, 5V Cam: http://rangevideo.com/forum/attachme...2&d=1315418277 |
| Thread Tools | |
| Discussion Maiden Reports | 12345 | Arizona Model Aviators | 466 | Apr 23, 2013 06:29 PM |
| Help! RVOSD thermal sensors | rcmonster99 | Video Piloting (FPV/RPV) | 16 | Jun 20, 2011 10:21 AM |
| Discussion Weekend weather reports | neck | Arizona Model Aviators | 13 | Jun 10, 2011 04:59 PM |
| Discussion where are the Joe Nall horror "reports? | guy hanson | Radios | 49 | May 18, 2011 12:06 PM |
| Discussion Finally Fixed the Country Reports | daboz | Dynamic Soaring | 5 | May 16, 2011 02:51 AM |
