Old Sep 13, 2012, 10:04 PM
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
RVOSD saves my plane
Lost DX7 signal @1.2 miles I was already trying to get back because of bad video. Very windy and I was disoriented in unfamiliar area. I just noticed while coasting home, no throttle groung speed was over 40mph. I really had to nose her down to lose altitude, hit over 70mph in down spiral.
71mph Skywalker Condor Saved by RVOSD (27 min 20 sec)
Just placed a big order with RV I was so pleased!
picard10th is online now Find More Posts by picard10th
Old Sep 14, 2012, 08:09 AM
bjornthans's Avatar
Norway, Troms, Skjervoy
Joined Jul 2012
just a question. is it possible to just run the osd and get the information that is there without a camera connected via the vtx? lets say your camera dies or something like that?
bjornthans is offline Find More Posts by bjornthans
Old Sep 14, 2012, 09:21 AM
picard10th's Avatar
Joined Jan 2007
No, needs a cam connected. I patched a canon camcorder output one time so I could read the osd.
Old Sep 14, 2012, 09:28 AM
Canada, ON
Joined Jan 2009
If I'm correct RTH still works if your camera dies.
Martin Y is offline Find More Posts by Martin Y
Old Sep 14, 2012, 10:23 AM
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Yes it works
Firatp is offline Find More Posts by Firatp
Old Sep 15, 2012, 02:27 PM
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Bump #3
So nobody has answered my simple questions about how the RVOSD handles waypoint navigation. In re-reading my post, perhaps I am coming across as critical of its capabilities, which may in turn seem critical of Alex. I'm sorry if this is the case, it was not my intent to behave like one of the Trolls that haunt these forums. I am honestly trying to gain a complete understanding of the limitations of the RVOSD waypoint navigation functionality.
Originally Posted by iskess View Post
Bump....
Can someone please confirm that my understanding of the limitations of the waypoint functionality are correct. This is not clear from the manual or the videos I've watched.
Thank you for your time.
Originally Posted by iskess<br />
Let me know if i understand this right... <br />
So if I havent used the waypoint sequencer yet, it will show waypoints 1-5. <br />
There is no way to show waypoint 6 unless I let the autopilot fly to waypoint 1 first. The only way to fly to waypoint 6, is to fly the whole route 1-5 first, and I can't stop and loiter at waypoint 5, it will move on to 6. If it moves on to 6, I would have to turn off the waypoint sequencer and re-engage it, which would cause the autopilot to fly back to 1 and start all over again. <br />
So the only real way to have it fly directly to a waypoint any time you want is to have that waypoint be 1, and set Last Waypoint to 1.
iskess is offline Find More Posts by iskess
Old Sep 15, 2012, 03:46 PM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
I would say your second post is quite correct. It does fly to each waypoint in sequence.
boopidoo is offline Find More Posts by boopidoo
Old Sep 15, 2012, 06:26 PM
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Thank you!
So if I turn off the autopilot at waypoint 5 to manually circle the point and look around, then turn the autopilot back on again, will it continue to #6 or start again at #1?
Old Sep 17, 2012, 01:07 PM
Joined Sep 2011
Hi, I just got my first RVOSD 5. Can anyone please tell me where is the best place to put it on a Skywalker? I also have the anti vibe mount from RangeVideo. Thanks
Minh
flashervn is online now Find More Posts by flashervn
Old Sep 17, 2012, 01:39 PM
Non nobis, Domine, non nobis
dayanki's Avatar
Joined Dec 2010
Minh
Hi, the Skywalker is cavernous, you can put the RVOSD wherever you want. This is an example.
dayanki is offline Find More Posts by dayanki
Old Sep 17, 2012, 02:32 PM
Joined Sep 2011
Hi, thanks for the answer. What I was really asking is where to install it on a Skywalker so it is
1. Nearest to CG
2.With the least vibration
In the example you shown, isnt it too close to the motor where most of the vibration happens? Thanks
Old Sep 17, 2012, 02:40 PM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Thank you!
I'm sorry I haven't tried to do that so I don't know.
Old Sep 17, 2012, 03:18 PM
dayanki's Avatar
Joined Dec 2010
1. Nearest to CG
Hi, I do not own the skywalker (but I own the RVOSD5). In the example it seems to me that the RVOSD is located near the CG of Skywalker, though this is not essential. IMHO, with the anti vibration mount you need not worry too much, instead check the balancing of propeller and engine.
Old Sep 17, 2012, 03:48 PM
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
This is how I made it: it's in the CG, takes almost no place (you can fit batter under it) and accessible via side door. RVOSD is in that black shrink wrap (I had no transparent one when I was replacing G4 to G5 board), I made my own anti-vibration mount (yellow), it was before RV made their own :-). Also the current sensor is in black shrink wrap - next to BEC. Final placement of ESC is on the opposite site. GPS is under the wing, next to LRS RX. I'm very satisfied with this placement, vibrations are no problem, I can take it out when I need to upgrade firmware (Alex knows how many times I did so )...
Oh, and one more thing: NEVER use that pan and tilt from BEVRC. It's a piece of ...
Rastislavko is offline Find More Posts by Rastislavko
Old Sep 18, 2012, 03:22 AM
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Thank you!
Does anyone know what happens if you turn off the autopilot in the middle of a waypoint sequence, then turn it back on?
Will it continue the sequence from where you were, or will it start over at waypoint #1 again?
Discussion Maiden Reports 12345 Arizona Model Aviators 466 Apr 23, 2013 06:29 PM
Help! RVOSD thermal sensors rcmonster99 Video Piloting (FPV/RPV) 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
