What I am saying is that you don't lose GPS lock unless there is a problem of interference on board or the GPS unit or cable are defective. This is not something that you realize on the very moment you lose RC link, but all over the flight.
On that case is better to come back and fix the issue, instead of pushing your luck. |
Excuse me, I haven't flown with the RVOSD yet.. Are you saying that while airborne, if you loose GPS lock, you quickly go into the menus and change from RTH to Failsafe, just in case you loose RC radio contact? This item is available in the airborne menus? |
This is rubbish...
I was flying away and lost gps signal so decided to turn back home but when turning back my rc rx antennas were in different orientation so rvosd went into rth mode not knowing were is home... It started to circle and plane was blown away by slight wind, last time I seen it was 12 miles away.... Never found it. $800 gone. Big thanks to RVOSD 5! |
No, I am saying that you don't lose GPS lock in flight unless there is interference on board, the GPS module is defective, or the GPS cable is damaged. Then you have to go back home and fix the issue. Or disable the autopilot for the next flight, you can't do that in flight.
I have quite few hours of FPV flights, never experienced GPS lock lost in flight, not even inside storm clouds or very high altitudes. If there is an interference on board you will notice it even before take off, the problems with GPS cables(connectors) or bad modules will be intermittent and the OSD will display the "GPS disconnected" advice. I think there is no reason to lose an airplane because of this, unless you ignore all common sense and dare beyond safety. |
Also I would love to know what type of autopilot programming could had saved your plane with this three conditions together: 1-GPS lock lost. 2-RC link on the edge of distance budget, not able to get it back even with airplane circling above RC link lost position. 3-Winds taking the airplane away from home. |
This way we all can see whats going on and maybe someone can help you find the problem. |
many people had problems with rvosd gps rx. bad cable or plugs... there was no interferance on board... i got gps lock quickly on ground. It doesnt matter now alex.... my lost your gain by using cheap components.. anyway - most important !!! RVOSD should NOT allow RTH mode without GPS lock ! |
It wasnt controlled circle - just random turns - sometimes right sometimes left.... 1. RTH should NOT engage without gps signal. 2. Plane wasnt circling above rc link lost position - as i said before it was just random turns and flying away ... Im not saying that rvosd is bad. it works easy out of box. But due to "programming" errors and poor quallity of gps ?sensor,cable,plug? it can be very danger and its more risk than safety future |
Can someone confirm my latest understanding of the limitations of the Waypoints feature here...http://www.rcgroups.com/forums/showpost.php?p=22680389
I'm trying to gain a full understanding of what the RVOSD can and can't do. The videos posted help, but they are not a tutorial so they don't explain how to actually use it. |
However the connectors are fragile, not meant to be twisted around many times. We used it on RVOSD because is the standard connector used on the locosys GPS units. I had thought to change them few times, but never did because didn't wanted to left old users without replacements for their cables and GPS modules. So kept them for the sake of compatibility. I can not program RVOSD to send the airplane on a step dive to crash if there is a GPS failure. The odds are much better if it does what it does now. Gentle circle waiting for RC signal to come back. |
| Thread Tools | |
| Discussion Maiden Reports | 12345 | Arizona Model Aviators | 466 | Apr 23, 2013 06:29 PM |
| Help! RVOSD thermal sensors | rcmonster99 | Video Piloting (FPV/RPV) | 16 | Jun 20, 2011 10:21 AM |
| Discussion Weekend weather reports | neck | Arizona Model Aviators | 13 | Jun 10, 2011 04:59 PM |
| Discussion where are the Joe Nall horror "reports? | guy hanson | Radios | 49 | May 18, 2011 12:06 PM |
| Discussion Finally Fixed the Country Reports | daboz | Dynamic Soaring | 5 | May 16, 2011 02:51 AM |
