Old Sep 08, 2011, 11:44 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Elcheapo, what's the current sensor type of the latest RVOSD5 pack?
Thanks.
lrrps is offline Find More Posts by lrrps
Old Sep 08, 2011, 12:07 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
Elcheapo: How do I get any customer service from you RMA101576
You have to contact Vova at Rangevideo.
Thanks.
70A (absolute G5)
Elcheapo is offline Find More Posts by Elcheapo
Old Sep 08, 2011, 12:10 PM
DIG2fly is offline
Find More Posts by DIG2fly
work all night and fly all day
DIG2fly's Avatar
USA, CA, San Fernando Valley
Joined May 2009
can you forward my requst to him for me since you speak for RV
DIG2fly is offline Find More Posts by DIG2fly
Old Sep 08, 2011, 12:11 PM
datyip is offline
Find More Posts by datyip
Spain
Joined May 2011
Is in the "Cruise altitude" that you define your RTH pre set altitude?
And about the radius? Can also be defined or is it fixed?
datyip is offline Find More Posts by datyip
Old Sep 08, 2011, 12:53 PM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
70A (absolute G5)
Thanks.
Old Sep 08, 2011, 12:58 PM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
I tried to set rx input type to combined PPM then entered PPM config, set to PPM1 but the value of each chanel won't change and I can't make the controls move.
Controls work fine if I select regular Rx input type.
Is that normal?
Old Sep 08, 2011, 03:17 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Are you sure your Tx uses the PPM signal ?
SpookiePower is offline Find More Posts by SpookiePower
Old Sep 09, 2011, 01:01 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
I have the Spektrum DX7, not sure it uses PPM, can someone confirm pls?
Old Sep 09, 2011, 03:46 AM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
I don't think so.
You need PPM out on the receiver. Most general use RC receivers do not have this.
BushmanLA is offline Find More Posts by BushmanLA
Old Sep 09, 2011, 11:48 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Originally Posted by BushmanLA View Post
I don't think so.
Thanks, that's why it didn't work.
I have bought a used T9CP, that one will work.
Old Sep 09, 2011, 02:00 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
Yes, cruise altitude does define the RTH preset altitude.
The actual radius is predefined to 0, so the autopilot should hit "home" as close as possible and keep flying on eight figure patterns around it.
Old Sep 09, 2011, 02:44 PM
razorseal is offline
Find More Posts by razorseal
razorseal's Avatar
United States, FL, West Palm Beach
Joined Nov 2010
So how many channels are needed? The FAQ says only 1.
Let's say 3 ch plane (elev/aileron/throttle)
I got 3 channels left for my dx6i
1 would go to OSD. What can the rest 2 be used for?
And how can I set the autopilot and osd menu thing? How do you guys assign them?
razorseal is offline Find More Posts by razorseal
Old Sep 09, 2011, 04:20 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
You need one Ch for the osd with a 3 pos switch to control the flight modes and change screens. The other 2 would be to control pan and tilt of the camera if you want.
ommadawn is offline Find More Posts by ommadawn
Old Sep 09, 2011, 04:58 PM
razorseal's Avatar
Joined Nov 2010
Hmm.. Whatiff the tx being used (like my dx6i) doesn't have a 3 pos switch?
Maybe I'll get a dedicated turnigy 9x, I *think* that has a 3 pos switch.
Do you guys do pan and tilt btw?
Left stick controls throttle (and maybe rudder if equipped) and the right control elev/aileron
How do you pan and tilt?
Like the turnigy 9x has these little knobs up top. Are they another channel? Those can be good for pan and tilt.
Old Sep 09, 2011, 05:10 PM
BushmanLA's Avatar
Joined Dec 2005
I use a 9x and love it. It has a three position switch.
I don't know what you can and cant assign with the default firmware because I use er9x firmware.
Most people who use pan/tilt with 4 channel planes are using head trackers probably. But yes, you can use the knobs for pan tilt. It's a little awkward though.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
