Old Oct 22, 2012, 07:50 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Originally Posted by Wefinance01 View Post
I was thinking about soldering it but that thing should have not pulled that easily. I wonder if the unit was defective. I will send it to RV to see if they can fix it under warranty and if not, will have to see what he will charge me to fix it.
I pulled mine off () by pushing too hard on the plug. Its not defective, just fragile. If you look closely there are a couple of solder tags either side of the socket that are supposed to give some support. Also there is a little bit of double sided tape under the socket. Mine came away cleanly and didnt damage any of the tracks so I had a friend who is adept at SMC repairs re-solder it for me. He also reinforced it with epoxy.
RV standard $35 charge for OSD repair would probably cover it, but how long can you go without your OSD? If you are experienced with SMC soldering, go for it, otherwise give it to someone who is.
ommadawn is offline Find More Posts by ommadawn
Old Oct 22, 2012, 08:09 AM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Anyone using RVOSD fbw when launching ritewing z2 ?
octane81 is offline Find More Posts by octane81
Old Oct 22, 2012, 09:26 AM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
I hot glued each end of GPS cable into sockets with a little overflow onto the boards. I don't know how I ever survived before discovering HG. strong, flexible, fast bond and easily removed, perfect foamy adhesive!
picard10th is offline Find More Posts by picard10th
Old Oct 23, 2012, 02:48 AM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
GPS Triangulation
Originally Posted by picard10th View Post
Check GPS settings 10HZ and HDOP
From manual....
4.23 Configuring GPS
Be sure that the GPS fix update: is set
to 10Hz (default), if you are using the
included 10Hz GPS module.
RVOSD will display "Searching Sats"
when there is not any satellite lock
reported from GPS and will change to
"Setting Home" as soon as it locks on
the first satellite.
The RVOSD start the ‘Setting Home"
timer after GPS HDOP value goes
below Set max HDOP: value.
-This value sets the minimum GPS
signal Horizontal Dilution of Position
(HDOP). -Its recommended to set this
value to the minimum possible (around
1.00) to have an accurate set of zero
altitude and home GPS coordinates,
with this value to low. Setting it to 1.30
seems to be the best compromise
between accuracy and lower time to set.
Keep in mind that this must be done
with clear open sky visibility.
This is true as long as accurate triangulation exists.
We all know these low Earthorbiting GPS sats fly around fast to keep their orbit.
One sat can fall off the horizion and a gps rcvr loose accuracy within 15 min's. Or another can be overhead and reflect a stronger signal off a cliff edge adding latency error. DOP can change at any time.
I am still trying to determine why some want to put a foil cup around their GPS rcvrs on other forums.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Oct 23, 2012, 09:53 AM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Because it works!
I don't use a cup, but a flat sheet of foil really speeds things up on my DOSD GPS. I haven't had any problems with the RVOSD GPS yet.
iskess is offline Find More Posts by iskess
Old Oct 24, 2012, 12:12 AM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
I might have to try the gps foil trick. Swapped my RVOSD into a new plane and it noticeably takes longer to get satellite lock.
Stunt Double is offline Find More Posts by Stunt Double
Old Oct 24, 2012, 05:46 AM
Joined Feb 2011
Horizontal front end overload
You might be right the distance to the new VTX placement might blind the Gps Rcvr's ability. Also the foil cup might lessen the Gps birds on the horizon that are far away even though they might make a better 3D coordinate in time.
Old Oct 24, 2012, 03:50 PM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
anyone knows where i can buy just the gps connectors?
timtimtim is offline Find More Posts by timtimtim
Old Oct 24, 2012, 05:50 PM
uavrat is offline
Find More Posts by uavrat
Joined Jan 2012
From the RV forum:
you can use this on the GPS side: https://www.sparkfun.com/products/10361
And this on the OSD side: https://www.sparkfun.com/products/10360
Soldering any extra cable length in between.
24" length is OK
uavrat is offline Find More Posts by uavrat
Old Oct 24, 2012, 06:42 PM
Joined Apr 2012
Originally Posted by uavrat View Post
From the RV forum:
24" length is OK
why is it two different connectors?
Old Oct 24, 2012, 06:53 PM
npre is offline
Find More Posts by npre
Joined Jan 2011
the GPS comes with one more pin which is used for a feature that isn't needed
npre is offline Find More Posts by npre
Old Oct 24, 2012, 07:00 PM
Joined Apr 2012
Alright! Thank you
Old Oct 24, 2012, 08:57 PM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
i always launch my DeepReaper FBW, ALWAYS, never had a problem,
Max throttle, side throw, walk back to my chair not looking at the wing.
check it out, excuse the mud on lens...
DepReaper XL, 3 Juin 2012, vol dans les nuages et test du nouveau RVGS Antenna tracker. (2 min 34 sec)
bakchos is offline Find More Posts by bakchos
Old Oct 24, 2012, 11:25 PM
Wefinance01 is offline
Find More Posts by Wefinance01
RCMafia
Wefinance01's Avatar
United States, GA, Roswell
Joined Jun 2008
i went ahead and ordered the 35$ service repair from rv but not clear in how that work......do just send them the unit with my reciept or what?
Wefinance01 is offline Find More Posts by Wefinance01
Old Oct 25, 2012, 04:41 AM
Joined Feb 2011
Soldering Art
Soldering, Brazing, Welding is a Art that takes a understanding of Temperature, Time, Flow and Material over the workplace. If for example a soldering tip has low temperature it may (over time) heat other connections on a board and disconnect them. Personally I like to flow the work hot and fast then cool it down fast also.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
