Old Oct 06, 2012, 10:40 AM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
hi Khaled ,
Sorrry to hear about your plane. I.ve learned a few the hard way too.
1. check failsafes each time
2. use a BEC
3. have a gps tracker watertight and padded.
Didn't you record the last gps coords.
picard10th is offline Find More Posts by picard10th
Old Oct 06, 2012, 12:34 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Originally Posted by picard10th View Post
hi Khaled ,
Hello
Can you tell some about GPS tracker ?
Firatp is offline Find More Posts by Firatp
Old Oct 06, 2012, 01:17 PM
picard10th's Avatar
Joined Jan 2007
[QUOTE=Firatp;22929216]Hello
Thanks[/QUOTE
Call from a phone and it texts back GPS coords. need a sim card.
There's some threads http://www.rcgroups.com/forums/showthread.php?t=1608563
Old Oct 07, 2012, 03:05 AM
Macattaka is offline
Find More Posts by Macattaka
Beyond the BlackStump
Macattaka's Avatar
Australia, SA, Adelaide
Joined Mar 2006
Screen 0
Anybody seen this screen before?
It has been working flawlessly this week until I powered up today. I can cycle through screens numbers (0, 2,3,4) 0,2 &3 are as below, screen 4 is the config menu. I'm guessing screen 0 is some kind of factory default? maybe screen 1 is the OSD. I rebooted several time but no joy, help? Daylight Savings just kicked in here so I have heaps of good light after work
Name: RVOSD issue.jpg
Description:
Macattaka is offline Find More Posts by Macattaka
Old Oct 07, 2012, 11:33 AM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
Sent you a PM. My guess is that there was a voltage instability that affected the firmware. Maybe an static discharge.
Will be checking the firmware just in case.
Elcheapo is offline Find More Posts by Elcheapo
Old Oct 08, 2012, 04:32 AM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Hi
I've done the following mistakes ... actually very expensive mistakes .. but I didn't expect a Long range UHF system to have a very short range of less than 200 m by flying only line of sight ... because of some interference somewhere ... I thought I will have at least 1000 meter of range in the worst case not less than 200 m ..live and learn ...
1- I didn't have a recorder
2- I didn't do a range check with the video gear on/off
3- I haven't waited for the sat lock to finish...
4- I didn't write my phone number on it
5- I didn't have any means of locating (GPS tracker, UHF beacon )
6- haven't checked noise floor ..
Although I had all of those on my check list .. but I didn't know I should have done so even before the very 1st short range LOS flight ...
But I want you all to know that I almost got that expensive bird fine tuned and it was able to fly itself in strong winds very stable .. Thanks to the RVOSD autopilot ...
and I didn't have any intention to fly FPV... I only wanted to fly short range line of sight .. just to get the feel of the plane and practice launches .. the last thing I expected is to get a fail safe in less than 200m ...
EZUHF R/C link on 433mhz
Video on 1280mhz (300mw VTX with a cloverleaf )
I used shielded cables, torroids, twisted wires, .. I was really careful on that build ...
a separate sBEC to power the servos , a separate SBEC to power the camera/ VTX
Layout is typical .. like all the pilots of a Zephyer have .. VTX is located midway of the right wing and the EZUHF RX is located midway of the other wing ... GPS antenna is near the middle section on the EXUHF side ...
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Oct 08, 2012, 07:44 AM
rclab1 is online now
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
khaled,
why did the EzUHF go into "failsafe" mode at such short distance?
If it did goto "failsafe", how come the RVOSD didn't RTH and loitered around your flying field?
Is it because you didn't "wait for the Satellites" to lock on? How long did you wait?
Maybe I missed a few steps?.... just wanted to learn from your expensive mistake.
Sorry about your $1000+ loss. That is a lot of money.....
rclab1 is online now Find More Posts by rclab1
Old Oct 08, 2012, 11:03 AM
cmanley_nl is offline
Find More Posts by cmanley_nl
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
Does anybody know where to get a GPS extension cable or which connectors I must search for on ebay? I don't want to pay at $15 or more int'l shipping costs (to Europe) for a $2 item that fits in an envelope.
cmanley_nl is offline Find More Posts by cmanley_nl
Old Oct 08, 2012, 12:30 PM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Alex listed the correct connectors on the RV message boards. It's the same connectors for Cyclops, so I copied the link for those users in the Storm and Nova threads. I don't have time to look now, but search my posts and you will find it, or go to the RV message boards, they are better for RVOSD anyway.
iskess is offline Find More Posts by iskess
Old Oct 08, 2012, 01:17 PM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Cmanley if you find the link please link to us..
IMEIV is offline Find More Posts by IMEIV
Old Oct 08, 2012, 01:29 PM
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
Thanks iskess.
@IMEIV:
Below are the relevant links I've found so far for replacement GPS cables/connectors..
Alex's answer:
http://rangevideo.com/forum/showthre...nnecting-cable
This may be a compatible cable:
http://hobbywireless.com/index.php?m...roducts_id=523
These are the connectors Alex recommended (JST SH 5 & 6 pins):
https://www.sparkfun.com/products/10360
https://www.sparkfun.com/products/10361
This is the 6 pin connector from Ebay that fits the GPS:
http://www.ebay.nl/itm/Micro-JST-1-0...ht_2238wt_1111
Last edited by cmanley_nl; Oct 15, 2012 at 12:50 PM. Reason: Removed 5 pin connector link from Ebay because it doesn't fit
Old Oct 08, 2012, 01:39 PM
Firatp is offline
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
I used this,
http://www.ebay.com/itm/Mini-Micro-J...item27cb27f00b
You need desolder connector on OSD board then solder the male connector.
works fine..
Any alternative, please share
Firat
Old Oct 08, 2012, 01:44 PM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Thanks iskess.
@IMEIV:
Alex's answer:
This may be the cable:
These are connectors from Ebay that someone recommended (although I have my doubts about if the 6 pin connector link is correct):
http://www.ebay.nl/itm/Micro-JST-1-2...ht_2225wt_1111
Originally Posted by Firatp View Post
I used this,
works fine..
Firat
You're great men..
Old Oct 08, 2012, 03:15 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
There is just soo much information to sort through on this thread, I was curious if someone might be able to direct me to a schematic of wiring the RVOSD to DragonLink and Lawmate.
...I read the directions, but cant seem to process the info
is this right?:
http://www.rcgroups.com/forums/showp...postcount=1500
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Oct 09, 2012, 12:13 PM
picard10th's Avatar
Joined Jan 2007
Thats about the same as mine started doing, It's in for repair at RV been a few weeks now hopefully it's being replaced or sent back today
Attachment 5212452
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
