Old Sep 20, 2012, 09:53 AM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Originally Posted by iskess View Post
How do you make an anti-vibration mount? The RV one is too big for the belly of my Twinstar.
This is how I have done it, and it works just perfect.
- Kim -
SpookiePower is offline Find More Posts by SpookiePower
Old Sep 20, 2012, 12:49 PM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
the waypoint feature is great, but once you done it a few times it like erm .. been there done that ... you kinda feel like a passenger ...
Blackrat is offline Find More Posts by Blackrat
Old Sep 20, 2012, 06:00 PM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
- Kim -
Thanks Kim, that looks like a really simple solution. What are you using to adhere the foam to the plane and PCB?
It doesn't seem very secure without something like a strap, and a dislodge could spell disaster.
iskess is offline Find More Posts by iskess
Old Sep 20, 2012, 06:04 PM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
I hear you. I don't care about the autopilot function as much as the ability to map waypoints, even of I just manually fly to them, or just have them for reference and orientation. These could be areas to avoid as much as points to navigate to.
Old Sep 21, 2012, 06:16 AM
Joined Jun 2009
I use this type of tape. So far the RVOSD have been "glued" like this for about a year now. Sometimes I try to gently pull the RVOSD just to test if the tape is still working but so far now problems at all. But just for the safety maybe I should change the tape each year.
- Kim -
Old Sep 21, 2012, 08:40 AM
flashervn is offline
Find More Posts by flashervn
Joined Sep 2011
Hi guys. Im having problem with my (brand new)RVOSD 5. Lagging AHI no matter what order of the batts I plug in. I disabled main batt (4s) as it will fry my Vtx so the RVOSD is powered by the Aux batt which is a 3s. I always wait a full minute before I plug in the other batt, no matter if its the main one or the aux. Any idea? Thanks
Minh
flashervn is offline Find More Posts by flashervn
Old Sep 22, 2012, 06:51 AM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
Post in rangevideo forum. Alex will hook you up.
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Sep 23, 2012, 12:37 AM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Range Video Forum url
http://rangevideo.com/forum/forumdis...hp?3-RVOSD-FPV
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Sep 23, 2012, 04:14 PM
KC9TPL- Get Legit
Joined Aug 2007
In RVOSD v5, Is heading hold the same as level flight but it tries to keep the same heading too?
Old Sep 23, 2012, 04:29 PM
Wefinance01 is offline
Find More Posts by Wefinance01
RCMafia
Wefinance01's Avatar
United States, GA, Roswell
Joined Jun 2008
My V5 is on its way...yeppie!
Were any of you gents able to successfully use the Gopro as primary cam for day and Kx191 as secondary camera for night....both controlled by camera switch? The manual states to remove the resistor but is it still required even when using a camera switch? If it is required then do I need to do anything else to have the KX191 to work. I have seen the Gopro not working correctly without the resistor removed.
Wefinance01 is offline Find More Posts by Wefinance01
Old Sep 24, 2012, 06:10 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
The KX191 works very well as is with no modifications. However some camera switches aren't compatible with the RVOSD.
boopidoo is offline Find More Posts by boopidoo
Old Sep 24, 2012, 07:49 AM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
It all depends on impedance and video level. The tx needs the 75 ohm impedance and video of 1 Volt P to P so not to overdrive the it. the GoPro is non standard video out . I also use a 191, it's a great camera for a all around use.
Martin Y is online now Find More Posts by Martin Y
Old Sep 24, 2012, 08:34 PM
MK3 is offline
MK3
Find More Posts by MK3
MK3
Aerial Loitering
MK3's Avatar
Joined Sep 2011
Hey guys.. I'm using Dragonlink and RVOSD. I want the DL rx to handle Failsafe conditions, not RVOSD.
I've set failsafe on the DL to RTH on RVOSD... so I don't need the OSD to be checking for failsafe on the throttle channel, it's a bit redundant.
Hope that made some sense... How can I do this?
MK3 is offline Find More Posts by MK3
Old Sep 24, 2012, 09:54 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
DL failsafe alone cannot RTH. You need a DL failsafe to trigger RVOSD RTH failsafe.
Stunt Double is offline Find More Posts by Stunt Double
Old Sep 24, 2012, 11:51 PM
RCMafia
Joined Jun 2008
i got my cam switch from hobbywireless from hobbywireless. so if i remove the r11 resistor...will i have problems with my kx191?
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
