Old Sep 17, 2011, 01:56 PM
hobbyboy is offline
Find More Posts by hobbyboy
United States, AK, Wasilla
Joined Nov 2001
Well, at least it is on your list.......... :-) Is the update for bugs or cool new things?
hobbyboy is offline Find More Posts by hobbyboy
Old Sep 18, 2011, 04:43 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
Here's a flight flown with waypoints.
Waypoint Flight with RVOSD G5 (5 min 48 sec)
vertcnc is offline Find More Posts by vertcnc
Old Sep 18, 2011, 07:15 PM
hobbyboy is offline
Joined Nov 2001
vertcnc
It looks like you were gliding the whole flight? It also looks like you might be using throttle cut to activate RTH or are you just shutting off the TX? I like that airframe. Have you been happy with it?
Bob
Old Sep 18, 2011, 07:38 PM
vertcnc is offline
Illinois, USA
Joined Aug 2009
It flying under power, I had a problem with wire for current sensor. Throttle level is controlled by OSD, depending if it needs to climb or decsent. RTH and Waypoints are activated by a 3 pos. Switch.
Foamaroo is a nice platform for FPV. Lots of room for gear. I run a 8000 mah battery for long range flights. I have been out 7 miles with out a problem.
Old Sep 18, 2011, 08:31 PM
hobbyboy is offline
Joined Nov 2001
Ok, I figured your Foamaroo could not be that frugal with power. I know how the RVOSD 5 works , I have 2 of them :-)
Old Sep 19, 2011, 12:51 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Wow that video is really low quality, what do you use to record it? I'm sorry but I just can't watch it, I get a headache.
boopidoo is offline Find More Posts by boopidoo
Old Sep 19, 2011, 06:23 AM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Today I did a test on the ground, with and without the prop. When reaching WOT (with the prop) the plane was making some small jumps, and the vibrations seems to be too much. Without the prop, it seems fine...I think.
I have not done a balance test of the prop.
Info:
Plane - Skywalker
Motor - Scorpion SII-3014 1040KV
Lipo - 4s
Prop - TGS Sport 9x6E Precision propelle
Testing vibration - RVOSD Gen.5 (0 min 45 sec)
Is it possibly to test the vibration while airborne ? I'm not sure if I stil can control the plane while looking at the debug screen ?
SpookiePower is offline Find More Posts by SpookiePower
Old Sep 19, 2011, 07:27 AM
boopidoo is offline
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Yes, you can fly (ie control the model) and look at the debug screen at the same time.
Old Sep 19, 2011, 08:33 AM
vertcnc is offline
Illinois, USA
Joined Aug 2009
Lawmate. I not really good at post processing these.
Old Sep 19, 2011, 04:44 PM
Joined Jun 2009
When I switch between the different screens, and reach the menu-screen, then I will not be able to control the plane - is this correct ?
Old Sep 19, 2011, 05:02 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Yes. The plane holds its last control stick positions. In order to change any menu items you need to have any of the automatic flight modes, like FBW, turned off as well.
ommadawn is offline Find More Posts by ommadawn
Old Sep 19, 2011, 05:07 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
This is true, except that if you enter the menu with any stabilization mode activated, some menus cant be changed but at the same time the autopilot will temporary set level flight while you are in the menu, this will let you change the menus you can in a more relaxed way.
Elcheapo is offline Find More Posts by Elcheapo
Old Sep 19, 2011, 05:08 PM
Joined Jun 2009
I have not yet been airborne with my RVOSD, but on my first flight, I do not plane to change anything in the menu settings. Just selecting the debug screen to see the vibration while flying around. But when going through the different screens, I guess I just have to quickly enter and exit the menu screen, to regain control of the plane.
Old Sep 19, 2011, 05:13 PM
Joined Jun 2009
Just to be sure about the difference between Stabilizaton and Autopilot. Stabilizaton is where the plane helps you control the plane, and this type of stabilization is selected in the menu - right ? Autopilot, is where the plane take total control of the plane - and this is activated by using a 3-position-switch, or turning off the Tx - right ?
Old Sep 19, 2011, 05:19 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
You can manually activate any of the stabilization modes.
When you toggle the auxiliary switch it will enable-disable the mode set on the menu Aux autopilot mode. You can call this "Stabilization" or "autopilot" mode.
If Rc link is lost and the OSD configured to detect it, then the system will force Return home.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
