Old Dec 29, 2012, 12:17 PM
MaximumBob is offline
Find More Posts by MaximumBob
I love the smell of elapor....
MaximumBob's Avatar
Setauket, New York
Joined Oct 2009
Originally Posted by ommadawn View Post
Great stuff Bob! Its a common problem.
The PCB connector is the GPS socket on the RVOSD top printed cct board. I pushed on my GPS plug too hard once and tore the thing clean off the board. Luckily it came away without damaging the tracks, so a buddy with SMD soldering skills reattached it for me.
I suggested checking that cos sometimes it gets damaged in a crash if the lead gets ripped out.
Cheers
Frank
Frank, going to order some spare gps cables from RV. thanks again for your advice. it prompted me to go looking through a bag-o-partz and i cant believe i found a gps cable. Hope the fpving is good down in OZ. In New York its cold, rainy and quasi-snowing out. If you are in Sydney, go have a Carlton Cold Lager and a Steak on me down at Philips Foot! HAppy New year
MaximumBob is offline Find More Posts by MaximumBob
Old Jan 01, 2013, 09:28 PM
Stunt Double is offline
Find More Posts by Stunt Double
Multi Rotor Maniac
Stunt Double's Avatar
Australia, VIC, Melbourne
Joined Oct 2007
Might try my luck here... The other day I flew my plane with RVOSD/dragon link and was getting some strange glitches. Each time I gave it high throttle input it would go into failsafe which triggered RVOSD RTH. The failsafes were lasting about 5 seconds each time then after I could regain control. I repeated it about 5 times in the air. When I landed I tried again with high throttle but couldnt replicate it. Other times ive had a radio glitch it was while flying far away and only last for less than a second.
My best guess is the ESC BEC failing. But im not 100% sure, could be the dragon link or radio as ive been having some glitches with a copter too. Any ideas?
Stunt Double is offline Find More Posts by Stunt Double
Old Jan 01, 2013, 10:43 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
You should look at the variables, if you can not replicate your problems at close range as you can at long range then the only variable is your rc link. I would be thinking for sure its your UHF. Especially seeing the new version problems with Dragonlinks reliability
Coyote64 is offline Find More Posts by Coyote64
Old Jan 01, 2013, 11:33 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Hi Guys,
Bit of a perdicament here. I fly an FPV Raptor with DragonOSD and the FY30 as well as a SkySurfer with the FY20 and a DragonOSD.
I really like dragonosd and am very comfortable with it. Buddy of mine uses the RVOSD and really likes it. What i like about the RVOSD is that it has the Stabilization built into it where as the DragonOSD i'd have to purchase an FY20 or FY30.
When you consider the cost of the DragonOSD and the FY30 it comes to about equal that of the RVOSD.
I plan on using this on my new Penguin. Help me decide guys.
blueprint is offline Find More Posts by blueprint
Old Jan 02, 2013, 04:31 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Have you done a range check? I recently had a Mk1 DL Rx fail on me. It would go out of range at about 1.5km.
Were you pointing the Tx antenna at the plane?
How far away was it?
Try connecting your 5v servo rail to the aux V input. Its a great way to keep an eye on what is happening with your RC supply rails, if you suspect BEC problems.
Swap out the DL Rx if you have a spare.
Also check your 5v wires coming out of the BEC. I had a case where they twisted together and the insulation rode up, allowing a short on the 5v supply. Theres an interesting clip of it here, watch the 5v Aux in the top LH corner.:
Near miss (2 min 2 sec)
A video clip would help.
Hope this helps..
Cheers
Frank
ommadawn is offline Find More Posts by ommadawn
Old Jan 02, 2013, 10:16 AM
billyd60 is offline
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
Originally Posted by blueprint View Post
Hi Guys,
RVOSD5 is much easier to use and configure than the dragon osd. The dragon seems more like a college research project than a finished product. But it works well enough if you have the time to put into it. I have one on the shelf, but never could get it to work with the imu and a baro sensor at the same time, so I put it aside. At any rate the RVOSD is pretty simple and is well documented (in one place).
billyd60 is offline Find More Posts by billyd60
Old Jan 02, 2013, 01:38 PM
superevan is online now
Find More Posts by superevan
superevan's Avatar
United States, TX, Austin
Joined Aug 2007
Agreed, rvosd works right outta the box and is well documented.
superevan is online now Find More Posts by superevan
Old Jan 02, 2013, 01:45 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
thanks guys!
Old Jan 04, 2013, 07:13 PM
bakchos is online now
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
quick question guys, i have been using RVOSD5 for a long time but i am moving to another plateform, i will have
1- Aileron
2- Elevator
3- Throttle
4- Ruder
5- RVOSD 3 position switch
6- Pan
7- Tilt
8- Navigation lights on/off switch.
i wanted to have my flaps working since they are pre installed on the wings, but i am short on channels.
Anyway to have the OSD control the flaps and save a channel ?
otherwise i might reconsider the tilt and have only pan working.
what do you guys think ?
bakchos is online now Find More Posts by bakchos
Old Jan 04, 2013, 10:43 PM
ommadawn is offline
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
Connect rudder to your aileron channel on the Rx. Its not a completely satisfactory solution, but it works for me. Also, Nav lights??? I would sacrifice those before any flight controls.
Another option is Channel Wizard. I bought one but havent fitted it yet. It allows you to split a channel into multiple extra channels. Make your 8ch into 12 easy.
Channel Wizard adding 8 ch. via trainer (1 min 11 sec)
Cheers
Frank
Old Jan 04, 2013, 10:46 PM
2Vision-Air
bakchos's Avatar
Joined Aug 2009
http://www.youtube.com/watch?v=lE7slObvq_Q
Cheers
Frank
Thank you, but i like the nav lights, this plane is a night flyer and i want to be stealth when i decide to
i guess i can live with pan only, i will check that channel wizard !
thanks !
Old Jan 05, 2013, 12:55 AM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
1- Aileron
2- Elevator
3- Throttle
4- Ruder
6- Pan
7- Tilt
I would use ch8 for both flap and navigation lights.
Firatp is offline Find More Posts by Firatp
Old Jan 05, 2013, 07:56 AM
ommadawn is offline
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
Good idea. Switch up turns Nav lights on, switch down is flaps lowered..
Old Jan 05, 2013, 07:59 AM
2Vision-Air
bakchos's Avatar
Joined Aug 2009
Only problem is i need Nav lights to be on when i land/takeoff, so that means they would be off when i switch the flaps off.
Old Jan 05, 2013, 04:44 PM
ommadawn is offline
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
Easy. Use a latching push button operated by the servo arm. One press on, one press off.
Ideally you would also use a 3 position switch on the Tx.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 10:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 11:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 05:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 01:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 03:51 AM
