Old Nov 18, 2012, 05:17 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Is your Rc Rx failsafe set up to activate RTH? Perhaps the RVOSD isnt seeing the throttle FS, and FS channel for switch A is setting FBW.
ommadawn is offline Find More Posts by ommadawn
Old Nov 18, 2012, 05:50 PM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
It's DL and I can't remember if I've checked that so I'll go play with that, thanks for the pointer fingers crossed.
WitnessOnly is offline Find More Posts by WitnessOnly
Old Nov 19, 2012, 02:47 AM
Joined Jan 2010
Cheers Ommadawn for the tip, problem sorted... I think, do we see any problems with just using 'switch A' to activate RTH (the 2 mix option on the Futaba) and then just capturing that as my failsafe for the DL? if not we are good to go
Old Nov 19, 2012, 07:46 AM
ommadawn is offline
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
I reckon that should work. Set the throttle end point to about 120%, then save that as FS. Then reset end point to normal. Just remember to set all the other controls to neutral, not forgetting things like flaps airbrakes pan tilt etc. One time I thought I had everything set ok. At the field I tested RTH by switching off on the ground, and the flaps deployed
Old Nov 19, 2012, 03:59 PM
Joined Jan 2010
Hi Ommandawn,
Luckily, its my Skyfun, so the complexity is reduced somewhat but I'll go over it once more front to back just to make sure I've got it how I want it, this little unit has been away too long, I'm wanting to have it around for a while now, so 'measure twice, cut once'.
Of course the wind is blowing a gail and I've got work commitments today
Old Nov 20, 2012, 05:07 AM
Efti is offline
Find More Posts by Efti
Efti's Avatar
Norge, Rogaland, Bryne
Joined Oct 2011
Hi.
I did maiden this weekend with my bixler 2.
What is the jumping dotted line in the OSD overlay?
bixler 2 maiden ny motor 2200kv (4 min 16 sec)
Efti is offline Find More Posts by Efti
Old Nov 20, 2012, 03:38 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
debugging. set the neutrals again and they will go away. see the rangevideo.com forums for more information.
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Nov 21, 2012, 08:26 PM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
Does any of the RVOSD;s work with Futaba S-Bus?
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Nov 22, 2012, 10:25 AM
Efti is offline
Efti's Avatar
Joined Oct 2011
Thanks.
It worked
Old Nov 22, 2012, 01:24 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
I am not sure if this has been addressed before...
From what I see, most pilots that are using this OSD are paired up with a LRS and are not flying on 2.4
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: New Drone Movie :D
Old Nov 23, 2012, 07:39 AM
Macattaka is offline
Find More Posts by Macattaka
Beyond the BlackStump
Macattaka's Avatar
Australia, SA, Adelaide
Joined Mar 2006
Strange issue today with a new RVOSD, unboxed and installed into a Zephyr and ran wizard, all good except the AHI is REALLY SLOOOOOOWWW ie: I lift the nose up 45 deg and the AHI takes about 7 seconds to get there. FBW reacts at the same speed as AHI. Everything else seems to be working correctly.
Cheers,
Al
Macattaka is offline Find More Posts by Macattaka
Old Nov 26, 2012, 01:37 PM
MrBen. is online now
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
are you using 2 lipo setup? if so try powering your osd up first and letting it initialize before pluggin in the 2nd lipo, assuming you are not on the 5.1 fw then updating to this should help/resolve the issue.
MrBen. is online now Find More Posts by MrBen.
Old Nov 27, 2012, 04:18 PM
ktyildiz is offline
Find More Posts by ktyildiz
Joined Jul 2010
Hezarfen Airport - Around Istanbul, Turkey
We attached a 360 degree servo on our Senior Telemaster airplane and mounted our GoPro on it...
Here's the result:
Hezarfen Havalimanı Etrafında 360 Derece (3 min 48 sec)
Hope you like it... ;=)
Regards...
ktyildiz is offline Find More Posts by ktyildiz
Old Nov 28, 2012, 08:03 AM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
DL setup
Hi,
I am trying to setup my RVOSD G5 and have some question if any of you can answer please.
1. How many channels can i set on the PPM configuration with my DL Tx?
2. Do i need to connect an extra wire to ch 5 for changing the screen/autopilot modes or it can be set in the PPM stream?
3. Any guide on setting the ER9X three position switch to work with the RVOSD G5?
teopbako is offline Find More Posts by teopbako
Old Nov 28, 2012, 08:27 AM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
Originally Posted by teopbako View Post
Hi,
1. All ch
2. No just one, dlrx to rvosd
Yes, youtube it. How i did mine.
Been trying to do a video for it.
Ruben
RUBNorris is offline Find More Posts by RUBNorris
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
