Old Jan 21, 2013, 02:32 PM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Hi ..
Has anyone of you guys experienced this ...
Now for some reason .. each time I power on my RVOSD .. it defaults to FBW mode ... I remember it didn't do that before .. an clues .. ???
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Jan 21, 2013, 02:42 PM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
Use the remote to go into menu and save after you have made changes.
MrBen. is offline Find More Posts by MrBen.
Old Jan 21, 2013, 02:50 PM
Joined Nov 2006
I remember I did that ...
Khaled
Old Jan 21, 2013, 11:06 PM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
Frank, Your smile says it all! You still had several hundred feet to spare
picard10th is offline Find More Posts by picard10th
Old Jan 22, 2013, 08:18 AM
Joined Nov 2006
Today I flew my ZII in FBW mode ... I had to turn down the stabilization roll gain to 25, and stabilization pitch gain to 30 ... but I almost had no control over the plane .. I was pushing the sticks all the way to barely make it want to turn ... I'm not sure if it is supposed to do that ... I had to increase the dual rate to barely have some control ...
Any hints are greatly appreciated
Thanks a lot
Khaled
Old Jan 22, 2013, 10:52 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Im just getting ready to get my rvosd all setup on the ground in my z2 then maiden. Ill watch to see any info u get... Any other z2 advice or whatch out fors lol
elliott000 is offline Find More Posts by elliott000
Old Jan 22, 2013, 11:08 AM
cabster101 is offline
Find More Posts by cabster101
United States, TX, Austin
Joined Jul 2011
I had the same issue with my Z2. I set my max pitch and max roll angle as high as it would go (60). That will give you more control.
Thanks a lot
Khaled
cabster101 is offline Find More Posts by cabster101
Old Jan 22, 2013, 12:05 PM
Joined Nov 2006
Thanks a lot
Khaled
Old Jan 22, 2013, 12:25 PM
Joined Nov 2006
AHI drifting while standing still ???
I've noticed something else .. today .. after I landed ... the AHI was tilted a bit although I'm sure my ZII was sitting on flat ground ... I remember seeing a similar issue over the range video forum from a gent who has just upgraded to 5.09/5.06 Main/Graph
I still have the stock firmware 5.07/5.05 on 5.1 hardware ....
the funny thing is that my 1st RVOSD on my lost ZII ... didn't have any drift
I wonder why it is that way
1-Needs a firmware fix
2-Vibration ... but it was standing still on a flat ground
3-temperature difference ... but that was near the end of the flying session .. more than an hour and a half
4-RVOSD is not seated properly ... but I'm sure it is setting dead flat on its anti-vibration mount
Any hints are greatly appreciated ...
Thanks a lot
Khaled
Old Jan 23, 2013, 03:44 PM
Joined Nov 2006
1-Make sure your ZII flies correctly and comfortably by LOS and with no RVOSD ..
2-Make sure your ZII flies correctly and comfortably by LOS and with no RVOSD
3-Make sure your ZII flies correctly and comfortably by LOS and with no RVOSD
4-Then start Simple with the RVOSD as it is really complicated in a good way .. take your time and try to enjoy the learning curve ...
5-Read the RVOSD manual several times and the forum ... it's the RVOSD not the ZII you should worry about ...
Have fun and get back in one piece .. also turn off the RTH when you start until you are ready to test it ...
Khaled
Old Jan 25, 2013, 08:33 AM
chillybee is offline
Find More Posts by chillybee
Plainfield, New Jersey, United States
Joined Mar 2003
Is there anyway to set the autopilot to have 3 throttle setting? If the plane is too high, lower the throttle to predetermined descent power. If the plane is at the correct altitude, keep the throttle at the predetermined cruise power. If the plane is too low, set the throttle to predetermined climb power. Or does it already do what I described and I just don't know how to enable it?
chillybee is offline Find More Posts by chillybee
Old Jan 30, 2013, 04:38 PM
martyester is offline
Find More Posts by martyester
Joined Jun 2012
Khaled,
How are your x, y, and z vibrations? Are they fairly calm?
martyester is offline Find More Posts by martyester
Old Feb 02, 2013, 11:29 PM
jeff2215 is offline
Find More Posts by jeff2215
jeff2215's Avatar
United States, MI
Joined Dec 2002
I'm trying to get more stability out of my RVOSD. There was only about a 5mph in this video. But the plane seemed to roll alot. Do I need to reduce my roll gain? reset my neutrals? My AHI was slightly tilted to the left as I was flying and wasn't completely level so I don't know if I was fighting that and causing the rolling. Any suggestions would be appreciated!
http://www.youtube.com/watch?feature...&v=vIxyw8D3tag
jeff2215 is offline Find More Posts by jeff2215
Old Feb 03, 2013, 12:41 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
N ice clip! A view of the OSD/flight cam feed would be helpful.
Getting the AHI to indicate level with the wings level is essential. Otherwise the plane will bank until the AHI is level. It is not unusual to have the plane roll around a bit in FBW mode, as every time you put in a little bank with the ailerons, as soon as you release the stick the stabilization will counter it and return the wings to level. It took me a while to re learn how to fly with FBW.
You can play with stabilization roll gain to tune for your particular plane.
ommadawn is offline Find More Posts by ommadawn
Old Feb 03, 2013, 08:47 AM
jeff2215 is offline
jeff2215's Avatar
United States, MI
Joined Dec 2002
Thanks. Currently I don't have anyway to capture OSD/Flight Cam feed. I'm thinking its a combination of things in particular AHI needing to be level. If weather holds up I will give it another go today. I had it once about a year ago and have lost the settings since. Thanks for the feedback.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
