Old Aug 29, 2011, 04:37 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Originally Posted by ommadawn View Post
Be very careful any time you are messing with the RVOSD and you have a prop on the motor. If you test RTH/failsafe on the ground your motor WILL start.
To be safe, always expect the motor to start any time you change anything. Its probably best to leave your prop off until you are fully conversant with the user interface. I still have unexpected motor starts occasionally.
Cheers
Frank
Right it's like a gun, it has to be considered loaded with a round in the chamber.
lrrps is offline Find More Posts by lrrps
Old Aug 29, 2011, 02:40 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
I'm not sure how short I should make the servo wires that are connected to the RVOSD. Are your wires so short, that you have to let the RVOSD stay inside the plane, while you connect/remove the servo wires - or do you have them as long, so that you can take the RVOSD out of the plane, while all the servo wires still are connected ?
I think that it is much more easy to work with the RVOSD if you can take it out of the plane, still with all wires connected. But I'm not sure if these long wires, will add more vibration than needed.
I'm flying a skywalker.
SpookiePower is offline Find More Posts by SpookiePower
Old Aug 30, 2011, 02:27 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
IMHO long wires won't induce more vibes, they put more weight but make easier to work with.
Old Aug 30, 2011, 03:23 AM
ommadawn is online now
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Its generally good practice to keep all wires as short as posible to reduce the lkelihood of picking up interference. This must be balanced with practicality though. If your leads are to short you will struggle and likely end up with plugs getting half pulled out.
Just keep it tidy.
ommadawn is online now Find More Posts by ommadawn
Old Aug 30, 2011, 03:50 AM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Hi,
I am near future RVOSD5 user. I have just ordered mine and waiting fir delivery.
Experienced user, do you have any advice for me fir initial setup.
One quick question!
Does RVOSD support antenna tracking?
Firatp is offline Find More Posts by Firatp
Old Aug 30, 2011, 04:14 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
@Firatp
Read, understand and follow the manual!
Also, take it slow. If you haven't flown FPV before learn to do so before even thinking about installing the RVOSD. Make sure everything works on the ground and make rangechecks to identify and eliminate as much RFI as you can.
boopidoo is offline Find More Posts by boopidoo
Old Aug 30, 2011, 08:50 AM
GavinW is offline
Find More Posts by GavinW
Joined Oct 2009
GavinW is offline Find More Posts by GavinW
Old Aug 30, 2011, 10:42 AM
hobbyboy is offline
Find More Posts by hobbyboy
United States, AK, Wasilla
Joined Nov 2001
It works fine with ChainLink on PPM.
hobbyboy is offline Find More Posts by hobbyboy
Old Aug 30, 2011, 10:46 AM
Joined Jun 2009
Just keep it tidy.
Thanks I would really like to be able to take the OSD, out of my skywalker, without removing any of the wires first. But I definitely have to make the wires shorter than they are now.
Old Aug 30, 2011, 12:47 PM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Originally Posted by Firatp View Post
Hi,
One quick question!
Remember that Range Video has their own support forums. You can get quick answers there.
http://www.rangevideo.com/forum/forumdisplay.php?f=3
Antenna tracking is not supported at the moment. Supposedly a ground station is in the works.
BushmanLA is offline Find More Posts by BushmanLA
Old Aug 30, 2011, 10:08 PM
GavinW is offline
Joined Oct 2009
Old Aug 31, 2011, 02:28 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
Do you by any chance know how much the RVOSD5 weighs?
RVOSD5 board = 30gr
GPS+cable = 12.6gr
Current sensor = 10.8gr
Elcheapo is offline Find More Posts by Elcheapo
Old Aug 31, 2011, 09:14 PM
GavinW is offline
Joined Oct 2009
Originally Posted by Elcheapo View Post
RVOSD5 board = 30gr
GPS+cable = 12.6gr
Old Sep 02, 2011, 03:05 AM
massimo is offline
Find More Posts by massimo
massimo's Avatar
Joined Nov 2001
Hi guys ,
I already asked this to Vova but he is very busy and have not received your response. I wanted to know if the rth of rvosd5 also works with only 3 channel models (without ailerons). I appreciate your response.
massimo is offline Find More Posts by massimo
Old Sep 02, 2011, 07:38 AM
BushmanLA's Avatar
Joined Dec 2005
Originally Posted by massimo View Post
Hi guys ,
Yes. You can exchange the normal aileron out for rudder out in your case.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 10:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 11:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 05:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 01:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 03:51 AM
